Question about Dryers
Im useing a plug from dryer to wire directly to welder i dont know what color wires are on dryer because they are all the same color gray ??????
Im useing a plug from dryer putting it on a 220 welder the plug that i took off welder told me where black white and green went on welder terminals the problem is i dont know which is which on the plug from the dryer as the wire is all one color
  • 686 Answers
THE OUTER ONES ARE HOT AND THE MIDDLE ONE IS YOUR NEUTRAL
Posted on Apr 18, 2009
  • James Chandler Apr 21, 2009
    your cord is grey terminal 123, 1 and 3 are the hot wires and 2 is the ground or neutral. Iwork with dryer cords all the time and don't appreciate a bad rating
Make extension 220 volt cord for 220 volt welder
most 220v welders have a NEMA 10-50 plug or the NEMA 6-50 plug--the input /output ratings thru recepticle and thru plug are same-configuration of plug prongs are different( Grainger Catalogue shows simularities and differences) main difference is AC Horsepower Ratings are different, and that applies Only on equipment that uses 3 phase, not your welder.Use an Ohmmeter to touch unpowered wire connection under shroud at ground and plug prong, then red power connection to corresponding plug prong, and again to black connection and plug prong,mark them w/ felt pen w/ corresponding colors (Green, Black Red). Change out wire plug to fit into dryer or stove recepticle, or make an extention adapter plug witch fits stove recepticle and extends out thru floor to carport and goes to 10-50 recepticle-whereas ground green goes to W position (Center) Y is Black and goes to Y Black, X is Red and goes to X red and cap off the white neutral coming from plug -welders and hot water tanks do not return unused electrcity via the white neutral (return) wire--they use up what is available on demand in heating elements or in welders - the electromagnetic field.GET HELP DOING THIS, by someone who has knowledge, SKILLS and EXPERIECE. I have 1 welder fitted to go into dryer plug which has 14-30 recepticle, and i have 1 where i kill stove circuit at panel, unplug stove, plug in 14-50 plug which has a 10-50 recepticle on other end, plug in welder 10-50 -p, flip cicuit breaker switch to on-welder has full power range capacity. No oven in use while welder going--but probably wouldnt run it anyway if on different circuit.Any doubts whatsoever--anything not 100% clear--DO NOT DO THIS or any other Electrical Manipulations--have a licensed electrician stub in a secondary circuit breaker off your main if load is acceptible and have him wire in the recepticle which your plug will fit into---.
May 31, 2012 | Craftsman Welding Tools
Changing out 220 cord
Here is a tip that I wrote that will help you to figure out that problem...
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
Jul 03, 2010 | Amana NED7200TW Electric Dryer
I have a 1996 dodge grand caravan with 8 speakers. Im hooking up a kenwood stereo but I can only get 4 speakers to turn on. How do I get the other 4 to turn on?
here is the wire digram hope it helps
Factory in-dash wire harness (this vehicle has a 2 pc harness)
that snaps into the factory radio
Black Plug
Gray Plug
Radio Wire & Color Code Information Page 2 of 2
Typical Dodge/Chrysler Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (-) Blue w/ White Stripe Purple w/ Black Stripe
B Left Rear Spkr (-) Brown w/ Yellow Stripe Green w/ Black Stripe
C Right Front Spkr (+) Purple Gray
D Left Front Spkr (+) Dark Green White
E Right Rear Spkr (+) Blue w/ Orange Stripe Purple
F Left Rear Spkr (+) Brown w/ Blue Stripe Green
G Power Antenna/Amp White (use for Infinity Radio) Blue
H +12 Volt Battery Wire Pink or Pink w/ White Stripe Yellow
I +12 Volt Ignition Wire Red w/ White Strip Red
J Radio Dimmer Wire Do Not Use
K Headlight Dimmer Wire Do Not Use
L Right Front Spkr (-) Blue w/ Red Stripe Gray w/ Black Stripe
M Left Front Spkr (-) Brown w/ Red Stripe White w/ Black Stripe
N No Wire
Metal Braid Or Plastic Connector Attached To Back Of Radio Is The Ground Wire
Feb 22, 2010 | Kenwood KDC-MP242
Need wire color codes for pioneer model DEH-P3001B
If you're installing this the easy way to go is go to like walmart and buy a stereo wiring harness for your specific vehicle. This plug plugs directly into your factory plug and has the wires that connect to your pioneer unit attached to it. All you need to do is match color to color. tracing wires to splice directly into your factory wiring can be a royal pain, trust me i've done it and it ain't fun... but for what its worth here you go.
Red...Accessory
Yellow...power
Black...Ground
Blue w/ white stripe...remote turn on
Blue...power antenna
Gray...Right front+
Gray w/black stripe...right front-
White...Left front+
white w/black stripe...left front-
Purple...right rear+
Purple w/black stripe...right rear-
Green...left rear+
Green w/black stripe...left rear-
Aug 30, 2009 | Pioneer DEH-P2900MP CD Receiver...
Same dryer but I need to switch to a 4 prong cord.Please help!
WARNING! I believe you want to replace a 110V-120V plug with a 220V. Don't do it until you know for sure. Sounds dangerous! Not an expert, just some free advice from a novice.
Aug 17, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Audio wiring problem
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: White/Red
Radio Ground Wire: Black
Radio Illumination Wire: n/a
Radio Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Rear Glass
Front Speakers Size and Location: 6 1/2′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size and Location: 6′ x 9′ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Apr 05, 2009 | 1998 Honda Accord
Wiring 4 wird dryer plug to 3 wire 10/3 for 220 welder
the four wire plug seperates the neutral and ground. the three wire just piggybacks the ground to the neutral. so just get a three wire cord that fits the 220 plug on the generator and install it on your dryer make sure to attach the ground correctly for your three wire setup
May 07, 2008 | Dryers
Soun connections
did you turn off onboard audio in the bios
Jan 14, 2008 | Logitech X-540 Computer Speakers
Dryers Logo
79 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
