Question about Kenmore 63672 Convection/Microwave Oven
Microwave Panasonic NN-A554W
I put a packet of Microwavable popcorn in the microwave for 4 mins as suggested on the packet. When it was done I noted that there was a sorched mark on the unit as I opened the door and the door seal has melted in 2 places. Do I get the door replaced or is there a more serious problem luking somewhere? The unit still appears to work to all intents and purposes!!
    Scholar:
  • 136 Answers
This is usually caused by either exposed metal in the micro, or the metal in the bag of popcorn was overexposed. Typically if this happened, replacing the door components costs around 20-50 bucks. Which in, in any case, if the unit is over 2 years old or older, it would be more fesable to replace the unit.
Posted on Sep 17, 2007
SOURCE:
Where do I go to download manual for National Microwave NN-K577WF
Hello, Vishal -
I have not yet found a manual for a National microwave model NN-K577F online.
The National brand was a subsidiary brand of what is now known as Panasonic. National brand kitchen appliances stopped being manufactured in 2008.
Source of information:
https://en.wikipedia.org/wiki/National_(brand)
The Panasonic company may hold a copy of the user manual for the NN-K577WF model in its archives, however.
Panasonic is headquartered in Japan. However, unless you reside in Japan, I suggest you contact the Panasonic division located where you reside:
https://www.panasonic.com/global/support/get_support.html
On the home page for the Panasonic division in your country, there should be a Contact Us link or a Live Chat link. Ask if the company Archives holds a copy of the manual for the National microwave oven NN-577WF or the Panasonic microwave oven NN-577WF and if you can obtain a copy. Note: There may be a charge for a copy.
Best wishes.
Jun 02, 2018 | Microwave Ovens
Trouble code H98
H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
R
Oct 03, 2014 | Panasonic NN-H765BF 1250 Watt Microwave...
My plate just cracked while microwaving popcorn
Make sure you don't put any dishes in the microwave with something like popcorn because they retain more heat and have nothing to transfer the heat too. If you mean the built in spinning plate that you set stuff on and you have an older model the fan might be broken. Something similar happened to my microwave as it is pretty old i just removed the panels and cleaned everything/blew it off with an air hose and it started working again. I'd check with the manufacturers also!
Sep 25, 2012 | Panasonic NN-T694SF Microwave Oven
Replace a fuse for a Panasonic NN A554W
To replace a fuse, unplug microwave, remove top,"several screws" look to the right where the keypad control board is, now look down where the circuit board is, there should be a fuse clipped in, pop it out and replace with the same current rating, assemble before testing, lethal voltages.
Apr 07, 2012 | Kenmore 63672 Convection/Microwave Oven
OVERHEATING - Magic Chef Microwave M# MCO160S
Generic questions and comments:
Does your microwave have a "popcorn" setting and are you using it? Is there a rotating table in your machine? Is your popcorn bag elevated on top of a bowl or similar? Are you using some other "sensor" setting? Can you use straight time setting and get it to go past the 1 min 45 second mark?
On my microwave, it takes just about that much time and the popcorn is done ... BUT only if I elevate the bag to about the middle of the oven.
Let me know if this works for you.
a
Sep 21, 2009 | Microwave Ovens
Panasonic nn-s558ba microwave won't power on
Lee,
Have Landlord replace unit after verifying that outlet has power.
In the future, follow manufacturer's cleaning instructions and DO NOT
run microwave without something in it (even a microwave safe cup of water).
Larry Hanson EH&S Specialist
Apr 04, 2009 | Panasonic NN-S558BA/WA Microwave Oven
I desparatly need instruction for the NN-A554W inverter slimline combi PLEASE can you help
Apparently that's a UK model.
You can visit Panasonic.net, select your country, then follow the support links to find the manual download area.
If yours in not there, look for spares or service centers to order one.
Mar 05, 2009 | Panasonic NN-A811A Convection/Microwave...
Oven turns off
You are running the risk of damaging the Magnatron by doing this.
Check the packets you are using, you will have to reduce your power output.
This is because microwaves act by being absorbed by water. There is very little in popcorn and in fat. Once this has been evaporated, the microwave energy builds up (as it is still being produced - but not absorbed), and ends up cooking the magnatron itself.
I have seen countless posts on here after cooking popcorn!
More fun on the hob anyway - and cheaper to buy in bulk!
Jun 21, 2008 | Magic Chef MCD1311ST Microwave Oven
Kenmore 63672 Convection/Microwave Oven Logo
225 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
