Minn Kota Edge 40 Freshwater Bow Mount Trolling Motor Logo
Posted on Apr 18, 2009
My brother inlaw got a minkota 40ta all terraine trolling motor that is supposed to produce 40 pounds of thrust. it does not seem to produce even close to that. is it possible that the motor is turning the wrong direction after he wired it up?it is a minkota 40ta all terraine trolling motor.s#mkad2601705
  • Dean
    Dean May 11, 2010
    What are you comparing the thrust to? Not to 40Hp right?
    What size boat?
Johnny G14
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Sep 07, 2009
Johnny G14
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
9067
Points
16
I would check the battery. If you're using an old or under charged battery you will loose power for sure. Make sure you're also using a 12v deep cycle marine battery as this will ensure proper operation and a longer battery life.
I have a 65 pound thrust all terrain MinnKota trolling motorThat stopped working on me the other day when I was fishin.Iwas fishing and was trolled 2 another spot when I got there I stop the trolling...
Hello John,
Most Of The Time I Find The Problem Is With The Cables And Connections To The Battery?
Remove Battery Lugs And Cables Clean All Contact Areas .
Re Connect And Test Again
Hope This Helps
Gordy
Dec 01, 2017 • Boating
Hard foot pedal
On the base of the foot pedal there is a tensioner for the cable. Try loosening or tightening that first. If you still have the manual from when you bought it, it is explained in deatil in there. It's a common issue - not to worry!
Motorguide Trolling motor has low thrust in all five speeds
I have a 4 speed with 48 lbs of thrust. On mine, 1 through 3 will move me out pretty well, however, 4th is similar to an overdrive gear in a car or truck and is meant more for maintaining a speed with less draw on the amps.
I certainly wouldn't want to take off with it. I suspect it is the same with your 5 speed. The boat needs to be up to speed and then those two gears will maintain it, with 5th being optimal as far as low draw in amperage.
2answers
How does the minn kota 65 all terrain run on 24
You should only run the motor with a 24v battery or two 12v batters 'jumped' out. To jump the two batteries, connect the positive on one batter to the negative on the other battery and hook the trolling motor battery cables up to positive and negative terminals that are NOT jumped out as you would normally. Don't run this with 12v as you will have serious problems if you do. They do not make a 65lb thrust in 12v - too much pound thrust to run off of 12v.
Motor guilde lll trolling motor
I have a motorguide trolling motor model 2600 #s/n 19409 can't find out what thrust it is
The plastic part in my bow mount Turbo 765MX(36lb.thrust) Minkota
Hello poorjohn, stroll to www.minnkotamotors.com/index.asp When you call ask for ext #406 and ask for Dave. Refer to my logon 'themoneypitt' He is a great guy. Merry Christmas.
Need wiring diagram for a Minn Kota 50lb thrust "All Terrain" trolling motor
Call Minn kota, the number should be on the bottom of the head. They will e-mail it to you.
Oct 16, 2008 • Boating
3answers
Wiring diagram for Die Hard 28 lbs thrust trolling motor
It's probably a Minn kota with a die hard label. Call Minn kota and ask them.
Aug 08, 2008 • Boating
Top Minn Kota Boating Experts
ADMIN Andrew
ADMIN Andrew
john h
vince
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
