Question about Apple Mac mini G4 Desktop
Cd burn error apple mac mini
I picked up a mac mini g4 with superdrive. I have another mini with cd drive. The superdrive mini can't burn a cd. I get an error message "laser cannot calibrate". I have used a cd drive cleaner cd (small brushes clean laser surface). I have blown air into the slot. I have re-installed OS 10.4 The blank CD is a Maxell. I have burned the same CD that was rejected by the superdrive mini on the other mini. The drives are called "matshita".
    Problem Solver:
  • 15 Answers
Did you use the same Maxell blank CD's in the other mini?
If so, it sounds like your drive may be failing/failed. Try another brand of CD in the superdrive just in case. I have found that drives that are beginning to fail will have problems with some brands but not others. Sometimes they'll go totally dead a while after that point, others will still be ok with another brand that they "like" more.
Posted on Aug 08, 2009
Operating instructions for apple superdrive
If this is an external Apple superdrive, then it won't work with any Apple laptops with an internal drive as the firmware detects the internal drive and will not run the external Apple device
Aug 05, 2016 | Apple Powerbook G4 17" 1.67 GHz SuperDrive...
CAN I SWAP A POWERBOOK "SUPERDRIVE" INTO MY PPC MAC MINI?
yea it can you must do it your self tho apple will not do any modification
Dec 26, 2012 | Apple Powerbook G4 A1013 17" Genuine...
Card jammed in CD player of PowerBook
I would tilt the computer to the side and then hit the eject button and hopefully the eject action and gravity will do the job.
Feb 14, 2012 | Apple Powerbook G4 15" 1.5GHz SuperDrive...
Mac mini superdrive ejects discs
Hi
I think the answer is in your question. Pioneer DVD-RW drive, DVD+R disc.
For some reason known only to Apple, some drives do not work with all discs. Mine will not burn -R dual Layer discs.
Nov 23, 2009 | Apple Mac mini 2.0GHz
I am trying to transfer a file to an external hard drive from a Mac Powerbook G4. I get an error code 8065 and I am unable to copy the file.
8065 refers to a cross-platform error (like between a p/c system and a mac system).
You could try copying your file to a cd and burn the cd to be compatible with pc or mac and then transfer to the other system.
Oct 16, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Burned a CD and it will not eject. The CD is in my 17" PowerBook G4, but does not populate on my desktop. It's as if the computer does not recognize the CD at all.
If you restart your Mac, holding down the mouse button while it is starting, will eject any cd or dvd. Once the disc ejects just release the mouse button and the computer continues it's startup procedure.
Jul 14, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I without research Installed Windows XP on my Apple MacBook 13" White, 2.0 GHz, Intel Core2 Duo with 2Gb of RAM and 80GB HDD. It is the only NTFS partion, i.e clean install on the whole volume. Waz I...
If you did a clean install on the whole volume, you wiped your Tiger installation. The best bet is to install your preffered operating system first. When you do it, partition the drive into two of about equal size. Install the other OS into the other patition and have a menu to start the wanted OS when you turn on the computer. You will have to do some research on dual boot computers.
Jul 09, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
PowerBook Aluminum G4 1.67GHZ
Kim,  I'm glad you asked this.  I have had problems with my superdrive as well.  What I found out through persistent research is this:     The new Superdrives can take CD+R and DVD+R.  (I am assuming you are asking about recording?   However, the older models of Superdrives ---usually found in Powerbook G4s, can take CD-R and DVD-R.  These are different from the first ones ini that they are slower to burn, and just a few gb short of space than the +.  this should help solve the problem with taking new cds and dvds for burning.  The superdrive tends to just spit these right back out.  If you are referring to playing them, then have you tried cleaning the dirty ones?  Check the help section at www.apple.com.  they have wonderful solutions.  Try to put in a couple new cds or dvds to play.  Open up itunes or the dvd player before you put the disks in.  If you're still having trouble, make use of that warranty and go to your nearest apple store to fix it right up! Hope this helps!
May 19, 2008 | Apple PowerBook G4 Mac Notebook
Apple Mac mini G4 Desktop Logo
207 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
