Question about Kenmore Dryers
Have a kenmore dryer model 110.96586400 it has a brand new heating element and will not blow hot air. what else could it be and were can i get a manual for this unit?
Do you have 220 volts to receptical? if so check the thermal fuses in the back going to the element. the tub will turn on 110 volts maybe the breaker is only letting 110 volts to the dryer. i have seen it happen before.
Posted on Apr 18, 2009
catriver
  • 878 Answers
SOURCE: replacing the heating element Kenmore dryer 110 64892
nestor, on the posted model, you want to drop the lower front panel. Take a puddy knife and push in on the clips on each side and it will pull off. Kill the power to the dryer. On the right you will see the heater housing. The housing will have a front deflector. You can remove that deflector by removing the screw on the bottom or simply just bend it down out of the way. Remove the 2 wires on the left that attach to the element itself. On the left side of the housing there will be a quarter inch screw that holds the element in place. Use a small socket set to get it off. Now the element will pull right out of the housing. Sometimes they are difficult to pull out but it will come out. Did you ohm out that element to make sure that was the culprit? Catriver.
Posted on Dec 09, 2007
SOURCE: Kenmore Dryer Model 110
I found the solution to be very informative and helpful. However, I checked the resistance of the heater element and it is about 10 ohms, and is not open. The TCO resistance is about zero. What about the thermostat? No values were given to check it for, but I did check it's resistance and it was also close to zero. The thermostat sort or "rattles" when I shake it; is that normal?
I pulled the heater element out and looked at it, and can see no visible damage. Also checked the air outlet and hose - no blockage in the hose and the air output at the dryer seems fine.
What else could be causing the dryer to not heat. Have checked at all cycles and temperature settings (low, medium and high)?
Posted on Sep 16, 2008
SOURCE: kenmore 80 series runs but dont blow hot air
I had the same problem. The heating element is most likely broken. It is an easy fix and costs about $75-$100
Posted on Dec 12, 2008
  • 659 Answers
SOURCE: whirlpool dryer not blowing hot air
The element is at the bottom of the unit. Usually they are located on the right bottom but when you take the housing off, you will be able to see it.
Posted on Apr 11, 2009
SOURCE: Dryer blowing cold air only
older homes with fuses can have to fuses on the dryer circut-1 could blow and the dryer would run without heat
Posted on Jun 20, 2009
How do I replace the heating element in a 11063032101 dryer?
KENMORE Electric Dryer Parts Model 11063032101
Link shows the parts explosion. You can click on various diagrams and find your part.
Sep 13, 2014 | Kenmore Dryers
My dryer is not blowing hot air the brand is kenmore model # m-460-g
Check the element and fuses for continuety
Replace as needed.
Jun 06, 2010 | Kenmore 62602 Electric Dryer
New heating element not working
You should check to see if the "high limit switch is burned out. Some models/Brands have 2. It should be on the outside casing of the heating element.
Apr 30, 2010 | Estate EED4100SQ Electric Dryer
No longer blows hot air, only cold air
when a dryer does'ny blow hot air,it's normally either the element or the stats on the element.
Nov 01, 2009 | Dryers
Dryer working but not blowing hot air
Either bad thermal cutoff or bad element .( first 3 numbers missing on model #)
Jul 05, 2009 | Kenmore 800 6983 Electric Dryer
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Dryer not hot
Tht means that the element is not heating on.
You need to call a technician to test the element, the thermic sensor, and the control assembly.
The most likely is a defective heating element, that must be replaced.
Jan 31, 2009 | Kenmore 73952 Gas Dryer
Does not heat, air blows, drum tumbles.
then DIY we do not read minds as to MAKE
Sep 28, 2017 | Dryers
Kenmore 80 series runs but dont blow hot air
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
Kenmore dryer replaced heting element now it does not blow any air
HI danon this dryer its common to have the blower wear out, it slides on the motor shaft, and what they do is wear out the flat in the blower. that could have caused the element to fail. check the blower thanks the appliance doc. please rate my answer. thanks
Sep 30, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
146 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
