Maytag washer SAV2655AWW pulley wheel replacement
A black pulley (seems to be p/n 40045001) came off. I think I can get the part in the morning...
??? what else might need to be replaced? How do I replace it?
THANKS! Vandy
  • 686 Answers
I POSTED YOU ALREADY DISREGARD THAT POST AND FOR THIS PULLEY I WOULD SAY REMOVE THE FRONT ACCESS COVER WHICH I PRESUNE YOU HAVE, TO SEE WHAT IT WAS. THIS PULLEY LOOKS LIKE IT JUST SITS ON A LEVER WHERE THE BELT ROUTE IS AND I SUGGEST YOU ALSO CHANGE THE IDLER PULLET LEVER SPRING AND THE BELT WHILE YOU ARE CHANGING THESE OUT.
Posted on Apr 18, 2009
  • James Chandler Apr 18, 2009
How to replace a crankshaft pulley on 2002 Buick rendezvous
a slight wable is common on many of these. I would be more concerned with the belt tensioner and belt. But the crank pully can be done in your driveway. You will need to go to parts store and rent the pulley removal tool that is specific to this engine.
Nov 12, 2013 | Cars & Trucks
03 eclipse making noises in cold weather
First you need to find the source that is causing noise. On cold weather is very normal engine belts or belts idle pulley bearings or belt tension-er to make noise, especially when they are old. Also power steering pump too especially if the oil is very old.
Feb 03, 2013 | 2003 Mitsubishi Eclipse
I have a 1994 Toyota camry xle 6cyl.,I started the car this morning and heard a whirring noise under the hood. Opened up the hood & the noise was coming from where the pulleys are .And had not heard...
Was the timing belt replaced recently? If your crank pulley/harmonic balancer is wobbling, it is probably loose. Do not run the engine, if this part falls out, it will cause more damage.
Sep 07, 2011 | Toyota Camry Cars & Trucks
I have a Troy Bilt Bronco (2006) - model 13AO77TG766 which needs a new transmission drive belt. So I bought the right one at Lowes. I can access the largest pulley somewhat by taking out the battery and...
a 1/2 inch impact is the solution. with enough air pressure you should be able to loosen the nut no problem while holding on to the pulley with your other hand. it is a standard thread so ccwise to loosen. you should be able to get the top belt on the variable speed pulley. usually have to loosen the variable speed pulley assembly when replacing lower drive belt. i hope this helps you out
Aug 15, 2011 | Garden
My 2000 montana has a belt problem it keeps coming off track and getting ate up. Replaced the tensioner already. There seems to be a wobble at the pulley area. Do you think both harmonic balancer and crank...
Check all of the accessories that run off the belt. some may have loose or bent pulleys or the acessory itself may have come loose. Be careful to route the belt exactly as shown too. Tighten up or replace your wobbly pulleys.
Aug 17, 2010 | 2000 Pontiac Montana
My clothes don't always spin out. have to put through spin cycle several times. It doesnt happen all the time. Im figuring its the V belt what do you think
Yes the vbelt (part# 27001007 )could be worn, as could the idler roller (#40045001 ) , and arm (#27001028).
However if you find traces of oil as in motor oil your gearbox/transmission is leaking and you may as well start searching for a new unit as the transmission is around $230 and not a quick/easy chore to change..
best of luck, have fun,
ttfn
Feb 02, 2010 | Amana NAV2330AW Top Load Washer
Trying to put belt back on magtag sav2655aww. do
Maybe this breakdown250 will help, not sure, hope so.
Nov 11, 2009 | Maytag SAV5710 Top Load Washer
Open Questions:
Washing Machines Logo
366 people viewed this question
Top Washing Machines Experts
