Question about Speed Queen AES28AWF Electric Dryer
I have a 4 prong pigtail
My apt has a 4 prong 220 outlet my dryer had a 3 prong now i need to switch them but the back of the dryer has 3 things to hook up and my cord has 4 so what 2 go together
  • mspeach39 Apr 19, 2009
    Same problem, did the solution work?
  • Speed Queen Master
  • 1,147 Answers
Here is what I believe you have.
The 3 prong plug on your dryer is configured with 2 lines of power and 1 ground. The 4 prong receptical is 2 lines of power, 1 neutral, and 1 ground.
You will have to turn off the breaker to see how the receptical is wired by pulling it out and looking at it. You can then buy a 4 prong plug to match it and only wire up the 3 prongs you need for your dryer and leave the 4th prong empty.
Good Luck and hope this helps
Posted on Apr 18, 2009
My Gibson dryer has a three prong plug on it.I
The National Electrical Code began requiring 4-prong receptacles for 220-volt residential circuits in 2000, but it doesn't prohibit you from using your older dryer with a 3-prong cord. Instead, it allows you to change the cord so that the dryer can be plugged into a modern receptacle, and the procedure isn't very complicated. Four-prong dryer cords, or pigtails, are available at hardware and electrical supply stores, and usually cost less than $20. To make the switch, you'll need a green ground screw to attach to the dryer body so the machine can be grounded by the ground wire.
1 Unplug the dryer and move it to an accessible spot. Unscrew the plate on the back that covers the electrical terminal with a screwdriver. You'll find the cover on the back of the dryer near the bottom of the machine at the point where the cord exits.
2 Loosen the three terminal screws holding the cord. Before you remove them and take off the cord, note the colors of the screws and the wires attached to them. The screws holding the black and red wires are brass and the one holding the white wire is silver.
3 Remove the ground strap from the silver terminal. It may be a small metal plate or a length of wire connecting the terminal to the body of the dryer. You may be able to pull it out with pliers, or you may have to loosen a screw to remove it. Its function was to ground the dryer, and that function will now be served by the ground wire on the new pigtail.
4 Insert the brass terminal screws into the ring lugs attached to the red and black wires on a replacement pigtail and the silver screw into the ring lug on the white wire. Drive the screws into the same slots from which you removed them and tighten them securely with a screwdriver.
5 Drill a 1/4-inch hole in the body of the dryer within reach of the fourth wire in the pigtail, which is green. Insert a green ground screw through the ring lug on the end of that wire, drive the screw into the hole and tighten it securely.
6 Feed the cord through the notch on the terminal cover plate and screw the cover plate to the back of the dryer.
Things You Will Need
  • Screwdriver
  • Pliers
  • Drill
  • 1/4-inch drill bit
  • Ground screw
  • 4-prong pigtail
Tip
  • There usually isn't room behind the cover plate to install the ground screw. If not, it's acceptable to attach the screw to the back of the dryer outside the plate.
  • Check the grounding with a multimeter before you plug in the dryer. Set the meter to ohms, touch one lead to the dryer body and touch the other lead to the ground prong on the plug. The meter should show less than 10 ohms of resistance.
References
Sep 12, 2014 | Dryers
I have a Gibson dryer..It has a three prong plug
  • Screwdriver
  • Pliers
  • Drill
  • Ground screw
  • 4-prong pigtail
Tip
My outlet is a 110v I just needed to know if i can switch out the plug on the dryer for one that will fit my outlet cuz the prongs are differant
no the dryer if it has an odd 3 prong plug is 220v and you need to place the dryer where you have access to 220 volts.
Jun 20, 2011 | Dryers
Elkectric dryer won't start
to put it kindly depending on way you connected wires unit could be damaged,replace pigtail with three wire and outlet to original.outlet wires should be black,red and white. turn breaker off attach white to middle and red,black to sides,"either side is fine".Attach dryer pigtail in same manner with white on white and if plug in and turn breaker on.If there is no operation at this point dryer possibly damaged from previous wiring.Just remember be safe when working with electrical and ask before trying to change things that aren't the same.
Apr 20, 2009 | Whirlpool LER5636P Electric Dryer
I just purchased a new home and the pigtail of my Amana dryer is different than the electrical outlet and the dryer does not have a schematic to install a new 4 wire pigtail. Is there an adapter to change...
There are no adapters. But a dryer will accept a 3 prong or 4 prong cord. The extra green wire just needs to be connected to any screw on the dryer casing. Some newer dryers have a screw there for it..or u can just use the closest screw avalable......usually the screw for the cover works good.
Apr 20, 2008 | Dryers
Dryer electric cord
The national electrical code requires the installation of a four wire system for ALL 240 volt equipment. He will be putting in a four wire dryer receptacle. The pigtail you'll need will be a standard four wire pigtail. The way it is connected is: the red and black go to the two outermost terminals, the white goes to the center terminal and the green goes to a good chassis ground point. If there is a jumper strap from the center terminal to the chassis ground point it must be removed.
Oct 01, 2007 | Dryers
Speed Queen AES28AWF Electric Dryer Logo
316 people viewed this question
Top Speed Queen Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Kristy Heard Duke
Kristy Heard Duke
Level 1 Expert
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
