Question about Raymarine C80 GPS Receiver
Gps mapping No gps mapping. Lights are not displayed on the receiving unit. We have radar, depth finder, all other stats but for the gps mapping. Card is installed correctly and we have disconnected and re-connected the unit to be assured it is properly installed.
  • 16 Answers
It sounds like you are reporting that the GPS is not getting a fix?
What color light are you seeing on the GPS receiver? We are hoping for a green light indicating it has a fix. Any color at all indicated it has power. If there is no light on the receiver, there is no power being fed to it.
Depending on how this was installed you could get power from the C80 itself, or from the larger SeaTalk network if you have instruments and autopilots. MAke sure all of your breakers and switches onboard are powered on to start. The GPS receiver could have been wired to a different circuit than the display.
Posted on Dec 28, 2007
SOURCE:
Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Sep 02, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Gps error message "gps module not responding"
Check the connectors and wiring between the GPS module and sonar unit. If it's an internal GPS module yo may have knocked loose a connector internally.
Jun 01, 2009 | Lowrance LCX-17m Sonar with GPS GPS...
Eagle 640c Fish Finder dosen't read corectly.
I had the same problem and got the transducer changed. It now works perfectly. That could be the problem you are having... bad transducer.
May 17, 2009 | Eagle Intellimap 640c Marine GPS GPS...
I have a Garmin 178c map/sounder and it will not load up my BlueChart Data Card. I bought a new card, thinking that would cure my problem, but it didn't. I would love to get your input what steps to take...
I have the same problem. Did you ever figure out why it was not loading? There are no software adjustments to be made. Just plug in the card and wait. It says its reading the card, but never goes any further. Let it 'read the card' for hours with no luck. Help!!!
May 16, 2009 | Garmin GPSMAP 178C GPS Receiver
Problem with navman 4150 fish finder
I installed my Navman 4150 depth finder along with the Navman GPS unit when I purchased my Bayliner Trophy 20Ft. Offshore model. Everything was ok for one year and it has been downhill since then. Losing signal, unbelievable high depth ranges, blank periods, etc.. I now can't even get a reading tieded up at the dock. I am now giving up and shoping for a quality unit.. Cape Disappointment.........
Jan 07, 2009 | Navman Fish 4150sx GPS Receiver
I would like to install a north america maps to my Garmin bought in italy withy europe maps
You would install the maps on an SD card, or microSD card, and then inside the setup of the GPS unit, you would choose which maps you want the unit to display.
Sep 08, 2008 | Garmin GPSMAP 76Cx GPS Receiver
Rl70c raymarine depth finder problem
fish finder transducer needs to be on before you boot your system. check your hsb cables and termination
Jul 12, 2008 | Raymarine RL70CRC GPS Receiver
WAAS
sounds like the problem is with the pilot. You may be expecting too much from nav mode you should check the antenna connector on the WAAS issue
on VX2, are you marking a good bottom on the sonar screen, but have no digital overlaid? never seen it, must be a BB thing
May 04, 2008 | Furuno GP32 GPS Receiver
Is it possible to make my Humminbird 787c2 to show METRIC unit instead of IMPERIAL?
hi
Did u bought Humminbird 787c2+GPS or just Humminbird 787c2 ?
If u bought Humminbird 787c2+GPS i like to know, do the built in GPS UniMAP work in australia ? i bought one myself. Thanks.
Mar 27, 2007 | Humminbird 787c2 GPS Receiver
Raymarine C80 GPS Receiver Logo
346 people viewed this question
Top Raymarine GPS Experts
gerd butler
Level 1 Expert
Goldi Kunal
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
