Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
How to print from LAPTOP - Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
  • suezinjane Apr 18, 2009
    i have tried to print someting off my computer ie laptop, and it wount print, the inks are new and ok,cables are connected to laptop and printer,i have uninstalled the software and then reinstalled it, and it still wont print from the laptop
  • Anonymous May 11, 2010
    "my car won't start"....think about it!!!
    Genius:
  • 1,847 Answers
Do you get any error message.
Is this the first time you are using teh printer.
let me know
Kevin
Posted on May 27, 2009
Have a dell laptop and can't print on my computer using ctrl, shift and p. I think there is something wrong with my laptop because the printer prints for other computers but not this one. How do I fix the...
go to printer and faxes make sure the printed is properly installed in your laptop and make sure it's on the default checked mark... then do some test print
Aug 28, 2013 | Regal Ware Kitchen Appliances - Others
Right i have new laptop have loaded up disk for printer, and when i click print on laptop it prints something else that i printed last time i used the printer. it is a bx300f thankyou
Check what is in your print queue before printing. If a document fails to print completely it may remain in the print queue even if you turn the laptop off.
Feb 16, 2011 | Office Equipment & Supplies
My printer is always offline and when i click print it never prints! I have my laptop connected to the printer through a wire. Is is a Samsung CLX-3175FW. My laptop says that the print job is in the queue...
Unplug your printer from the power outlet and from your laptop for about 60 seconds. This will reset it. Plug them back in and try again after your laptop has recognized it. If this does not work uninstall and reinstall the print drivers and software. This should work for you and you will be able to print. Hope this helps!
Lori
please leave rating if this helps! thx
lori@computersolutionsbylori.net
www.computersolutionsbylori.net
Oct 14, 2010 | Office Equipment & Supplies
Can't print to HP 2600n over network
The LaserJet 2600N has a built-in print server and can be connected to the local network (normal ethernet cable) directly. While printer sharing via Windows should work, I found it much more convenient to access it without the need of a hosting computer - you do not need to switch on the desktop PC for printing from the Laptop, for example, its also printing faster.
Jan 25, 2010 | HP Color LaserJet 2600n Printer
Wifi laptop will not print to printer - not a wifi printer
Check if the printer has a wireless option. Actually this issue is complex. First thing first, you can print wirelessly from your laptop within the WIFI range in a case that your printer do have wireless on in. It is impossible to print wirelessly from the wired printer through LAN.
One thing, I guess you don't have a wireless router. You need to have a wireless router like LINKSYS that is easy to setup then try to connect wirelessly to the wired printer. There I am not too sure if your can do a printing option from your laptop wirelessly.
Lastly, check if you have a ROUTER and need to set it up on your laptop and on the network LAN. You may now have a NETWORK printer in this regards. Thank you.
Oct 06, 2009 | HP Compaq Presario V6000T Notebook
Networked laptop will not print to any network printer. Getting error message that there may be a memory problem or cable problem. Memory is fine and cable are fine. Others in the office are printing fine....
Do you still have access to the Internet from this laptop? If not your Laptop isn't connecting to the network you won't be able to print. Check and see if your laptop is set to DHCP which will automatically assign the correct IP Address to enable your laptop to connect to the local network. If all this is correct you may have to delete and re-install the print drivers for the printers you want to print to.
Aug 18, 2009 | Office Equipment & Supplies
Cannot print from laptop to printer using wireless print server
This is probably the Software Firewall on your laptop
you should probably tell your firewall software that you have an internal network (Laptop-desktop-printer) you should add the IP range of the wireless network as a trusted network.
May 25, 2009 | Lexmark X3550 ALL-IN-ONE InkJet Printer
Printer's printing black instead of colored.
the printer is fine its the computer that you are printing from that is giving the wronge information. try reinstalling it onto that computer. and check that the background on the word documents are not black on print prevew first. or you have not chosen on the program you are printing from there is not a background colour that needs sending to the back.
Mar 26, 2009 | HP DeskJet 3745 Printer
My printer(hp laser jet 1320) dosen't print correctly in more then 30 pages.
sounds like a memory issues or a windows swap file problem. when printing large docs u need to have some free memory in the computer. Also some printers 2 day used windows memory to print so if your pc only has small amount of free memory it can effect printing out large docs. also with a laptop it shares it memory with the video GPU. so you may need to upgrade your memory in your laptop .
Sep 25, 2007 | HP LaserJet 1320 Printer
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
171 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
