Question about Philips SA2315 MP3 Player
Driver installation I followed all the directions on the user manual and when I intalled the driver, the device manager said that the driver does not support the MP3 player.
  • 2 more comments
  • DenisL Sep 18, 2007
    Thanks for your advice, but I still have a problem. On the back of the package of the Philips SA2315 MP3 player, the requirements said that the MP3 player is compatible with Windows ME, which I have. But when I tried to update the Windows Media Player for my computer, the latest update that was compatible for Windows ME is Windows Media Player 9. I downloaded that, and it didn't solve the problem that I had with my drivers. Should I try to download Windows Media Player 10 for windows ME?
  • DenisL Sep 19, 2007
    I tried that but it didn't work, it said that it can only be used with Windows XP.
  • cwecwe Feb 26, 2008
    can;t get lock off, don't know where to plug it in my computer.
  • fire fare Mar 03, 2009
    usb device not recognized
Yes
Posted on Sep 22, 2008
  • 626 Answers
Most of the newer MP3 players use the drivers built into Windows media Player 10 and newer. I would suggest checking the version of Windows Media Player. Best of Luck.
Posted on Sep 17, 2007
  • Timothy D
    Timothy D Sep 18, 2007
    I would try upgrading your Windows Media Player to version 10.
    Best of Luck.
SOURCE:
My netbook have not cd. Where can I find the drivers oh Nu Tech Dolphin mp3??
Hi martacornet...
Go to the following webpage and download and intall the firmware (driver) you need, there is also a user manual there at the same webpage..
Please take time to rate me 4 thumbs up
http://www.nu-global.com/service.aspx?id=4#C_00000019
Sep 03, 2011 | NuTech Dolphin MP3 Player
Hi, my pc don't read the mp34 audio player =( help!!!
Why is my mp3 and mp4 player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see mp3 and mp4 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the mp3 and mp4 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: mp3 and mp4 Players can connect to your computer in MSC or MTP mode. Exceptions are mp3 and mp4 Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for mp3 and mp4 Players when used with Windows OS.
The mp3 and mp4 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
May 05, 2011 | Digital Audio NAP256 MP3 Player
When i installed the media player into my computer. i get a little screen saying usb device not recognized. one of usb devices attachedto this computer has malfunction,and windows does not recognize it....
Hi, smpk4083 mp3 player not recognized by the computer
Why is my smpk4083 mp3 player not being detected by my computer when I connect it?
4. Power issue.
- Run the hotfix.
For MAC users, see smpk4083 mp3 player not recognized by a MAC OS
STEP 1 - Connect the smpk4083 mp3 player to the PC
NOTE: smpk4083 mp3 Players can connect to your computer in MSC or MTP mode. Exceptions are smpk4083 mp3 player Connect and smpk4083 mp3 Express which only use MTP mode. MTP mode is the recommended and default method for smpk4083 mp3 Players when used with Windows OS.
The smpk4083 mp3 player will show up on Device Manager's right pane as:
Hope it helped.
Have a nice day,.
Feb 22, 2011 | Sylvania Audio Players & Recorders
Not connet on computer
Hi, Sony NWZB133F MP3 Player not recognized by the computer
4. Power issue.
- Run the hotfix.
For MAC users, see Sony NWZB133F MP3 Player not recognized by a MAC OS
STEP 1 - Connect the Sony NWZB133F MP3 Player to the PC
NOTE: Sony NWZB133F MP3 Player can connect to your computer in MSC or MTP mode. Exceptions are Sony NWZB133F MP3 Player Connect and Sony NWZB133F MP3 Player Express which only use MTP mode. MTP mode is the recommended and default method for Sony NWZB133F MP3 Player when used with Windows OS.
The Sony NWZB133F MP3 Player will show up on Device Manager's right pane as:
Have a nice day....
Feb 22, 2011 | Sony NWZB133F MP3 Player
No audio output device is intall
I also could not find recovery manager, and I also did not have the option when going to device manager and selecting action to scan for hardware changes. However, I fixed the problem by these steps:
1) Go to device manager
2) Select sound, video, and game controllers from the list, and select high definition audio device when it drops down
3)New window opens. Select the driver tab. Click uninstall.
4)Then after it is uninstalled, go back to device manager window.
Select action, and THEN you will have the option of scanning for hardware changes.
Select this option and it will reinstall and the problem should be fixed.
Jan 20, 2011 | Audio Players & Recorders
I dont have the manual my MP3 104 came with because it was a gift but how can I get my computer to recognize it again Correction: Archos 104
For Windows XP users: verify the following operating system requirements are met. - Windows XP SP2 or higher - Windows Media Player 10 or higher
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. - Download the hotfix from http://support.microsoft.com/kb/939211. - Run the hotfix.
Next:-- Refresh the driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. NOTE: - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Next - Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. ffffff
Sep 18, 2010 | Archos 104 MP3 Player
Hi we got the mp3 player for the kids for christmas and when connected to the computer it says it is not rocognized. what do i do now?
For windows vista/7;
Press start
In the search box type in deviceman
In the search results press Device Manager
Depending on your security settings press Yes on User Account Control.
In device Manager, Right click the device with the triangle and the ! in it.
Click "Update driver software"
Click on the top option.
Your driver software should be installed.
The mp3 player should be linked up to your computer.
For windows xp
ALL the steps are the same from getting inside device manager.
Press the Windows Key and R together.
It should bring up Run.
Type in;
devmgmt.msc
Follow the steps from above
Dec 26, 2009 | Audio Players & Recorders
Free intalation
1st You download Webcam Driver.
Free intalation
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Nov 09, 2009 | A4tech PK5
I cant get in my computer but its showing in device manager
As you tell the device in can only be detected in the device manager.
It can not be seen as a removable disk in MSC mode and neither in MTP mode, showing as media player with the Sans icon.
Consult next page about 'player not being recognized':
http://kb.sandisk.com/app/answers/detail/a_id/42/kw/manager/r_id/101834
Refresh the drivers or manually ad the driver for the player as described.
Sansa manual for e200 series (version 2):
http://mp3support.sandisk.com/downloads/um/e200v2_userguide_en.pdf
Important:
1. Check the system requirements of the computer as described in the manual on page 8 of the file [=page 5].
2. Charge the device using an USB connector directly to the computer,
not through a hub or card reader, preferred at the back side.
If more help is needed, just post a comment.
Sep 28, 2009 | SanDisk Sansa e250 MP3 Player
Device manager shows error in sm bus controler
goto to system devices look for the question mark, right click, and try reinstall the drivers again, this should normally work and reboot your machine and the drivers should be there.
may be the bus driver you are trying to install may not be compatable for your machine, check with the user manual to see what bus derivers you can install
Nov 17, 2007 | Computers & Internet
Philips SA2315 MP3 Player Logo
154 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
