Code to program a sony trinitron tv KD-27fs170
I need the codes to program my home theater system to a sony trinitron color tv,I will aprecite your help,
SOURCE: Setting up a Yamaha RX-V690 home theater system
you almost have the exact same situation i am in. i have the same receiver, and going to purchase a panasonic 50" (th50px75u). i think what i will be doing is running a hdmi from my hd cable box to my tv, and installing an audio cable (red/white) from my tv to the receiver. i believe there is an audio input below the hdmi insert. i have polk audio, but theyare about 10 years old, they sound great, but just too large....and may be purchasing a harman kardon system. which models do you have from polk? i have the rt16's, cs350ls center, and fx/500 rears. let me know what you have come up with as well...as it has been a while since you posted this.
cheers,
sean
Posted on Jan 22, 2008
SOURCE: Direct TV remote codes for SX-315
hello i have a pioneer sx-315 it plays great but the sub performs badly.they sound is very low.they really need to perform better.if anybody know any sub that work better please let me know.
Posted on Nov 23, 2008
SOURCE: need codes for universal electronics remote that will oporate tx-sr606receiver
I have the same problem and from what I've read elsewhere there is not a cheap and easy solution. From what I gather, simple remotes (like what you get w/ your set top box) that use manufacturer's codes for programming treat "on" and "off" as a simple toggle. That means they fire out a singal signal which is supposed to simply change the state of the device from off to on or vice versa. The Onkyo apparently uses different signals for on and off. Because of this we will need to get a "learning remote" which can be programmed to provide a separate signal for any desired function. These tend to be much more expensive which is why they don't just give them out with your set top box. Right now I'm still fiddling with separate remotes until I break down and drop the bucks for the special remote.
Posted on Jun 03, 2009
ABKSeeker
  • 69 Answers
SOURCE: Remote control programming codes needed.
this is the link for onkyo receivers you are missing 1 # on your model #
http://www.onkyousa.com/download/own_manuals.cfm?cat=Receiver
Posted on Feb 14, 2010
SOURCE: Need Universal Remote Code for Panasonic DVD Home Theater Sound System
panasonic home theatre-can't select tv/video area after hooking up to new Vizio TV. DVD lights keep flashing. Can only select am/fm.
Posted on Feb 28, 2010
Has audio, but why no video?
Please describe how you TV is setup and connected to devices.
Check to make sure you have the correct input selected.
Also, check to make sure you have correctly connected the video cables and that you don't have bad video cables.
Another thing to try is unplug the TV for 30 seconds.
Prepare to observe the Standby LED on the lower front of the TV.
Plug the TV back in and see if the Standby LED blinks, counting the number of blinks. These blinks are the self-diagnostic codes.
Post your findings here.
Mar 31, 2016 | Sony FD Trinitron WEGA KD-27FS170 TV
What is the code for a 2001 Sony Trinitron?
Search Results
    Sony eSupport - Remote Control Codes & Programming ...
    https://esupport.sony.com/.../select-system.pl?...RCOD...
    Sony CorporationFind the codes you need to program your remote control. ... Television - Accessories; Television - FD Trinitron® & WEGA™; Television - Internet TV & Players ...
    [PDF]Trinitron Color TV - Manuals, Specs & Warranty - Sony
    https://docs.sony.com/release/KV20FV12.PDF Sony CorporationRefer to section 54-300 of Canadian Electrical Code for Antenna Grounding. Lightning .... Congratulations on your purchase of the Sony Trinitron Color TV.
Dec 08, 2015 | Sony Televison & Video
Our Trinitron KD-27FS170 Tv will not turn on. It sounds like it is turning on/off but no picture or sound. The Stand-by/Timer red light is flashing 4 times, pause, then 4 times, etc.
This typically means you have a bad capacitor, you can inspect for any swollen or bulging capacitors however unless familiar with desoldering boards best leave it to a repair technician.
Jan 13, 2015 | Sony FD Trinitron WEGA KD-27FS170 TV
Do I need a converter box for a Sony KD-27FS170?
When a TV hasn't digital tuner, it's necessary to add it a digital to analog channels converter box, but your TV already has digital tuner, you can switch between digital and analog tuning by pressing the digital/analog botton on the remote control.
Feb 24, 2011 | Sony FD Trinitron WEGA KD-27FS170 TV
I have a sony triniton color tv medel 3 KV-DR34M89. How do i connecft and play a DVD on it.. i treid connect the yellow,red and white cables on all the slots but no success. please advise
Connect cables:
Connect yellow to yellow (dvd player to TV)
Connect white to white (dvd player to TV)
Power on DVD and TV and insert a DVD into the player, press PLAY.
Use your TV remote to select the proper input:
Your remote should have a button like INPUT SELECT or Video, keep pressing until you see the DVD players output.
Feb 20, 2011 | Sony FD Trinitron WEGA KD-27FS170 TV
Program code for sony home theater DAV-DX250
my home theater model dav dz270 but my remoteis missing please help me what is the remote number
Mar 27, 2010 | Sony DAV-DX250 System
Side by side picture analog
Try to re oreint your antenna posistion.it was a gohst signal..find a place were there is a good signal of TV reception
Apr 25, 2008 | Sony FD Trinitron WEGA KD-27FS170 TV
TV controls do not work
replace system IC then check Sytem area.
Oct 10, 2007 | Sony FD Trinitron WEGA KD-27FS170 TV
Unable to channel to channel 3
If you take a working remote, point it at the TV and hit "3", then "ENTER", does the set go to channel 3?
Sep 04, 2007 | Sony FD Trinitron WEGA KD-27FS170 TV
251 people viewed this question
 Grubhead
Grubhead
