Question about Lexmark X1270 All-In-One InkJet Printer
Printer grabes paper at an angle every time i try to print a page,never has done this before, am using same kind of paper, just keep's going in sidways,thank's rr
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 77 Answers
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print the self test page.
Please follow the steps given below to perform the self-test:
1. Power the printer off.
2. Press and hold the "Paper Feed" button.
3. While still holding the "Paper Feed" button, press and release the "Power" button. Continue holding the "Paper Feed" button.
4. When the printer starts pulling paper, release the "Paper Feed" button. It should print a test page at this point.
5. Power the printer off, as this test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let me know.
If it still fails to feed the paper correctly, please reply with the following information:
What type and brand of paper were you using?
Have you ever used this type or brand of paper before and if so what were the results?
Once we have this information we will try to fix the unit through email support.
Posted on Apr 27, 2009
I spent lots of time last night trying to get my printer to work - it did a couple times and now it won't print out again - trying to print from the computer to the printer.
IF THE PRINTER has any ALARM LIGHT. check for paper jam or BAD paper pick up roller not grabing the paper (clean or replace it).
If the printer doesn't blink ALARM. check if you have failed jobs in QUE; IF YES DELETE IT AND TRY TO PRINT AGAIN OR TRY UNINSTALL AND REINSTALL THE PRINTER DRIVER.
Dec 11, 2014 | Kodak ESP3250 All in One Printer
Epson C86: paper not feeding and prints at an angle
try feeding the paper through manually if you cant do this then try printing a blank page and see if this still wrecks the paper if it does then it does sound like something is jammed on the roller the best way to clean this is with a blast of air from a compressor this is the only sollution as it will cost more to replace the parts than it would to buy another printer if it is still under warranty they should replace it for you if not you could take it to a computer repair shop where they will strip it down adn rebuild it for you this is a paper feed problem but im sure their must be somethig sticking in the way or maybe the paper feed has come lose at the one end sorry i couldnt help you any more ........................................
Oct 31, 2007 | Epson Stylus C86 InkJet Printer
How to fix the hp laser jet 3055? Is not printing... looks and sounds like is not grabing the paper sounds like the turning wheels are turning but not grabing paper..help
Try gently scrubbing the rollers with a lint free damp cloth.
Make sure that the paper is good(not warped).
Make sure that the paper is pushed back far enough to meet the roller.
Dec 21, 2010 | HP LaserJet 3055 All-In-One Printer
Printer keeps printing blank pages non stop going
drop kick unit across room:)))) sorry just kidding I had the same problem with mine. If the computer is continually printing that means the printer is receiving print orders from your computer. Best thing is just disconnect the printer from the computer and turn the computer off and wait 30 seconds then turn on . This should clear the print cache then reconnect the printer. Make sure to only request one print at at a time.
if the printer continues to print blank pages check to see if you have the latest software driver for the printer installed on your computer. You can do this by going to the manufactures website and download the software its easy to do just follow the prompts and install! Hope this helpful!!!
Jul 24, 2010 | Epson Stylus C84 InkJet Printer
LP2844 printer stops after one page with out of paper error
Did you try to reload the labels. Pull the labels out and clean the paper path
May 07, 2010 | Zebra LP 2844 Thermal Printer
Printer using to many pages at once
When printing in moist climate or conditions, be sure to fan your paper before loading printer. Also set your paper guide so that the paper does not pull in on an angle.
Mar 25, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Hp deskjet 5550 is grabing the paper but paper prints crooked
You may have a paper jam (small paper cut) in the feeder ytry to check it and see if you can clean it...or you may bent the feeder...open it and let me know
Sep 13, 2009 | Office Equipment & Supplies
Usually won't print from upper tray
These printer have a problem grabing the paper from the upper tray it might look like it was ready to print but they usally miss grabing the second sheet of paper from the upper tray.
Jun 27, 2009 | Brother HL 2140 Laser Printer
Feeder grabing the paper crooked causing jams and paper unable to go through the feeder smoothly. it stops once the feeder grabs the paper.
set the paper tray size to the size of the paper...if this is ok...clean the pick upo roller with damp cloth and soap water...if this doesnt help ...change the pick up roller..
keep me posted
May 04, 2009 | Computers & Internet
Brother HL 5150D not printing unless I keep pressing Go
its not the problem of toner cartridge.its the problem of gears which pulls the paper they r worn out or may be cracked internally.exactly what happens when you u give the print for the first time the printer gets command and the gears starts spinning and the paper gets pulled because it gets a pressure internally and after 2 pages that pressure gets low and it stops pulling the paper.some times changing the paper thickness solves the problem temporvarily .i mean use the thick quality paper instead of thin.
Jan 08, 2009 | Brother HL 5150D Laser Printer
Lexmark X1270 All-In-One InkJet Printer Logo
686 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
