Won't start My Emachines A26EV17F won't start. I press the power button but it won't start.
  • 2 more comments
  • gaga2110 Apr 18, 2009
    yes i hear the fans turn on the dvd drives open but the monitor goes into power save mode.
  • gaga2110 Apr 19, 2009
    as soon as the cpmuter "turns on" the monitor goes into power save mode right away.
  • cmacelis May 11, 2010
    When you start the computer, do you see the Bios Screen at all? And if you do how long does it take for your monitor to go off?
  • Mark Gough May 11, 2010
    do you hear any fans come on?
    President:
  • 414 Answers
If you don't hear the fans coming on you'll need to replace thge power supply. You can go to best buy or any computer store or order one online and get at least a 450 watt power supply, more reliability.
Mark
Posted on Apr 18, 2009
  • Mark Gough Apr 18, 2009
    if you happen to have a video card i'd put that in first, if that works just need to keep video card in if not you need to replace power supply.
    Mark
Check your computer's power supply...
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
My emachine won't power up.
Power is not working.replace the power cord and check if it stays the same then your power box is not working.
Jul 16, 2012 | E-Machines eMachines Desktop PC
My desk top monitor want stay on
What do you mean won't stay on? Describe exactly what it is doing? When does it not stay on, when you press the power button to start the computer? You said it does not stay on, so that tells me that it comes on for a while and you are able to see things, right?
Mar 30, 2012 | E-Machines eMachines Desktop PC
My emachines EL1850-01e Disc drive won't open, I've tried pressing the button and I can't find the eject button anywhere on my computer!
there is a small hole on or around the drawer . straighten a paper clip insert it in the hole to release the lock .
Feb 17, 2012 | E-Machines emachines (emachinees) CD-ROM...
Emachines W3619 won't load ntldr
Take a windows XP CD, Switch on your PC and go to "BIOS" menu and select "Boot From CD/DVD" whichever is applicable for your pc.
Now insert the Win Xp disc i drive and start PC, Boot the Pc From CD Drive and you shall get the Blue screen of windows Installation. Restart the PC by hard pressing the power button for 30 secs.
Now you will be able to login to windows.
Dec 02, 2011 | eMachines W3619 PC Desktop
Kitchenaid kudi01ilwh2 won't start
By won't start do you mean that everything is set ok but when you press Start button then nothing happens.
In that case most likely the door is not sitting properly or the door latch or door switch is faulty causing the dishwasher to not start.
However, if nothing happens on the panel when you press buttons but power is there, then most likely the panel is faulty and can be replaced.
you can trace the parts in these diagrams.
Nov 01, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
Cd rom drive door keeps opening up when in, it won't start cd
Try to this. Start - Right Click My Computer - Properties - Hardware - Device
Manager - CDROM - Properties - Disable. See if it Stops then enable it again.
Look at cdrom button it might obstructed or pressed in, try pulling and pressing. Or it could be a program/driver problem. Try restoring your pc the day before it happen.
Sep 14, 2011 | E-Machines emachines (emachinees) CD-ROM...
My dell desktop won't start. when press the front panel button, computer won't start
check the power connections, if its okay change the power supply or smps
Jul 27, 2011 | Dell Dimension 3100 PC Desktop
Dear sir! my dell optiplex gx 150 won't start when i press the power button but power supply will be start and pc can't give any beep ?
try to remove the power cable on that product and then hold the power button for 8 secs. Reinsert back the power cable and press the power button. If it won't turn on, then the power supply is the main cause of trouble. Contact dell right away for repair...
Jun 22, 2011 | Dell OptiPlex GX280 PC Desktop
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
