The washer was making the (apparently) usual noise in the spin cycle before there was this burning plastic smell and the drum stopped spinning. The motor kept running, however, until the end of the cycle.
Disassembly revealed that the pulley wheel had fallen off. (I identified the part on the Maytag website)
How do I replace it?
What else should I replace in the process?
No apparent leaks. Motor appears to run properly.
Less than 3 years old... repair or replace it???
THANKS... Vandy
WHICH PULLEY FELL OFF YOU HAVE 3 OF THEM ONE IS A "IDLER PULLEY FOR DRIVE BELT" ANOTHER IS "PLASTIC HELIX, TRANSMISSION DRIVE PULLEY" AND LASTLY IS "PULLEY FOR TRANSMISSION DRIVE" GO TO www.repairclinic.com ENTER MODEL NUMBER AND SCROLL ALL THE WAY DOWN TO THE RED 100 CLICK IT AND LOOK FOR PARTS 550204, 889619, AND 889618. YOU MAY HAVE TO WORK ON THIS FROM THE BOTTOM TO GET TO THE PULLEY. IF YOU HAVE A MECHANICALLY INCLINED FRIEND, IMPLORE HIM OR HER TO HELP YOU UNLESS YOU CAN GET THE TUB OUT AND WORK YOUR WAY DOWN
The Maytag part number is 40045001 (pulley, wheel qR).
It's black pulley 2 1/4 " diameter / 1" thick.
After checking your link I am sure its the idler pulley for the belt drive.
Does that pulley just "drive" onto the shaft or was there a "keeper"?
Thanks!
can't figure out how to get the motor pulley wheel off.
