Question about Compaq CV 7500 17" CRT Monitor
Colour defect becomes yellowish
    Champion:
  • 205 Answers
Check cabling wiggle near connector body. Lost of blue color is what you are describing. Good luck
Posted on Jul 09, 2009
What can be done for beans or peas with stunted growth
Plants stunted; vines off-colour; roots rotten or absent. Root rot and crown rot. Improve soil drainage by adding aged compost to planting bed. Destroy infected plants. Rotate crops. Plant resistant varieties.
Leaves curl under and become deformed and yellowish. Aphids are tiny, oval, and yellowish to greenish pear-shaped insects that colonize on the undersides of leaves. They leave behind sticky honeydew. Spray away aphids with a blast of water. Use insecticidal soap.
Leaves turn pale green, yellow, or brown; dusty silver webs on undersides of leaves and between vines. Spider mites suck plant juices causing stippling. Spray with water or use insecticidal soap. Ladybugs and lacewings eat mites.
May 02, 2017 | Garden
Power
I have an defective HW191d too. The CCFL are used up(bought it for 5Euro as defect)
What is the colour of a white screen when it is on? Mine is yellowish/reddisch.
Jun 03, 2013 | Hannstar I-Inc TW-191D Monitor
I have this blob discoloration that is in the center of my screen. what could this be its a yellowish green color
Yellowish green colour is usually caused by a burnt blue LCD Panel or the light engine requires servicing.
Jan 15, 2011 | Zenith E44W46LCD 44" Rear Projection...
The picture of my 51" Mitsubishi TV WD 62531 is dull or yellowish.How can I fix this?
It seems the problem you refered is quite complicated if you are not qualified technican. It needs full servicing of main board, including all the heated areas on board.You will need a soldering iron, and a multimeter to test the components, such as resistors on CRT socket board. The yellowish colour is caused by dry joints, (a common fault causing components to shake from its soldered base by heat). Resolder the main board and test the resistors on the CRT socket board for defective ones, change it. If you think you are qualified for this, give it a try or else consult a technican. thanks
May 15, 2010 | Mitsubishi WD-62531 Projection Television
LG CRT TV, picture becomes yellowish
yes it is due to dry solder in vedeo driver section(a board fixed to the pict-tube.).
Jan 22, 2010 | Televison & Video
Yellowish colour of the monitor
check the datad cable of monitor, if ok.then soldring may be dry ot the CRT neck
Jul 29, 2009 | Samsung 793S 17" CRT Monitor
Hi my monitors screen becomes yellowish.all colour effected y dis
Do you have a CRT monitor?
Have you tried to adjust the color on the monitor?
How is it connected to your computer?
It sound like one of the guns on you monitor died. But there is some testing you should do first.
If it is a CRT monitor and it is connect your computer properly. First thing to do would be to replace the cable and or try a different monitor that you know works.
To confirm try adjusting the color. If that does not work, if it more purplish it is the green gun, if it is orangish it is the Blue gun. That would be cause by a failed gun or driver.
If the gun is gone it is best to get a new one. It will save you money in the long run.
Thank you...
Jan 27, 2009 | Samsung 793S 17" CRT Monitor
Yellowish tinge
Hi again,
Any development(s)?
Apr 18, 2008 | Televison & Video
Screen Gone "Yellowish" Colour, Appears that Blue colour is not working
your problem is in blue color cathode circuit. as you say that it becomes ok tha5t means 1 cable wire is loose from computer to monitor. 2 crt base loose. 3 loose contact in blue video ckt. 4 signal processor cable to crt board connector loose.(blue wire)
Oct 14, 2006 | LG Flatron F700B 17" CRT Monitor
Compaq CV 7500 17" CRT Monitor Logo
65 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
