Question about Sony PlayStation 2 Slimline Console
Fat PS2 doesn't spin discs
My PS2 doesn't spin discs for more than a half a second, with inertia keeping it going for about two. The laser is emitting a beam, as I saw the red dot appear on my copy of Gran Turismo 3. It just won't spin discs. It says "Reading disc" in the browser, but immediately goes away. It might also help to know that the laser head won't move up or down. It stays in place and it tries to focus on the disc, but it won't get anything. Any help?
    Problem Solver:
  • 6 Answers
One thing, inertia is the property of mass to resist motion. You mean momentum keeps it going for a bout two second. Dont ask questions unless you get properties of motion correct
Posted on Apr 18, 2009
  • critiki Oct 30, 2010
    Really helpful answer. One thing, "a bout" isn't a word, "about" is. Another thing, you should have written "two seconds", not "two second". It's plural, not singular. You want to be a smart arse and not help the guy, at least get it right.
PS2 Modchip and Laser Fix installation Failure ...
I bough ps2 with cracked after 3-4 days not working dvds are not read.
sometime it's working some dvds..
so plz solve my problem...
May 28, 2012 | Sony PlayStation 2 Slimline Console
Hi there, I purchased a Bush lcd/ dvd combi for my daughter 18 months ago.... All of a sudden it is not reading the dvds and automatically ejecting them, any ideas on what the problem is, and how possibly...
Hello
There are two possibilities for this fault. The first one is the spinning problem of disc inside it. If loaded disc does not spins, the mechanism will eject it. The reason for this is damaged sled motor. Sled motor is one which spins the disc inside at high speed. It can be replaced. The second reason is of Laser Pickup Unit itsef. If it does not emit laser beam, the main system circuit will recogonise as there is no disc in the tray, and play function is energised, and will eject the tray out. Check for the first one. This is most comon fault with DVD players. OK.
May 30, 2011 | Bush DVD142RC 14 in. TV/DVD Combo
My PS2 slim wont spin a disc it takes you to the game settings but nothing else
Well has it been dropped? If so more then likely the guide rail fall out of place and can easily be poped back in place. A good way to see if its your laser or guide rail is to fined the hole that when the lids closed this pin goes in the hole so the ps2 knows the lids closed and stick a piece of paper in that hole with lid opened. Now it should act like the lids closed. See if the laser produces a red beam or strange noises. Maybe even the little black piece at the back that stops the disc from spinning isnt working right. But dont get worried as theres a pin on the lid that makes the black piece pull back from the disc when lids closed so it might be stopping disc from spinng while its open. Several diffrent solutions need to know how you know its not spinning. If your just putting your head to it and cant hear it spinning then you will need to trouble shoot.
Nov 21, 2010 | Sony PlayStation 2 Slimline Console
My fat ps2 spins 1/2 a turn with no laser light showing what should i do?
More than likely the unit is not detecting a disc in the drive due to a faulty optical pickup (laser). More than likely the laser will need to be replaced.
May 03, 2010 | Video Game Consoles & Games
Disc not spinning
the laser lens may be faulting. bottom line the system is not going to work for now.
Jan 02, 2010 | Sony PlayStation 2 (PS2) Console
Ps2 powers up, but disc is not spinning and
Following could be the reasons for not spinning any PS2 disc:
  • A dirty laser. Try cleaning the laser and see if it helps. If you can see crust or dust covering the laser eye, it may not be strong enough to read anything at all. If the laser looks clean, this is probably not the issue.
WATCH this video to clean lens
  • An unplugged laser cable. These things normally do not come out by themselves, but if you opened the ps2 that was spinning OK to clean the laser and/or removed the laser to clean it, plugged it in, now it's spinning 1/2 of a turn, the laser cable may not be in securely. If it is in securely, make sure it is plugged into the motherboard end properly.
  • A dead laser. On models 30001, 35001, and some 30001R, this is the most likely issue. These models are old and the original lasers were a bit unreliable.
No Spin At All If your spindle hub is NOT SPINNING AT ALL, NOT EVEN 1/2 OF A TURN, it may be bad or unplugged. A tell tale sign of it being unplugged is if you hit eject, the laser moves down the rail, and starts grinding because the PS2 keeps trying to move it down the rail even though it hit the end. There's a small switch on the spindle hub that tells the unit to stop pushing the laser because it's reached the end. Spindle hubs usually do not go bad by themselves, usually either the PS2 too a bad fall and it became bent [try spinning it by hand], or someone the cable out and put it in too many times [or incorrectly] and the silver contacts on the cable were detached.
Nov 18, 2009 | Sony PlayStation 2 (PS2) Console
My Slim PS2 discs won't spin. I just replaced the laser...
put some wieght on the ps2 disk cover flap eg a game cover that fixed mine otherwise i would trash it man ;)
Jul 26, 2009 | Sony PlayStation 2 Slimline Console
My 50001 Ps2(Fat) is making a Grinding noise...... I know what it it doing....The laser mover motor is moving and the laser is just coming off the Gold rail.....the other 2 rails are nice and smooth and...
okay, try this. hope this helps. what you're looking for is a post by Nintendoman (kyle)(#2186); post date saturday, Dec. 31,2005 to fix that grinding noise --> mattread.com/2004/01/ps2-disc-read-error-fix also try www.powerfulguides.com/ps2 ;D
Jun 07, 2009 | Sony PlayStation 2 (PS2) Console
PS2 won't work at all
The laser or main power unit might of died i would just go buy a new one there not that much and these problems will probaly run u more than the new one.
Jan 12, 2009 | Sony PlayStation 2 (PS2) Console
Sony ps2 read disc error problem
Now this is strange PS2 hangs up..............!!!wHich pS2 u have.........???slim or the old fat one.........???As far as disc read errors are there, u should clean ur lens by using some lens cleaner CD or do it manually[for fat one] urself it not a big deal........becarefull while opening the cover....clean the dust on lens with the tissue or any other light material......the problem can also b with ur disc change that also...........
Sep 17, 2008 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 Slimline Console Logo
941 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
