Check firing order also plug wires and coil take water bottle spray water on wires and coil if you see a spark theres your problem
Every other time we start and drive it...it does this cutting out and jerking. They gave code P1391...what is that code for??
Every other time we start and drive it...it does this cutting out and jerking. They gave code P1391...what is that code for?? It has new wires, plugs, coil, pickup coil. Crank sensor and rotor.
SOURCE: 1995 JEEP GRAND CHEROKEE RAN AND DIED WILL NOT START
They are easy to replace. Here is the location It is near the top of the transmission bell housing just to the left of
centerline. You will need to unbolt it from underneath using a 7/16"
socket on a long extension. Before doing so, set the parking brake and
disconnect the transmission shifter linkage. Do this from underneath
the truck. Let me know if this helps you at all
SOURCE: my 1996 grand cherokee laredo 4.0 misfires code
If you're saying that you already had the troublesome crank sensor replaced then maybe your electrical connections to the sensor is bad, somewhere, along the way to the ecu.
SOURCE: My 2000 Jeep Grand Cherokee Laredo had the
depending on how long it sat, and also on if you had the code cleared when you replaced the o2 sensors could be why the light is lit, Now for the not starting, again depending on how long it sat ,, check the fuel pressure, you need a constant 6 lbs of pressure , also check for fire, pull one of the plugs,, reattach the plug wire to it,, hold it with a pair of insulated pliers, and ground the bottom of the plug to ground, any bolt attached to the motor ( as long as its a metal surface) will do, have someone crank the motor , Look for a nice blue spark arching across the tip of the plug, if it does, you have spark, put the plug back in, if it doesn't, you need to back track the electrical system,, follow the wire back to the dist cap,, remove the cap, check for any burn marks or charred or eroded contact terminals inside the cap,, also check the rotor tip, and contact rotor button in the center of the cap,
