Question about Baby Gear
Squeaky drivers seat backrest
Back of seat "squeaks" inside the centre (lumbar) section suggesting that the interior of the seat is broken? I am looking for repairer or replacement seat please. Thanks - Phil
SOURCE: CLK 330 seat malfunctions
The solution to your problem is to adjust your leg length instead.
Posted on Jan 02, 2008
riceski
  • 1851 Answers
SOURCE: lumbar bladder loses air
you will need to take it to an upholsterer - have them remove the skin of the seat and install a new one - then put the seat back in.
Posted on Apr 01, 2010
zappanut
  • 959 Answers
SOURCE: looking for a driver backrest for this bike, got
get a bolt on backrest and turn it around so the back of the passangers backrest is on backwards.
flip the pad to the backside of the backrest and there ya go.
Posted on Feb 19, 2011
  • 35572 Answers
SOURCE: how to repair the lumbar support in a 2010 sebring
The manual support linkage has become disengaged or may have broken. Check to see which is the case and make repairs
Posted on Sep 18, 2012
SOURCE: DRIVER POWER SEAT LUMBAR BUTTON STUCK. SEAT DOESN'T MOVE
Remove the button & resolve that part of the issue,
so it either works or if tests bad-- replace it
Posted on Dec 07, 2012
Remove rear seat
Rear seat cushion-fold forwards,release plastic clip from hinge,remove wiring multiplug if applicable.Lift out cushion.(40% backrest)Tilt forward approx 20degrees,use a screwdriver to release catch retainer on outer pivot pin.lift backrest and withdraw from inner pivot pin.Lift the backrest from inside vehicle.(will only lift out if backrest is tilted forward 20degrees from verticle. 60% section can then be removed on saloons by releasing the lock with a finger and pulling from the anchor pins.On estates unscrew centre seat belt lower mounting and unscrew hinge pin from centre support. unhook upholstery clip and lift backrest from lefthand side mounting.slide backrest towards the door to release centre pinlug and withdraw backrest from inside the vehicle. Refit in reverse order.
May 22, 2015 | 1999 Saab 9-5
Lumbar seat for 2006 trailblazer will not deflate
could be a problem witch air solenoid inside the seat or the balloon itself or line not connected
hope it helps
Mar 27, 2014 | 2006 Chevrolet Trailblazer Ext
How to remove the backseat of 1994 buick avenue
most gm vehicles have a two piece back seat; you have to remove the bottom first. there are two screws on a little vertical section of floorboard under the front of the seat; remove them, then push the seat back just a little and remove the lower section. then you will see two more screws which hold the backrest; when you remove them just lift up and remove the backrest. you can reinstall the lower section if you want.
Mar 05, 2013 | 1994 Buick Park Avenue
How to repair the lumbar support in a 2010 sebring
Sep 17, 2012 | 2010 Chrysler Sebring
Looking for a driver backrest for this bike, got any suggestions, other than the Bakup? It is a stock seat.
Feb 19, 2011 | 1993 Suzuki VS 800 Intruder
Hi - I have a much loved 2004 SAAB 93 Aero sedan.
This has been happenning on my 2006 Saab 9-3 2.0 T also for about 2-3 months also. I have had no clues until today I learnt by accident that the lumbar support on my car's driver seat does not work anymore. Which means that there are broken strings/wires inside the seat and that move on braking and make clicking sound. I haven't checked my seat's lumbar support but will do soon.
Try your lumbar support adjustment and see if it is moving freely, that means it not adjusting the lumbar support. If that's the case, that may be the cause of the clicking/slight-movement of the seat.
May 09, 2010 | 2004 Saab 9-3
Broken lumbar support
Go to the junk yard and pull you another one.
Nov 23, 2009 | 2001 Chevrolet Silverado 1500
Middel seatbelt will not loosen
I think you have to remove headrst bfore folding seat back down. You may have to unbolt seat from floor. 4 bolts.
Rear Seat Backrest —Split Bench Removal
NOTE: The 40% rear seat backrest must be removed before the 60% rear seat backrest.
  1. Remove the 40% rear seat backrest.
    1. Remove the nuts and bolts.
    1. Remove the backrest.
  1. Remove the 60% rear seat backrest.
    1. Remove the nut and bolt.
Installation
NOTE: The 60% rear seat backrest must be installed before the 40% rear seat backrest.
  1. NOTE: Do not tighten the nut and bolt at this time.
    Install the 60% rear seat backrest.
    1. Install the rear seat backrest.
    1. Install the nut and bolt.
  1. NOTE: Do not tighten the nuts and bolts at this time.
    Install the 40% rear seat backrest.
    1. Install the nuts and bolts.
60/40% rear seat backrest
  1. Tighten the 60/40% rear seat backrest nuts and bolts in the sequence shown.
40% Rear Seat Backrest
  1. Tighten the 40% rear seat backrest nuts and bolts in the sequence shown.
Jun 11, 2009 | 2005 Ford Escape
Lumbar support leaks
check the lumbar switch first it is an electrical switch and also vents the bag
Nov 24, 2008 | 1996 Mercury Grand Marquis
Baby Gear Logo
331 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
