Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Starting motor ok, but sounds liKE starter bad!!
I have a 19.5 hp craftsman 42" deck, motor started fine but sounded funny for a while now, motor won't turn over at all.
  • Noel Coward
    Noel Coward May 11, 2010
    Could you Please explain Funny sound also Does it have Oil,
  • 246 Answers
Hello beadingblond:
>>Check the Valve Clearances. If the Valve Clearances are Not Correct the Compression Release Does Not Operate as Designed and the Starter will seem to be Dragging.
>>Also, Is the Crankcase Oil Overfilled and Contaminated with Gas?
Respectfully
John
Posted on Apr 21, 2009
My craftsman riding lawnmower will not start unless jumpstarted off the starter and while mowing the blades will stop turning even on the two highest setting for the deck and the grass isn' t that high?
Sounds like your starter is bad and that could be causing your blades not to work if you have a cvt type clutch. If you don't i would check your belt it may be stretched out.
Apr 11, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman 15.5 HP 42"
Hi government32, seeing how you just installed a new battery I'll assume you cleaned all the connections. Not cranking at all sounds like 3 possibilities, Key switch, starter solenoid, or starter. Lets check starter first. Using a jumper cable, jump from positive battery post to starter motor (you'll see the connection on the motor where cable is connected,thats where you hook jumper), if it cranks the starter motor is ok. If it doesn't thats the problem. If it does crank check the starter solenoid, using a jumper cable jump across from side to side (the 2 big terminals). If it cranks now the solenoid is bad or the electrical connections are dirty. There are also 1 or 2 small connections on solenoid from the key switch, make sure they are clean. If these 2 components check out the key switch is bad or the connections on it are dirty. (its usually not the switch).Hope this helps you.
Jan 03, 2011 | Garden
42 in. Deck 19.5hp Lawn Tractor: Craftsman Lawn tractor my engine clicks but will n...
battery has a low charge or the starting gear on the starter is bad. just remove cover and see if the starter ingages and cranks the fly wheel. look at the gear itself to make sure the teeth are good ,if not replace the plastic gear. takes 5 min.
May 18, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
20 Hp 42" Deck Lawn Tractor: I have a craftsman rider that starts idels and dri...
sounds like one of the pullies is locked up . check all the pullies for free movement the plastic pullies are junk. replace with metal ones if you find a bad one.
May 17, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman Kohler 15HP 42
it deffenetly sounds like the coil is bad . as the motor increases in temp. the coil pack expands thus loosing positive charge. change it if it has points filr them a little too remove the tartar you should have a sharp blue spark
Apr 05, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a briggs and strattan 18 horsepower engine on my craftsman mower and it wont start, i replaced the starter and it still wont start! It wont even turn over, in fact it binds the starter, but if I...
Have the battery tested at an auto parts store to ensure there is enough power in it. Sounds like it's strong enough to turn the motor with no compression (spark plug removed) but too weak to turn the motor with compression. Also check for loose or corroded wires.
Sep 20, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman Lawn Tractor - Electrical
make sure you mower deck is not still engaged. that might make it not start with that safety switch.
Oct 04, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
198 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
