Question about Sharp AL-1655CS Laser Printer
Copy When we have more than sheets to copy we use the top feed part and when we do it takes two sheets and then stops.
  • 163 Answers
There is some alighnment problem with adf contact technician
Posted on Sep 19, 2007
Preprinted 4 part paper crunching up when being printed in epson lq680 printer
Mustafa:
The printer is not meant to use multi-copy carbon invoices. The cause of your problem is the double-feed prevention pad below the paper pickup roller. When the first form is fed, the double feed prevention pad will stop multiple paper feeds. With multi-page carbons, the paper feed roller is trying to feed the form, and is pulling the top page of the form into the feed rollers while the double-feed prevention pad is stopping the bottom form from feeding and the top and bottom pages are sliding because of the carbon paper between the sheets. The only solution that I know of is to buy a printer with a tractor feed and pre-printed fan-fold forms with tractor feed strips on the sides of the forms.
Oct 13, 2012 | Epson LQ 680 Matrix Printer
Our copies are streaky like the drum is not clean.... help! There is black streaks on the top of all of our copies on our canon imagerunner 3300.
A) Black Streaks, Shadows, And Ghosting
Adjust the printer's lightness/darkness setting to 2-3 different variables and see if problem disappears. Look at the fusing assembly - is the roller torn or does it have any black buildup? Use caution!!! It gets HOT!
Try another toner also.
Feb 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
How do I stop Fax from feeding more than one copy of typed sheets through the machine at onc time?
If you take some alcohol, and put a couple of drops in the center if a piece of paper, then pass it through the feeder a couple of times, this should clean the feed and separate tires, do this a couple of times, then try passing a couple of sheets to see if the problem has been eliminated.
Hope this helps.
Ed
May 07, 2009 | Canon FAXPHONE L80 Laser
Sheet feed won't work
When you reinstall the blue plastic piece underneath, the white plastic sheet that closes over the glass must hang over the blue plastic piece, not tuck under it.
Mar 29, 2009 | HP Officejet Pro L7680 All-In-One Printer
When using the adf get error message
Advice is terribly difficult without a model number of your machine
Mar 06, 2009 | Canon Office Equipment & Supplies
E-studio copier won't multi feed, it jams
Hello sir; Open the feeder cover clean all the rollers by rubbing alcohol or rubber rejuvenator( recomend) it should take care the problem.
Feb 03, 2009 | Toshiba Estudio 200L Copier
How do i make double sided copies for my HP 2840
When you call up your printer (usually [Ctl][P]) tell it to print even numbered pages only, but in reverse order, This means the last page to be printed will be page 2, and it will be face down on the top of the pile (blank side showing) Take the printed sheets and rotate them so the top (head) of the sheet is feeding back into the machine, with the blank sides up. Now call your print up again and tell it to print the odd pages only. The first sheet to be printed will be page 1 which will print on the blank side of page 2, and all the rest will follow in sequence, with the correct sides up. Works every time. The print control is part of the Windows system, so your application should provide the full functionality.
Dec 18, 2008 | HP LaserJet 2840 All-In-One Printer
ADF will only feed one sheet then stop
no,just try to clean the roller of the ADF at the same time the separator pad.make sure that you are using paper that is 24lb weight coz if you are using paper that is so thin if may cause also an issue that the ADF could not pick-up...if the issue is still occuring return/replaced the printer...
send feedback for further troubleshooting...
Aug 23, 2008 | HP Officejet 6310 All-In-One InkJet...
Xerox XC540 copier fails to feed bland sheet
sounds like there is something not pushing down the plunger, or may need to adjust switch to make it higher.
Oct 19, 2007 | Office Equipment & Supplies
Erratic operation thru top copy/fax function
I don't really want to get into this, but you sound desparate. i don't work on your model very often, so bear with me. When a sheet jams, don't just pull it out. Open the document feeder as far as you can and note where it stopped (the side tha DID NOT feed). Look for a possible obstruction or even spot of something that looks dirty or sticky. If so, remove or clean it. Look at the leading edge of the jammed sheet, see if there are any indentations that could possibly line up with a sensor flag, roller edge, etc. Last suggestion. Press down of the side of the document feeder that DID NOT feed through. If this helps, then there is a problem with the latch that holds the document feeder closed. Without seeing the unit it is difficult to diagnose correctly. Let me know one way or the other. Any observations will be helpful. Ed One more thing! Make sure the leading edges of the pages you are sending are perfectly straight and smooth. Make sure that they HAVE NOT been stapled at one time (the indentation can cause a problem)
May 31, 2007 | Canon imageCLASS D880 All-In-One Laser...
Sharp AL-1655CS Laser Printer Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
