Question about Brother P-Touch 1180 Label Printer
Ptouch 1100QL waste of tape issue
Every time I print a label, it waste about an inch before the actual letter comes out. Is there a setting that can be adjusted to get rid of this waste of tape?
TIA
It isn't actually "before the actual letter comes out," as you said, but rather after. You have probably noticed that you must do a "feed" first or the cut won't clear the end of the label and you have to do it again. This just reflects the distance between the print head and the cutting bar.
There's no way to avoid this if you must have the one label you just printed right away and you don't have any more labels to make at the moment.
However, if you have several labels to make, you can economize by printing them one right after the other (without any "feeds" or cuts), then once you're all done, do a "feed" and cut. The labels will be close together, with little waste except at the ends, and you can cut them apart with a scissors.
Posted on May 26, 2009
If you have extra space on both side you are probably set to 'mm' = middle. If you power off and then hold shift-R-power and let go you will see "English" pop up. Press 'OK" if this is the language you want.
You will then see either "inch" or "mm" appear. This is the stickler; you eithr can chose 'mm' which puts space on either side of the label or 'inch' which has a leading inch of tape. Either way you have waste (by greedy design). As they say, printing labels together and adding a space for cutting will help avoid the waste. Hope this helps.
Posted on Feb 08, 2013
PT 1280 suddently printing miniscule letters. Can't reset, have turned off using Shift/clear buttons, but doesn't change after settings redone.
What size tape are you using? If you have switched from half-inch to quarter-inch tape, then chances are that the printer is working correctly as the general size of the print is determined by the size of the tape. Beyond that, you can use the Text button at the top-center of the keyboard to enter the options for customizing the print such as the font used, the size (small, medium, or large), the width of the letters, and the style (such as bold, outlined, or shaded).
Jun 05, 2015 | Brother P-touch PT-1280 Label Printer
"no tape" error
I found 2 helpful manuals from brother that you may want to checkout. they explain exactly how to install the cartridge:
http://www.ptouchdirect.com/ptouch/manual/PT1000.pdf
http://www.ptouchdirect.com/ptouch/manual/PT85.pdf
Feb 18, 2013 | Brother P-Touch PT-2400 Label Tape OEM...
My ptouch isn't printing; after creating a label, when i press print, the tape comes out but nothing is on it.
Try a different tape. Usually, when the ink and label get screwed up it's time to trash it and start over, but you might just inspect the cartridge to make sure they are joining properly. If another tape works, there's your answer. If not, well 1180's aren't very expensive and our Brother store (Staples) has a sale on them every other week. Another heads up. If you have a Meijer's store nearby, they are stupid. They're selling black on white 12mm TZ tapes for $9.99. Go and buy them all :-)
Carl
Apr 21, 2011 | Brother P-Touch 1180 Label Printer
When I print a label, there is a blank white space before and after the printed text. How do I reduce the amount of tape printed before and after the text so as to maximize the label tape available?
you can, change the margins to narrow. you'll decrease the right margin but not the left margin which accdg to my research, is the space needed for the ptouch to print.
May 31, 2010 | Brother P-Touch 1180 Label Printer
Labels coming out blank
1. Replace the batteries (use only alcalines)
2. See if the tape is correctly inserted.
3. Clean the printer head
4. Replace the tape with a new one.
5. Check the contrast settings
Jul 20, 2009 | Dymo LetraTAG Thermal Label Printer
S4M automatically feeds extra labels everytime it's turned on
Set your print driver to "Do Nothing" on Head Close and Power Up. the next time you print will pass this information to the printer and the problem will not come back - actually the default for the driver is "Do Nothing" so it has probably been changed for some reason, you will need to change it back.
Apr 12, 2009 | Zebra Z4M Printer
Printed Tape Cuts Off Letters
I was having the ame issue. Found the solution on the user manual (posted online). Press Function, scroll to "Margin", press "Function", use arrows to select "#" or "##", then press Function again. Now it should print with a margin, thus not cutting off your letters. Mine was set to "-", which is basically no margin.
Dec 29, 2008 | Brother P-Touch 1180 Label Printer
Too much tape...
I was able to fix my problem. Please erase my email from your list.
thanks
Nov 18, 2008 | Dymo LetraTag QX50 Thermal Label Printer
Label Maker HELP!! Brother ptouch 1180
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Computers & Internet
Brother P-Touch 1180 Label Printer Logo
5,535 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
