Question about Miele Novotronic Premier 500 Front Load Washer
Water inlet Fault - Miele Novotronic W1511 - Washing Machine
When starting a cycle the washer starts washing(spinning) without water then after about 3 mins the fault starts flashing. Please help... the washing is building up.
  • Anonymous May 04, 2009
    Water inlet and outlet lights flashing, clycle wont start.
SOURCE: miele novotronic w/m fault light flashing
We had the same problem on a Premier 500 and solved it by tilting the machine forward. Some more water ran out and the lights went off.
Posted on Jan 05, 2008
IB4G2008
  • 3587 Answers
SOURCE: water not getting into washing machine miele novotronic w830
K5? which pipe is that..let's assume you have pressure to the back of the unit, yes? then you have a valve sticking or something obstructing the channels inside that unit..
does this work regardless of temperature setting.
Posted on May 10, 2008
jumptrout51
  • 3361 Answers
SOURCE: Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
Posted on Mar 10, 2009
Mark Harmer
  • 8 Answers
SOURCE: Inlet blockage red light flashing
Try turning the machine on its side, undo the bottom and check that the polystyrene float (attached to a switch) is not somehow jammed. This float cuts off the water if the machine leaks internally, and produces the symptoms you describe. It's a really good machine so don't throw it away!!
If that still doesn't help then it might also be the motor brushes, which produce similar symptoms - if your machine starts to fill but then flashes and just drains again, it's almost certainly the brushes. This might be the case after you check the float problem.
Posted on Sep 21, 2009
  • 4 Answers
SOURCE: miele W1712 washing machine drain fault
Just had the same problem, after Much patience and persistence I found the blockage at the y piece that joins the pump to the outlet hose air trap towards the top of the machine LHS with the top and cover off.
It was clogged solid therefore no back pressure on the top little ball valve (between the air trap and the outlet) therefore no seal therefore norain therefore a drain-fault that persists regardless of a cleaned pump filter.
Posted on Dec 04, 2009
Miele 500 washing machine inlet light comes on and machine wont pump water out or spin
try leaning against door when pressing start . if it runs get the switch replaced
Jan 24, 2016 | Miele Novotronic Premier 500 Front Load...
Miele w961 start problems
It ispossible that the machine does not start off the cycle because there are errorsdue to feedback from the inputs. For the program to start up the main programcontroller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting fromthe flow of water into the drum as also the drain valve to open to exit thewater at the point of the program cycle. If this does not happen then thevoltage at the valve/motor/pump must be checked or the fault relates to novoltage from the controller. This meansthe controller is a suspect.If thewater flows though the inlet then the flow pressure should be good, if not theinlet valve is bad or there is dirt in the filter. Also check the flow at theinlet of the water line. Once the water comes into the system the WATER LEVELSENSOR - normally a pressure switch- must activate at the preset/chosen levelto give the signal to the program controller to switch on the motor. What ismost important for the motor to start functioning is that the door switch mustbe ON when the door is shut or this will be an error for starting the motor forrinse and wash.Check thislink to replace the inlet valve:http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html Finallyafter the wash the drain valve will be activated, the water is allowed to comein to rinse and then finally the dry spin with the drain valve/pump activatedso as to drain off all the water from the clothes during the spin.Make surethat a fault in any of the cycle will relate to the specified action, so checkthe command from the program module and then the executing device be it thevalve or motor or pump. Please check the link below:http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jul 05, 2012 | Miele Novotronic Premier 500 Front Load...
Miele w1918 check water light flashes and the machine will no start washing.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter In this case the inlet filter and inlet valve is a suspect.
Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Thank you for using fixya.
Aug 17, 2011 | Miele Novotronic W1918A Front Load Washer
Miele washing w 487, signal show rinses and anti-create/Finish
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Aug 01, 2011 | Miele W487 Front Load Washer
Miele W1926 check inlet light flashes at the end of rinse fill. When the fill ends, the light goes off. I cleaned all 4 filters at the intake hoses. The problem still exists. What does it mean?
Hi dear.According to what you're saying,It has faulty water inlet valve.Machine unable to get enough water to do it's cycle in given parameters in time period & starts giving error but before the cycle complates,however it takes enough water,that's why error lights goes off.If you can,you need to change the valve or call service department.I hope that helps.Thanks.
Jul 25, 2010 | Miele Novotronic Premier 500 Front Load...
Check Inlet
where the water lines attach to the washer at the back un screw them and check the screens on the water valves see if rust or trash is restricting the water flow
May 24, 2008 | Miele Novotronic W1918A Front Load Washer
Miele novo w526
Can you hear the drain pump running??....If so the WPS system has been activated and there is water in the base.
If not, please post back if any water is going into the main wash compartment once it's started. No water, then faulty inlet valve.
Jan 21, 2008 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic Premier 500 Front Load Washer Logo
606 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
