Question about Craftsman Garden
Have a craftsman lawnmower with a tecumseh engine,model #917.377580. 6.75hp. I was having a problem starting my mower when ever it was hot. It seemed to load up with gas and flood out. So i replaced the float,needle and seat etc. because on this carb it is sold as a unit. the bowl is held on by a clip from the upper half of the carb. There is no bolt that screws up into the center of the bowl like on most carbs , just a plastic tube inside that goes up into the carb. Anyway I cleaned the upper half and blew out all holes and attached the bowl half. Now I am having trouble keeping it running and if it does run the engine surges. Could this bowl unit be defective, I see no adjustments for the float and needle to let more gas in. What kind of carb is this? I am not familiar with it and have no idea how to make adjustments. please help. this carb has no bolt the main jet is inside and is brand new,all holes are clean.
3 Suggested Answers
  • 109 Answers
SOURCE: lawn mower running problem
There are no adjustments for the carb., however, in the bolt that holds the bowl on, there is a small hole in the threads that must be clean in order for it to run right. It is a real small hole on either the 3rd or 4th thread from the top.
Hope this helps
Posted on Apr 17, 2009
  • 279 Answers
SOURCE: 5 hp tecumseh mower. plug is firing. carburator
Check the flywheel key. It is the most common problem I have found when a Tecumseh either wont fire or backfires. When you have the flywheel uncovered, take a nut the same thread as the flywheel. Remove the one from your machine and use the other one for the next operation. Take the new nut, place it on the sshaft in place of the one that was there. Lift the flywheel with one hand (to get a strain on it) and with the other hand, rap the nut with either a wood mallot or a regular hammer. You may have to rap it sharply. The flywheel will come loose and you can see the problem. Go to a small engine repair shop and get a new flywheel key. Install it and go about your cutting. Good luck...Lee
Posted on Sep 04, 2009
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
I have a Murray 20 model 20213A with a Tecumseh engine. The lawnmower will start but it dies a few minutes later. What could cause this and where can I get a manual for this model lawnmower?
Use high test fuel without ethanol, and
Murray 22" Lawn Mower - Carburetor Cleaning, Nasty ...
? 7:33
www.youtube.com/watch?v=_dzcDZUh1MY
May 10, 2013 - Uploaded by mountainbikekayak But here is the link for the start up of this Murray had to replace the plug as well also ... as well: Murray 22" Lawn Mower 6.5 HP OHV -- First Start after Carburetor Cleaning - Part III - May 9, 2013 ... When I start it, it runs for 3-4 seconds and dies. ... Youcan also find you engine Model # online and view the ...
Sep 09, 2015 | Tecumseh Garden
How do i take off the pull start from a craftsman model 917.377582 lawnmower
engine numbers would be helpful buttttt.... the perimeter of the recoil assy should be 3-5 small screws. remove them and it should come off, the is as long as you have a eagerbeaver engine ( tecumseh ohv )
Apr 15, 2015 | Sears Garden
Hi, what kind of oil can i put in my ridind lawnmower craftsman?
The domestic engines (Briggs, Tecumseh) take SAE 30 weight motor oil. The import engines (Honday, Kawasaki) usually take 10W30 motor oil. In either case, I recommend using a good quality name brand oil like Castrol, Pennzoil, etc. Most riding mower engine take about 48oz from a complete drain. If your engine has an external filter, it might require a few more ounces.
I hope this helps.
Aug 27, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Brand new lawnmower. Trouble starting and when it does start it has no power. When you move it to cut grass it konks out
Does it have a Tecumseh engine? If so it sounds like a broken or bent flywheel key. It may be a flywheel key on any engine but the Tecumseh seems to break easier. That is not a bad thing because the reason they break is to reduce other, more expensive breakage in the engine. If you need help replacing it, write..Good luck...Lee
Sep 20, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Wiring diagram for 10 hp tecumseh motor.
no worries go to searsparts.com type in your model # and follow the prompts you can then print it out for free ?
Aug 27, 2009 | Garden
6.75 Craftsman Eager1 Lawnmower, My son had this mower given to him,after cleaning the carb,plug,air cleaner etc. I noticed a black rubber tube entering the top of the motor at the back, upon starting the...
Go to parts www.searspartdirect.com and put in the model # and it will display all the parts that are supposed to be on the mower. Whatever you are missing just order from them.
May 16, 2009 | Garden
Cylinder head torque specs
Cyl. Head Bolts torque
200in.lbs
16.5ft.lbs
22.5Nm
Mar 26, 2009 | Craftsman Garden
Garden Logo
683 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
