Question about Microsoft Xbox Console
My xbox appeared black & white in my tv monitor
How can i fix this problem i connect my xbox in my color tv monitor with exactly 3 jacks connected each color but its appeared black & white?
  • 3 Answers
There might be a problem with the jack inserts on the T.V. have you tried wiggling the jacks while there plugging in to the T.V. and also make sure the same cord is securely connected in the back of the console.
Posted on Apr 18, 2009
My dynex tv only shows channel not available message?
Okay- the three cables (red, white, and yellow) are called RCA plug connectors. They are commonly used to carry audio and video signals.
Plug them into your Xbox according to the color codes- red cable connector to the red socket (jacks); then white to white, and yellow to yellow.
Now connect these leads to the RCA input jacks in the back of your t.v. - maintaining the same color code connections (red to red; white to white, and yellow to yellow)
The RCA input jacks on your t.v. should be labeled with an input number, to distinguish itself from the other inputs, like HDMI, S-Video, and such.
After plugging in your Xbox to the wall outlet or surge strip, turn it on.
Turn your t.v. set on.
With the remote control that came with your t.v. set, open the menu bar, scroll to... and open the "External Output" menu.
You should see a list of [however many] inputs your particular t.v has. Scroll to the input number that the 3 RCA cables are attached to, and press that number as the default video screen.
Exit the prompts and your Xbox video screen should be displayed.
Nov 27, 2013 | Dynex DX-LCD32-09 LCD TV
ELMO Visual Presenter (Model EV-2000AF) does NOT display COLOR properly onto HDTV monitor. (Appears Bluish or Reddish w/ 2 Composite Cables connected)
Those jacks you are plugging into on the HDTV are not composite inputs. They are component. The reason the color is not right is, you have to have a Red, Green and Blue connection.
The black and white picture from the 1 cable is because you are using a composite signal into a component green.
Big difference between a composite and a component signal. I hope this helps.
Apr 10, 2012 | Televison & Video
My xbox360 works on my flat screen in color but on my other tv its only black and white... how to fix this?
Do you have it hooked directly to the tv or going through a vcr or other device. Try connecting it directly to the tv. It sounds like the problem is not with the xbox being that it is in color on some tv's, also try a different input on the tv that is black and white.
Thank you,
Lee
Jan 03, 2011 | Microsoft Xbox 360 Console
Input connections are not working properly. Some are black/white, some flash, some dont work. How do I fix it?
is your main antenna / cable (or cable box) connected to tv/monitor cable in...the monitor is on Ch 3...do you have dvd player or vcr...these devices must be set to cable / ch 3 also...and hook up to aux 1 or tv 2 depending on the jacks avail on the back of tv (please note if you are using a dvd recorder premium ch like HBO is and will be scramble)
Jun 14, 2010 | Polaroid 4011-TLXB LCD TV
Xbox and dish network problem
if you have like a dvd player then try hooking the xbox up to it in the front where the video is for the 3 plugs then try to plug dish network in the back of the dvd where the ant in plug is at then take the cord from the dvd player and plug it in the back of the tv if this dont work let me know
Aug 08, 2009 | Microsoft Xbox 360 Console
Pyramat 450 wireless sound rocker. Comes with white/yellow/red rca jacks, how would I install that to a xbox 360? The xbox will play through chair if I connect xbox input jacks to chair! But you then get...
You need to go buy another cable, get a good length red and white rca cable one that suits the distance between the chair and the xbox.
Then you need to get a female to female rca adapter. Connect the adapter to the ends of the red and white audio cables on xbox, connect your new rca cable to the adapters, connect the cable to your pyramat seat. Connect xbox tv cable to tv as normal.
Jul 11, 2009 | Pyramat PM450WR for PlayStation 2,...
My game appears in black and white instead of color.
Ironically enough,I have serviced a Philips that has that problem,and the sticker that portrays the component/composite inputs were wrong and the jack coloring was wrong as well. dont be afraid to try different combinations as for what jack goes where
May 28, 2009 | Philips 47 in. LCD HDTV
Black and White Only
I had a similar problem when I first connected my son's xbox using the Audio/Video cable (red, white, & yellow connectors). I connected the cable to the TV correctly, but incorrectly selected "component" as the input on the TV setup. Result was black and white display. Switch your TV input mode to "AV" or "Audio/Video" and you will get color.
FYI, "component" TV mode is only used with devices that use the red, green, & blue connectors.
Jan 30, 2008 | Microsoft Xbox Console
No color on Sony TV, all other tvs are great
check the av cables in back of your tv and also check the wires connected up to the xbox 60 it's self
Sep 01, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
134 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
