How do i turn off the timer on the remote? - Heating & Cooling
  • 659 Answers
Locate your brand and model number online. Download a manual and refer to it. Most models have downloadable manuals.
Posted on Apr 18, 2009
I'm trying to cut off the timer on a sony t.v.RM-Y909 so I can turn my t.v. on with the remote control.
The RM-Y909 works for the KP46WT500, among other TVs. For the KP46WT500: to reset Timer 1 or Timer 2, you need to access the timer sub-menu. With the TV on, press Menu. Use the Joystick on the remote to select the Timer icon (looks like a clock) then press the center of the joystick (with the + with a circle at the center symbol). Use the joystick to select the timer you want to reset and then press Reset (on the left side at the bottom of the remote). Alternatively, you can just turn off the timer. The TV will remember the settings. Press Menu to exit the menus.
Sony has the manual on their product support page in the manuals tab: https://esupport.sony.com/US/p/model-home.pl?mdl=KP46WT500 . The direct link is https://docs.sony.com/release/KP46WT500.PDF . The Timer menu section is on page 57. I hope this helps.
Aug 31, 2015 | Sony Televison & Video
Set vcr to record after timer is set
You need to turn off the Timer and then add your new program to the schedule. Then turn the Timer back on (power off).
On most VCRs, the Timer is enabled by turning off the unit. Thus turning it on will work (as long as a program isn't currently being recorded). If a program is currently being recorded, press Stop to interrupt the programmed recording. Then add your new program - that doesn't conflict with other programmed recording or exceed the number of available timed recordings for the unit. Then turn off the unit.
At least one VCR I owned was a bit trickier. You had to press the Timer button on the remote instead of the power button.
I hope this helps.
May 16, 2013 | Emerson New Original VCR4010A Remote...
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
My remote only works on 1 and 2. # 3 does not work . How do I fix this?
You posted under Woods timers.
Woods makes a few different timers with remote.
One of them has 3 buttons
http://waterheatertimer.org/Woods-timers-and-manuals.html#13568
You can try unplugging all 3 remote units so they reset, and then try setting up on button #3 first.
You can also work around using this method: unplug all remote units. Plug in two remote units and turn both lamps ON. Then use button #1 to connect to both of those remote units simultaneously. This way, two different lamps can be controlled by one button.
If remote control is genuinely defective, then send it back for replacement.
Industry-standard is one-year limited warranty.
I own 2 sets of this timer.
One of the remote units stopped working immediately and has never worked since.
Both the remote controls work, but only 5 of the 6 remote units work.
I test timers and 6-8% arrive defective. Most go bad after a few years, some last quite a while.
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 24, 2011 | Woods Hardware & Accessories
CAN ANYONE HELP i'm having a problem keeping the timer from going off and shutting the whole tv off. My kp-46wt510 sony widescreen from 2003 is doing the same thing, picture is bowed in the middle and...
Most likely you have turned on the sleep function. 2nd button from the left on the top of the remote hand unit. Keep pressing until "sleep off" appears on-screen.
Or
Timer in user's menu is activated to turn off TV a specific time. Go to timer menu and adjust timer, then push cancel on the remote, this should reset timer to zero. Same with current time, adjust and select cancel, this should reset current time.
If you do not have the original remote, you are in trouble. Service tech will have remote.
easyab
Feb 23, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Howto disable 24 hr timer in avital 4400
Remote start the vehicle; turn ignition on with the key. The parking lights will flash 4 times indicating that the timer mode has been exited.
Please note how the timer was activated by pressing the lock and unlock buttons.
When in the timer mode, the remote starter can time out or, you can shut down the remote starter with the remote and the timer mode will remain active. But, if the remote start sequence is terminated by any of the shutdowns ( ignition, brake, hood or neutral safety switch) while the remote starter is running, the timer mode will be terminated.
Feb 03, 2011 | AviStart 4400 2-Way Security / Remote...
I have 2 units of 2 hp mitsubishi split type air-con. both units are having problem with timers. the timer will blink after 20 to 45 minutes of operation and then it will turn off by itself but the light...
the timer may have been activated at installation or by someone not fully conversant with the operation
use the remote and follow the instructions in the owners manual to turn the timer off
Sep 06, 2017 | Mitsubishi MSZ12UN Air Conditioner
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
