Question about Maytag MDE2400AYW Neptune Electric Dryer
Mde2400ayw thermal fuse
I replaced the heating element as there was a break in a coil, but once replaced, only half of the new coil is heating up. what is wrong?
SOURCE:
SOURCE: Maytag dryer: pye2300ayw
I had the same problem last month. My heater element broke in two places. This created an electrical open that prevented the heater from functioning. I replaced the heater element and my problem was solved.
In order to check your heater element: With the machine unplugged, disconnect one wire to the heater element and then use an ohm meter or multimeter across the heater element lugs to read resistance. Infinite ohms = open circuit.
Posted on Nov 04, 2008
  • 2715 Answers
SOURCE: Dryer not drying
Locate the heater element ,disconnect one or both ends. ohm it out with an ohm meter. Zero reading means tha it is open and needs to be replaced. Maxium or full; scale reading on the right side means that it is shorted and needs to be replaced. Middle reading on the meter and I would look elsewhere,such as;  Voltage coming to the element if you are used to dealing with 220 volts, live.
Posted on Nov 24, 2008
  • 163 Answers
SOURCE: Maytag MDE2400AYW Dryer Heating Elements not staying on
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
  • 686 Answers
SOURCE: Thermal fuse in Maytag PYE2300AYW not plugged in
NO. YOU ARE OK YOUR DRYER SHOULD ONLY HAVE A HIGH-LIMIT AND A CYCLING THERMOSTAT. YOU CAN LOOK AT YOUR DRYER PARTS AT www.repairclinic.com ENTER MODEL NUMBER SCROLL DOWN ALL THE WAY CLICK THE RED 100 AND SEE ALL.
Posted on Apr 13, 2009
SOURCE: Maytag Performa PYE2200AYW Dryer Heats intermittently
i had the same problem with my dryer and i installed the wrong thermal fuse for gas dryer which calls for a pink thermal fuse in which i installed and it works fine also check the lint in the front of your dryer. also my dryer which is the same make as yours seems will run on the fluff cycle until i replaced the right thermal fuse. my dryer run exceptionally hot and eventally shut down and it only run on the fluff cycle for any length of time.
Posted on Sep 22, 2009
My dryer is not heating at all where to I find the thermostat and coils? Thank You
Most dryer heating elements are incased in a metal type box behind the dryer. It looks like the size of a shoe box for the most part, the heating element or coiled wires are inside that box, most of the time the coil wire breaks and will not get red/hot and will not heat at all. I've replace the heating element on my dryer, wasn't that hard to find and remove and examine that the coil was broken not making contact any more.
Mar 05, 2015 | Dryers
WHY WOULD IT NOT BE HEATING UP
This means your heating element has burnt out. Usually they consist of a coil, much like you can see on a hair dryer, in line with the air intake. Most common cause is the coil burning out due to excess lint and severing itself. When the coil breaks electricity cant travel from positive to negative so the coil stops heating up. Look online, try sears, type in your model number followed by - heating element - . You should be able to find your model number in the manual or by searching the name of the dryer. If you get the heating element and pay someone to install it, you should not have to pay more then getting a new dryer.
Nov 08, 2013 | Dryers
Dryer heat not working
Without knowing your problem, I would guess that the heating element has burned out. This is a common issue with many dryers, regardless of brand.
The hearing element in a clothes dryer is like any other heating element, such as in a space heater, heat gun, or hair dryer. It is basically a continuous coil that is held in place by insulators, usually ceramic.
As the element ages, the coil becomes brittle and can often break. When a breakage occurs, the circuit is no longer complete and will not produce heat.
Replacing one is fairly simple.
  1. The first thing that you should do is unplug your dryer.
  2. Once unplugged, remove the exhaust duct.
  3. Use a screwdriver to remove the electric access panel in at the rear of the dryer.
  4. Locate and remove the heating element.
  5. Inspect the element for a break in the coil. The problem is not always obvious so it may be good to do a continuity test on it.
  6. Replace part if necessary. Elements will usually run $20 or so.
  7. Assemble in reverse order and test.
This website has some really great detailed step by step instructions on replacing a heater element.
Good luck.
Jan 11, 2013 | Frigidaire FFLE2022MW Electric...
I have a whirlpool dryer that won't heat. I removed the heating element and there were no breaks in the coils. I had the thermal cutoff tested and it was bad so I replaced it as well as the part
check the little 1"long x 1/4" wide white plastic fuse located on the dryer blower housing in the lower rear area,its held in place with 1 hex head screw,if its open dryer wont heat
Mar 11, 2012 | Whirlpool Dryers
Will not heat, replaced heating element kit. still not heating
Hi denise bobby...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me thumbs up
Sep 11, 2011 | Dryers
No heat . heating element looks good no coils broke. replaced thermal fuse and themostat .now what?
Hi mikedissnts...
Check your Wiring
Sep 08, 2011 | Amana Dryers
Heating element does not turn on. i replaced it with a new one. am look to know what turns the element on.
Hi ischwensen...
Check your Wiring
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
Aug 21, 2011 | Whirlpool Dryers
Dryer heating element will not heat up i have contuanty from the two ends of the element cont. i chanched the cut-off tml couse that is what someone told me was wrong well didnt fix prob.
Try doing these steps one at a time...
Check your Wiring
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
For video and pictures on how to replace the element go to the following website:
This is a FREE answer, Please rate me
Dec 31, 2010 | Kenmore Dryers
Workes fine no heat
the temperature thermostats and or heater are bad, on electricdryers, you can ohm out to see what is defective.
There's no heat dot_lineone.gif 1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
electric dryer
1 Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
2 Thermal fuse
Oct 27, 2009 | Candy CDC266 Dryer
My dryer stopped heating up so I tried to fix the heating element. I noticed in the other one that some of the coiles broke in half so I knew this was the problem. Well I bought a new one, hooked it up and...
Could be a defective element, but it also could be your thermostats faulty...give them a check.
Normally you can only hook up the heating coils one way...I do not believe that would be the problem.
Hope this helps
Sep 29, 2009 | Whirlpool LEN2000PW Dryer
Maytag MDE2400AYW Neptune Electric Dryer Logo
237 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Craig Butler
Craig Butler
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
