Question about Princeton Digital VL1716 17" LCD Monitor
White Display My Princeton VL1716 display is kind of bleached white and the letters show up purple, Greem and black. When I restart my PC the display works fine for awhile but it goes back to being white again after about 5 minutes. Any help would be appreciated.
  • 37 Answers
Here is two solutions:
1. Grab a LCD Color Tester, Run it through RGB.
- If it is still white its the LCD
-If it not at all either the inverter board is bad or the mainboard.
2. Sometimes its brightness control, look under the manual.
Posted on Aug 04, 2009
My MacBook Pro display screen is looking very strange....like a color photo negative of what it should be. White backgrounds are black, black letters are white and so on. I heard there was a problem with...
Don't worry you have put on one of the universal access settings if you go to system preferences and then universal access under display change the setting from white on black to black on white. Hope this helps
Dec 03, 2010 | Apple MacBook Pro with 17" Display
Monitor says out of range
The PC video resolution is too high for the monitor to display, you need to lower it to the native resolution of your monitor, see your owner manual.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Failed TV and monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 29, 2010 | Princeton Digital VL1716 17" LCD Monitor
Princeton VL1716 monitor displays "out of range" and the background is black when connected to compaq CPU and pugged on.
The set resolution is incompatible with the monitor. Use a monitor that works, change resolution then retry
Nov 29, 2009 | Princeton Digital VL17151 17" Flat Panel...
Princeton Digital VL1716 Monitor "No Signal Message"
Roxio Changed Your display settings on the dual display.
Right Click on desktop>goto Prefences>
You should see both monitors indentfy the one and change it to a lower resolution.
Apr 28, 2009 | Princeton Digital VL1716 17" LCD Monitor
"Black/White" display theme
one possible solution would be to flash the old black prada firmware onto the silver phone; as far as i know the hardware of the phones are identical?
however, you would lose the white theme, qwerty keyboard etc.
Jan 16, 2009 | LG Prada KE850 Cellular Phone
I have a kenwood krc-3005 radio I do not have a wire diagram can you help
Yellow (+) Constant 12 Volts
Red (+) Switched 12 Volts
Black (~) Ground
Blue w/white stripe (+) Remote Out(used to turn
on the amplifiers)
Orange w/white stripe (+) Dimmer IN(used to dim
the display of the unit)
NOTE. if you dont want to hook up this wire it doesnt matter)
SPEAKERS OUTPUTS
White(+) Left Front
White w/black (~) Left Front
Gray (+) Right Front
Gray w/black (~) Right Front
Green (+) Left Rear
Green w/black(~) Left Rear
Purple (+) Right Rear
Purple w/black (~) Right Rear
Jan 04, 2009 | Kenwood KRC-207S
Toshiba satellite m35x s149 displays red pixels for black pixels
if you have a warranty - have the manufacturer replace the lcd display unit.
Sep 26, 2008 | Toshiba Satellite 2250XCDS Notebook
LCD show purple or violet cast on white areas when using auto mode
Have you tried viewing the photos on a computer or printing them? There should also be parts of the menu/setting displays that would be white. The text on the image info should be in white.
If you are getting white, it would suggest your whitebalance isn't set correctly. If everything has a purple tint to it, check your LCD display settings, otherwise it may be the screen is failing.
Dec 31, 2007 | Nikon D40x Digital Camera
My camera will only take pictures of a purple screen
Sounds like a defective CCD imager. You may be in luck. Canon should fix this for you for free, including free shipping both ways. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Oct 28, 2007 | Canon PowerShot A85 Digital Camera
Princeton Digital VL1716 17" LCD Monitor Logo
184 people viewed this question
Top Princeton Digital Computers & Internet Experts
Josh Whitehead
Josh Whitehead
William Ward
Level 1 Expert
Fishlung
Level 1 Expert
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
