Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
WD-62327 Lamp We received a new lamp from mitsubishi-tv.com for our WD62327 mitsubishi. we have replaced the lamp, the lamp light on the front panel of tv starts out orange as the power is on. then the lamp light starts flashing green and then the tv shuts down and the lamp light is red. does this mean the lamp is bad? Please help.
  • tustle Sep 18, 2007
    Ok we have the lamp installed now and the TV was working. We were playing with the settings (contrast, tint, etc) and the tv all of a sudden froze up and shut down. When we try to turn it back on, the green timer button blinks a couples times (u can hear clicking in the back of the tv) and then the green timer button flashes 3-4 times, then the tv shuts down. What do you think the problem is now?
  • tustle Sep 25, 2007
    we ended up calling a service man and the power & sub power boards are bad. $477 for parts & labor to fix. just so you know.
    New Friend:
OSRAM VS. PHILLIPS
This is about buying replacement bulbs for the WD62327 TVs.I dont know about the other models but I purchased a PHILLIPS replacement bulb and it worked for about a week and then those dumb flashing lights and no TV. I did some research and others were saying that you had to replace some condensers. Shop would do it for 600 dollars..Well i sent the bulb back and bought an OSRAM replaement bulb. The TV is now working perfect.
Posted on Jul 14, 2010
    Genius:
  • 1,153 Answers
Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977020 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977020 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977020 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977020 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001
Posted on Sep 18, 2007
  • Lashawn Robinson Sep 19, 2007
    Try this model is equipped with a keyboard lock feature. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds.
  • Lashawn Robinson Oct 08, 2007
    Thanks for letting me know!
SOURCE:
We replaced the lamp in a tv mitsubishi wd-62327 now there is a orange flashing indicator light....now what?
if the set is now working,its just a matter of resetting the lamp-hour counter in the on-screen menus.be sure to clean any filters associated with the fan which cools the bulb,or your new lamp wont last long!
regards,steve
Jul 31, 2011 | Mitsubishi WD-62327 62" Rear Projection...
I have the Mitsubishi WD62327 62". I just changed the bulb which I did last year on my own too. My problem is not replacing the bulb but now the tv does not want to turn on. This did not happen to me last...
You need to reset the timer lamp. On mine it is getting the display to lamp then hold the left and menu button for five seconds.
If that doesn't work go to the mitsubishi site and DL the PDF of your model and it should be in there unless you have the paper manual still around.
Aug 11, 2010 | Mitsubishi WD-62327 62" Rear Projection...
Need to replace lamp
On this model the lamp is behind the front grill, pull the grill off and you will find the lamp door in the middle it has two phillips head screws in it taske those out and you can look inside and see the lamp it has two flat head screws in it, loosen these all the way off, they do not come out of the housing, grab the handle and pull the lamp out, after you replace the lamp and before you try to turn the set on make sure the door is back in place and screwed down because it will not come back on if the door is not on.
Sep 04, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Replaced Bulb and sill have red lamp light
no you should not feel any click,the lamp plug
slides into the ballast plug in the groves.do not
force it,you could have the plug upside down or
you need to visually see if the ballast plug is
damaged.you may need to replace the ballast if you still are getting a red lamp error on the
front of the tv.
Jul 15, 2009 | Mitsubishi WD-62327 62" Rear Projection...
How do I install the lamp? how to install bulb mitsubishi wd 62327
The lamp is in the FRONT of the television set. Just remove the bottom front, no screws, and you'll clearly see directions on how to install the new lamp.
Simple, just a few screws.
Feb 28, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Flashing red status light wd62327
Your lamp is getting ready to go!!! Better order a new on, it is approx. $236.00. I put a new lamp in mine (July 2007) just ordered another one this week. The first one that went gove me the warning of the flashing light, this time it just blew. I called 2 places and they said it is the lamp.You can order them online from Mitsubishi.
Feb 18, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi wd62327
where is the lamp housing located?
Nov 09, 2007 | Mitsubishi WD62327 TV
Replacing the lamp wd-62327
Did you get correct lamp:lamp part # 915P020010 ?
Sep 07, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
1,225 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
