Question about Horizon Exercise & Fitness
Erratic speed on Horizon treadmill.
Hi The speed of the treadmill does not correspond to the speed control key.  Any solutions? Thanks
  • Anonymous Mar 18, 2014
    erratic display program and speed change by themself on a t54 horizon
  • Anonymous Mar 19, 2014
    HI THE PROGRAM DISPLAY UNIT TURNS ON WHEN FIRST POWERED BUT THEN THE DISPLAY PANEL STAYS BLUE WITH BROKEN LINES IN IT SO UNABLE TO SET THE TREADMILL - IS THERE A BATTERY SOMEWHERE THAT COULD NEED REPLACING? PLEASE CAN YOU KINDLY HELP - LIZ
Treadmills Erratic speed on Horizon treadmill. Solve Hi The speed of the treadmill does not correspond to the speed control key. Any... (More)
Posted on Jun 03, 2009
I have a Horizon LS925T treadmill. It seems to jerk. I don't think the belt is slipping, more like the power roller is erratic. It rolls smooth then slows for a second which jerks the belt. Help.
Hi There, This sounds like the control board may be failing. Can you see the control board? Check the 3 larger capacitors for doming or bulging on the tops, which is a sign of high internal heating of the capacitors. This board, 032671 can have issues with these caps. Lubricate deck well, free spin the walking belt by hand to feel for jerky rollers and flat-spots in bearings, if all feels smooth, that controller is most likely at fault or a failing motor with partially shorted windings. Contact jatinah@rocketmail.com for more help if needed.
Mar 24, 2017 | Horizon Exercise & Fitness
The belt won't start on my treadmill. the speed is already at 0.5 when you turn it on instead of zero. everything starts going and speed can be increased but belt doesn't move......
Hi there, I think I can help. Now depending on model year the Horizon T500 can use a couple different motor control boards, most all of which are fixed at jatinah electronics which you can find with a Google search. It sounds like a failed control board fixed for 99 or less and exchanges available with returned cores. Good luck
Feb 04, 2015 | Horizon T500 Treadmill Walking Belt
Where can I buy motor control board for horizon treadmill T101
just run in the open air, it's much better to experience real life
Jan 06, 2015 | Horizon Exercise & Fitness
I have a horizon fitness t51 treadmill. I weigh about 138 pounds and typically run 5 miles a day at a 2% elevation at a steady speed somewhere between 5-6 mph. It recently has developed one of two...
hi,
from ur description i think ur treadmills control module have problem. motor driving card and motor is ok. normally there are no serviceable part inside the controlling module ( user interface module). only thing can do is remove the controlling module, take out its board check all the micro switches( press button switches) replace it found faulty or not( remember to remove the power before). the refix it and the test the tread mill.
ok
Dec 26, 2010 | Horizon Fitness Horizon Motor T51...
My Uncle gave me a Horizon T605 treadmill and the
horizon rct 7.6 , safety key off , replaced ,key.reed switch and board , still says safety key off ?? spoke to horizon several times and repair techs as well ,it can only be 1 of those 3 items , all switch & key tested good , must be a faulty new board ?? could it be anything else ??
May 28, 2010 | Exercise & Fitness
I have a T54HR horizon treadmill. The problem is
best if you see the local retailer where you bought the treadmill. Obviously the switch, whick is a magnetic disc is not activating the sensor in the control panel and need to be looked at.
Sep 23, 2009 | Horizon Exercise & Fitness
Exercise & Fitness Logo
1,334 people viewed this question
Top Horizon Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Trevor Turner
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
