Question about Jenn-Air JCB2280HES Side by Side Refrigerator
GE freezer/ bottom refrig won't turn on after short power outage
We just bought a new house with a fridge included. When the power company changed the electricity over to our name, the power went out briefly. The fridge stopped working, and we now can't get it to turn on again. We can't find a power switch after pulling it out from the wall. The breakers are fine. How can I get the fridge back on? Thanks!
    Guru:
  • 462 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Does it have a light inside? Is the bulb good? does the light go out when you push the button in? Why was power off? To change over to your name doesn't require the power co to kill power. At least it doesn't here. Try plugging in a lamp or other appliance to the outlet. Does this work?
It may have went into defrost and will take up to 30 minutes maybe longer with power applied before it comes back on.
Checking power inside the box next power to the compressor.
Yes power to compressor?
. To Decide if Either your compressor is broken inside or the start components are not working properly.
Parameters’ are as follows and must MUST be true before continuing:
1 Condencer coil (outside coil) Clean and open for a ir flow
2 Condensor Fan motor is running and turning at enough speed and correct direction.
3 Voltage to the compressor is correct and supplied.
4 Decide if the compressor is Hot or warm or cold to the touch for future reference.
Cold or Hot
Could it be the compressor not running or that it has overloaded?
If you suspect the compressor try to follow this to decide your next step:
These little helps allow you to get the compressor running or decide that it needs replacing
1 Ohm the compressor terminals to ground and across to each other.
A. If any read anything to ground the compressor is bad. No Need to go further.
B. If the compressor is hot and you read through some points on the compressor motor (pins or terminals) but not through others wait up to 24 hours for an internal over load to reset. Internal type, usually AC and larger Refrigeration Compressors. Smaller refrigerator type compressors have an external over load. After 24 hours off or yours has an external overload re-ohm and see if all have readings to each other. If these read open IE No resistance between each other the compressor is bad.
Results your looking for:
Your readings between the compressor terminals should all be different and you should have 1 low 1 medium and 1 high resistance reading.
Add the low and mid reading together and the sum should be close to the highest reading. If it reads say 20% more or less then retest it a couple of times to confirm your not slipping on the terminals.
After 3 or 4 tries if the results don’t add up the compressor motor is bad. Replacement is required. Is this machine worth a new compressor? Is it still under warranty? Is the labor and all parts covered?
2 Assuming the above checks out:
Get a new Start relay (start capacitor if so equipped) relay and overload (and run capacitor if it has one) In other words everything that is external and attached to the wires or terminals on the compressor, and replace them on to the compressor. Then if it starts problem solved if it still does same thing the compressor is bad (broken mechanically inside the compressor) and you have to decide to replace compressor or replace the refrigerating compressor be it AC or Refrigeration..
A few times I have gotten a compressor to start after leaving it off for 6 to 12 hours then retrying it. See the compressor unless left off for 6 to 12 hours and sometimes as long as 24 hours Is tight due to linear expansion from heat. And about 1/2 the time it is ok after new start components are installed. The other 1/2 the compressor will be ok for a day or 2 then stop again. Most likely from a “hard spot” in the movement of the internal parts in the compressor.
No Power to compressor decide if you have a thermostat or a sensor. Thermostats have a knob and a small metal tube extending into the air on the refrigerator side. An electronic controls type has a sensor and a board that require a sheet of instructions to check out.
A thermostat type is easy to check put the wires together temporary and see if the compressor starts has voltage to it then, if so replace the thermostat.
I recomend if you have an electronic board and decide to replace it replace the sensor as well.
30 years of doing refrigeration and this has not changed.
Please rate me as high as you can and ask me to clarify anything you don’t understand.
Posted on Apr 18, 2009
I have a Kitchenaid S x S KSCS25INSS00 refrig/freezer. We lost power for 30 hours, it worked fine before the outage, now it won't cool the fridge below 48 degrees, or the freezer below 43 degrees. ...
Try replacing the circulating fan first. If it's not turning, it's more than likely bad. However, the fan might not be your only problem. The problem may lie with the icemaker. The icemaker is essentially the brain of the unit. It tells when to cool, when to defrost and when to maintain temp. Your icemaker may be stuck in defrost mode.
Sep 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
Whole refrig stopped working. I checked house breakers so what next
Seems your freezer is short circuited. Common problem is on Compressor. Just the compressor first for shorted. Use OHM meter to make measurement. You can use this instrument to check other parts of freezer. Note : disconnect the power before take measurement.
Regards
Dec 17, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
I have a GE Profile refrig with bottom freezer.Today, the power company turned off the power to the streey and when power came back on, my display in the left refrig door is brinking 88 on one side and the...
I had this issue after a power outage with our GE Profile Model GFSF6KKY Dispenser Model. No solution that I could find online helped me so I started trying different button combinations. Pressing Adjust Freezer and Adjust Refrigerator buttons at the same time and holding it for at least 10 seconds worked for me.
Nov 19, 2010 | Refrigerators
After power outage, fridge does not work but freezer does
Sounds like a thermostat got damaged when the power surged when utilities were restored. Thermostats are usually behind the temperature controller. Hope I've helped. BB
Jan 20, 2010 | GE Refrigerators
Refrig & freezer not cooling properly
I believe the start relay and start capacitor with the overload will need replaced. That is easy and should solve your problem, Sea Breeze
Aug 26, 2009 | GE Profile Stainless Bottom-Freezer...
We had a power outage and top half will not work
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 08, 2009 | Refrigerators
I have a GE TBX25PAXCRWW top mount freezer model. It is leaking water from the light switch. I would assume it is a blocked evap line. Do I access it from the insde of the freezer or outside.
Your problem is a clogged defrost drain . This is accessed from inside the freezer section and by removeing the rear freezer panel . Use a hairdryer to defrost the pan , under the coils . Also , the drain line for your model , is located behind the refrig . So , you only have a short area between the drain hole and drain line , to clear . I would suggest blowing thru the drain hose behind the refrig also , to make sure it is clear .
Jul 02, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Refrigerator 50degrees; freezer 10degrees suspect fan outage/ge
I bought a wine cooler but I want to change the door I would prefare the door frame to be black
May 26, 2009 | GE Refrigerators
GE PFS22MISBBB freezer not cold enough. Temp won't reset.
replace the fan as quickly as possible it may be shorting and causing damage to your control board,
Mar 30, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Jenn-Air JCB2280HES Side by Side Refrigerator Logo
851 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
