Question about Marantz DR-4050 2-Disc CD Recorder
Will not power up
I checked the cord and it's good but when I push the on/off button nothing happens.
Just got mine out of the shop, which they could not fix, but they did say that the power supply was out and needed to be replaced. I am now looking for a power supply for my DR4050.
Posted on Oct 30, 2009
How to turn on
-Make sure power cord is plug very good into the printer.
-Make sure Plug to outlet and make sure there is power there.
Try again.
Good luck
Mai
Dec 05, 2017 | HP Computers & Internet
Why does nothing happen when power button pushed?
The Dyson cords are known to go bad, test the cord and see if there is voltage. If this is too mechanical for you, please take the vacuum to your nearest vacuum repair shop
Mar 21, 2016 | Dyson DC44 Animal Handheld Vacuum Cleaner
Troybuilt snowblow electric starter won't start or turn over. Nothing happens. What could be wrong
if it does nothing, check to be sure you have 120v power out of cord
push starter button do you hear a click/ if not micro swtch is bad
if you do than starter motor is bad
Jan 28, 2014 | Troy-Bilt Storm 2840 277cc 28-in Two-Stage...
Push on button, nothing happens. What to check?
There are two solutions to this problem: 1) you need a new charger or a charger that both either was recommended and reaches the volt age. 2) you need a new battery for your laptop.
Dec 02, 2011 | Twinhead Durabook N15RI-2 Notebook PC
The dishwasher won't start, its stuck, pots/pan button is blinking, & the timer has (2)_ _ bars blinking. I tried to reset/pushed the start/resume button nothing happened. I pushed the cancel/drain...
did you hold the start/resume button for at least 3 seconds if this works the dishwasher will start ok but if there is a fault it will fail again best you contact your nearest service agent good luck
Apr 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Nothing happens when push start button. power cord etc good ??? is this a power unit failure?
make sure the outlet is recieving power
unplug the tower from the outlet & then replug it in & see what happens
make sure all cords are plugged in correctly in the back of the tower
then if nothing happens after you push the start button, power supply & cord could be bad
the same thing happened to my daughter's pc & had to replace power supply & shorted out the motherboard
Nov 18, 2010 | HP Compaq Presario SR2050NX PC Desktop
Emachine D2880 worked fine yesterday will not power on today
when you push the power button, fan or blower on power supply spinning or not? of not. your problem is power supply, nut if yes... did you hear any beeping sounds?
Jun 19, 2010 | E-Machines eMachines Desktop PC
Nothing happens when you push the power button
i could be static build up . this is common. Try taking the battery out and unplug the power adapter. now with both removed press the power button on the laptop for approx 20 secs. then plug it in and see if it boots up.
Dec 02, 2009 | Compaq Presario 700 470024-192 Notebook
There is no power lights even when plugged in i push the power button and nothing happenes but there is power at thew end of the power cord it was working then nothing can enyone help mt
DID YOU CHECK THE CHARGER? CHECK FIRST USE TESTER TO CHECK IT.. THEN IF THE SAME PROBLEM CHECK THE POWER BUTTON IF NOT THE DC CONNECTOR YOU NEED TO OPEN THE UNIT IF UNDER WARRANTY BRING TO THE WARRANTY DONT OPEN IT....
Sep 12, 2009 | Toshiba Satellite Pro L300-EZ1005V...
Marantz DR-4050 2-Disc CD Recorder Logo
119 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
