Question about JVC THC4 Home Theater System with 5-Disc DVD Changer System
JVC XV-THC4 Home Theater System
I need to replace to cords: the power cord that goes from the THC4 unit to the power outlet; and the cord that connects that unit to the subwoofer. Do you know where I can find these two cords? (They were lost in a move.)
It a 8pin din cable ,,,,I picked up one from a specialty cpu shop in Norcross,Ga
but search ""8pin din cable"" see what you find!!!!
the power cord is extremely common ,you can find that one anywhere ,,,,,most any dvd player ,playstation etc etc etc uses that cord
Posted on Oct 23, 2007
My mackie swa 1501 when you plug in no power checked the outlet their is power checked power cord good. what can i do
There are many possibilities, the switch, motherboard, electronics etc. If you are a DIY kind of person and you want to try trouble shooting yourself, you need tools. Better still, take it to a service person/ outlet to proper checks.
Oct 06, 2014 | Mackie SWA1501 Subwoofer
Unit does not power up
try replacing the power cable. and you might want to make sure it didn't short circuit when it sparked.
Jun 30, 2008 | Audio Players & Recorders
R5002 resistor value for JVC XV-THD60 Home Theater
Why don't you read the color code? Assuming it's got bands of color painted on it.
Nov 12, 2013 | JVC THD-60 System
Agent in sri lanka
There is one or two fuses inside the unit. Open the unit very carefully, look for the fuses; they are usually located near where the power cord enters the unit. Get the same fuses. If this keeps happening, then it needs to be serviced.
Oct 05, 2013 | JVC Audio Players & Recorders
Replacing electrical cord
if you buy a color coded cord and plug then red and black go on thee 2 outer terminals of the power terminal and the white wire goes between these as this is the neutral connection and if it has a green ground wire connect this anywhere to the metal case of the unit, if its a gray cord with no colors then the 2 outer wire on the cord go to the outer terminals on the units power terminal block and the center wire on this cord goes to the center terminal on the unit
Jul 28, 2012 | Roper REX4634KQ Electric Dryer
I am looking for the connector cord that goes from my sub woofer to the system itself its the XV-THC4 Cord. can you help me find one.
The part you are looking for is a DIN/System cable.
you can order one from jvc directly
or search DIN/System cable in google, theres a few cheaper ones.
Feb 01, 2011 | JVC THC4 Home Theater System with 5-Disc...
Im trying the locate the power outlet on a 20" zenith flatscreen? Can't find a 3 prog outlet where it needs to go? Wondering if the power cord is not the power cord that goes to the flatscreen
I believe this needs a power adapter and the cord that should be going in to the flat screen is a small round connection/plug. ( Like a laptop power connector ).
Hope this helps!
Jan 21, 2011 | Computers & Internet
Our belling double elec oven has just stopped working, no power at all and the fuse has not tripped? any help out there?
Are you sure there is power on the outlet? If yes then probably the power cord is at fault. You should have a handy tester at hand to go further. You could buy a cheap one at any hardware or electronic shop. Now for the power cord. First remove the back cover of your unit. Then set your multimeter to voltmeter range... at the highest range. Plug your oven to the power outlet. Trace the line of the power cord inside the oven. Look for the connections and markings for Line1 and Line2. Now point your test prod to these connections. You should read a voltage similar to your power outlet. If not then replace the power cord. If its OK then remove the power cord to the power outlet. Set the multimeter to the Ohmmeter range. Check the coil if it is OK. You should read a reading of less than a hundred ohms or more. Be sure to remove any connections to the coil before doing this test. If everything goes well according to the test procedure then the culprit must be the power switch or the connection going to it or to the coil.
Jan 03, 2011 | Ovens
1,010 people viewed this question
Top JVC Audio Players & Recorders Experts
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
