Question about HP iPAQ H3835 Pocket PC
Is a compaq ipaq h3835 compatable with vista
Do i need to upgrade my ipaq h3835 to use with vista
  • 148 Answers
No, you do not need an upgrade. You'll need to be download only "Windows Mobile Device Center" to your Vista PC instead of ActiveSync. (ActiveSync is not compatible with Vista, instead Microsoft changed the software a bit called "Windows Mobile Device Center" and can be downloaded from Microsoft's website.) Your Vista PC should also recognize your ipaq PPC without needing any driver CD. I hope it helps.
Posted on Apr 18, 2009
Can i use windows vista with my ipaq 3835 pocket pc and what is till the memory expandable upto
No, you cannot use Windows Vista on your iPAQ.
I am not 100% sure but, I have seen products made before the whole HD SD cards not being able to use them so, I would stick to the regular SD cards which go to 2GB.
Feb 09, 2010 | HP iPAQ H3835 Pocket PC
Window Vista syncronizing with iPAQ 3835 problem
In order to sync any iPAQ with Windows Vista, you will need to download and install Windows Mobile Device Center 6.1 from http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/device-center-download.mspx.
Activesync will only work for XP Operating Systems and earlier.
Notes
  • To find out whether your version of Windows Vista or Windows 7 is 32-bit or 64-bit, click Start, right-click Computer, and then click Properties. The version is listed after System Type.
  • You can use Windows Mobile Device Center 6.1 only with phones running Windows Mobile 2003 or later. ActiveSync and Windows Mobile Device Center won’t work with Windows Embedded CE 4.2 or 5.0, Pocket PC 2002, or Smartphone 2002 devices. (To see which Windows Mobile operating system you’re using, and if your phone doesn’t have a touch screen, click Start > Settings > About. If your phone has a touch screen, click Start > Settings > System tab > About.) To sync content to any of these devices, you must use a USB or serial cable and your computer’s Internet connection and File Explorer.
  • You must use Microsoft Outlook 2002, Outlook 2003, or Office Outlook 2007 to sync your e-mail, contacts, tasks, and notes from your computer.
  • You must use a USB cable to connect your phone to your computer the first time you use Windows Mobile Device Center to sync.
Jan 11, 2010 | HP iPAQ H3835 Pocket PC
Where can I go to buy OS software for my Compaq Pocket PC H3835? I have a new computer and cannot find my Compaq OS disk in order to install. I've moved a few times since I purchased my iPAQ and beleive...
OS software can be purchased via Best Buy, Wal-mart, or any computer electronics store. If you're just looking to reset your PC to original settings, their may be a recovery application buried in the ROM of your PC.
Nov 13, 2009 | Compaq iPAQ H3955 Pocket PC
Online with a Compaq iPAQ H3835 Pocket PC
The 3835 did not have WiFi capability so you can't get online. Probably not worth messing with unless you're a real techie. I think there is a distro of Linux that can run on it if you want to play with that.
Nov 08, 2009 | Compaq iPAQ H3830
Can i use my ipaq h3835 with vista
U can check it out using vista ultimate crack version otherwise check the compaq's site for ur model specifications
According to me u can succeed try it out or send me ur configuration and then i will give u answer
Apr 18, 2009 | Computers & Internet
Where can I get a free upgrade for my HP Ipaq rx3115 for windows Vista?
For compatibility with Vista it should only require installing the newest version of ActiveSync which is free from Microsoft's site. But, If you mean the Pocket PC OS Revision, I don't think you can legally update the OS beyond a version number (Like 3.3 to 3.5) and if your not able to sync with certain Office components, etc. because of the OS, there isn't much choice legally but to buy the upgrade.
Mar 13, 2009 | HP iPAQ RX3115 Pocket PC
Is the Ipaq RX3115 compatible with Windows Vista?
Yes, but you will need to download Windows Mobile Device Center - free from Microsoft,
which replaces ActiveSync
Oct 22, 2008 | HP iPAQ RX3115 Pocket PC
Compaq 3835 Fails to start after installing dashboard
Have you tried to remove the battery for a few moments? Hopefully if you try this, all your data was backed up, because removing the battery will lose your data. But, if the system is stuck at the "welcome" screen, then removing the battery wipes out the memory. The system will be just like right out of the box (unless you flashed the rom with an updated version of the Operating system, that won't roll back by just removing the battery).
If your not sure what I meant by flashing the rom, it is the upgrade process from windows 2002 to 2003 version. That is the only change that will not be lost by removing your battery.
Good Luck!
Dec 30, 2007 | HP iPAQ H3835 Pocket PC
My PDA took a fall
First try to charge it . If it does not power on try a hard reset. If this does not work and if you are dedicated to your pda, invest a new battery Shop at (ebay, Amazon, Shopzilla,etc) batteries are easily installed http://www.fixya.com/support/p389721-hp_ipaq_h3835_pocket_pc HP iPAQ H3835 Pocket PC Troubleshooting, Support, Repair & Service
Oct 25, 2006 | HP iPAQ H3835 Pocket PC
Ipaq h3835 froze
Try a soft reset first to allow programs to terminate, then try to delete programs, if that fails to work give the hard reset another try http://www.fixya.com/support/p389721-hp_ipaq_h3835_pocket_pc HP iPAQ H3835 Pocket PC Troubleshooting, Support, Repair & Service
Sep 19, 2005 | HP iPAQ H3835 Pocket PC
HP iPAQ H3835 Pocket PC Logo
317 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
