Question about Dyson DC16 Root 6 Bagless Handheld Cyclonic Vacuum
Removing the battery
Can't figure out how to remove the battery from the Dyson DC16 Root 6 handheld vacuum? Did not get an owner's manual/guide in the box with the vacuum.
  • valmcelvain Apr 18, 2009
    Pushing down on the release didn't work until we finally got a screw driver to give us added leverage and pressure and were finally able to get it released.
    President:
  • 389 Answers
The battery is located at the bottom of the handle. To release it, press and hold down the button on top of the battery case (it has 3 ridges on it). That releases a catch and you can then slide the battery out to the rear.
Posted on Apr 18, 2009
  • Philip Gaut Apr 19, 2009
    Thanks for feedback. Glad you got there in the end!
How do I remove battery from hand held vacuum?
Hi Alan, it's Jack at Dyson.
If you own a Dyson DC16 handheld vacuum, the battery removes at the push of a button. Press the catch and pull the battery away from the machine horizontally. If you're fitting a replacement battery, this will attach to the machine in the same way.
If you own a different model of Dyson handheld vacuum, please reply to confirm which model you have so we can provide further advice.
Alternatively, if you'd prefer you're welcome to call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 25, 2014 | Dyson DC16 Root 6 Bagless Handheld...
How to disassemble a dyson dc16
The Dyson manual is here ( Dyson DC16 User Manual Page 2 ). If you're wanting to go further than just undoing areas to clear clogs, or, say, to do a super deep clean-out, then you may need to look around for specifics. There are videos out there on some deep inner checks, but I didn't have any luck on tear down guides.
Good Luck
Jul 06, 2014 | Dyson DC16 Root 6 Bagless Handheld...
Root 6 sill not shut off
Hi there Mike, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC16 handheld. If you've found a replacement battery has not resolved the issue with your machine, there may be a fault with the main body assembly.
We'd be happy to take you through some quick diagnostic checks to help confirm what may be causing the fault. You can reach our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 05, 2014 | Dyson DC16 Root 6 Bagless Handheld...
Hi, my Dyson DC16 works fine but after removing from charge base following recharge the red and green lights remain lit and the unit will not operate until i remove the battery and reconnect to vacuum,this...
If it is within the warranty period get Dyson to replace it. If not, live with it until it fails completely, then buy a Hoover. Your computer board is starting to fail. That's not repairable.
Aug 06, 2017 | Dyson DC16 Root 6 Bagless Handheld...
How to release canister from dyson root cyclone vacum
For guidance on emptying the clear bin from your Dyson DC16, please follow the steps shown in our online Support guide:
http://www.dyson.co.uk/support/dc16/dc16/maintaining-your-dyson-machine/empty-the-clear-bin1/emptying-the-clear-bin-step-1
If you're trying to remove the clear bin from the machine, you can do so by following these steps:
http://www.dyson.co.uk/support/dc16/dc16/using-your-dyson-machine/how-to-remove-a-blockage/how-to-remove-a-blockage/check-cone-shroud-1
I hope this helps - for any further assistance, please give our Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Apr 16, 2012 | Dyson DC16 Root 6 Bagless Handheld...
Where can I find a manual for the DC 16 to download as PDF? I can't find a site to do this at! Thanks!
The manual is available at the Dyson site. There are several DC16 handheld vacuums: http://www.dyson.com/support/help.asp?model=SUP-DC16&article=1374 . The direct link to the Root 6 manual is http://media.dyson.com/downloads/us/floorcare/manuals/dc16_opmanual_usa.pdf . If the direct link doesn't work, start at the first link that I provided. Then click on the Root 6 and then the User's manual will be the first link under Maintaining your Dyson product.
I hope this helps.
May 27, 2011 | Dyson DC16 Root 6 Bagless Handheld...
Can i get instructions for my dyson DC16
Here is the link....just select the dc16 model you have and you can veiw and save or print the manual!
May 10, 2011 | Dyson DC16 Root 6 Bagless Handheld...
Dyson DC16 keeps cutting of after 2to3 seconds tried removing the small three leg resister and joint A and B together but still didn't work can any one help with this problem
Most likely it is your battery. the lith ion batteries die out over time. That is on of the symptoms of an old battery. Did you call Dyson? They have a 5 year warranty
May 06, 2011 | Dyson DC16 Root 6 Bagless Handheld...
I Need A dyson hand held battModel DC16 12097 model 282-US-A35458 21.6 1080 MAH All I can find is the 1500 Mah
I didn't understand what you need exactly, but anyway, you can find both of them on amazon (the entire vacum, or just a battery 1500Mah). take a look on following links:
1. entire vacum: Dyson DC16 Root 6 Handheld Vacuum Cleaner
2. just battery: Pwr 1500mAh Extended Capacity Battery for Dyson Dc16 Root 6 Vacuum Cleaner...
Dec 09, 2010 | Dyson DC16 Root 6 Bagless Handheld...
Dyson DC16 Handheld Vacuum Cleaner Manual
Yes! Go to www.dyson.com/support. Click on "using your dyson", then (next window) on "select your model", then (next window) on "select your model" again, then (next window) on "DC user guide". And there you are, you've got a copy of the user manual.
Please remember to rate this response. Thanks!
May 17, 2009 | Dyson DC16 Root 6 Bagless Handheld...
Dyson DC16 Root 6 Bagless Handheld Cyclonic Vacuum Logo
639 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
