Question about Audiovox D1708 Portable DVD Player
No picture I can get audio, but no picture....even when plugged into AC outlet (it used to only do that when battery was low). Any suggestions? Thanks, Kris
  • Kris Renihan Oct 08, 2007
    For all those who have had trouble with the Audiovox D1708 who can get audio but no picture....the solution was simple. There is a tiny button located between the back of the DVD player and where the screen closes. My button was stuck in the down position (note, when the screen closes...there is a knob that presses the button down and should release it when the screen is open). I used a small, pointed object to release the button and the picture came right back on the screen!! It has happened once or twice since and releasing that button does the trick every time! Good luck and I hope this helps! -Kris
  • Anonymous Jan 02, 2008
    purchased summer 2007. No picture; audio only. my model number D1708 DOES NOT HAVE THE BUTTON TO FIX THE PROBLEM as indicated in other logs with the same problem. Any suggestions?
And if that doesn't work, try carefully unscrewing the screen and the hinge and reseat the tiny connectors of ribbon wire and wiring harnesses.
Posted on Nov 18, 2007
AC Power Failure
Providing that you the outlet is putting out proper voltage, check the voltage output of the plug in transformer. Used a voltmeter set to AC and attach the leads under the plug in transformer (where the wire normally go) and plug back into the outlet. The voltmeter should be reading around 9 volts AC. If there is no a low or no reading, you have a bad plug in transformer. It can be replaced with a 9 volt AC 25 volt amp transformer. Battery may also have to be replaced, if it is depleted. If this does not fix the problem, you have a bad panel and it will need to be replaced.
Jul 26, 2012 | GE Security Simon Xt Wireless Control...
My remote speaker system works with the batteries but not with the AC adaptor plugged in to the speaker.
I would suggest to check AC outlet first where adaptor is pluged in,if Ok measure output voltage from adaptor to see if there is any (using any voltage multimeter with AC/DC)
Check label on adaptor shold be writen AC or DC output ,and value 3V,6,9,12,24,48 etc...
If adaptor is ok then problem is power jack mounted in to the speaker (cold solder joints' or damage)
Aug 23, 2011 | Audio Players & Recorders
There is a significant high pitch running through my speakers. I checked speaker wires, & plugged in power cord into a different outlet. Still no luck. Any suggestions?
Disconnect the input(s) and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights. Sometimes, simply reversing the orientation of the ac power plug can eliminate humming.
Mar 06, 2011 | Harman Kardon AVR 300 Receiver
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Why should my GPS indicate a low battery even though it is plugged into my AC outlet in my car?
It sounds like the unit is not being charged when it is plugged into the car. Does it come on when you plug it in, or do you have to press the power button? If you have to press the button, the charger is not sending power to the unit. Make sure it is connecting properly to the unit and that it is seated in the AC outlet correctly. If it is, check the fuse in the end to see if it has blown. If so, replace it. If that is not the problem, you may have a problem with the AC outlet in the car.
Feb 18, 2010 | Garmin StreetPilot C330 GPS Receiver
Uploading pictures
Cameras can't upload if low on power. Charge batteries or plug in the ac adaptor to an outlet and try again.
Sep 12, 2009 | Panasonic SDR-H40 HDD Camcorder
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Doesn't start up
remove the primary battery and plug the computer into an AC outlet using the AC adapter. If the computer starts up, one of the batteries need to be replaced. If the battery light on the of the comoputer is blinking, the battery has reached a low batery level, which may not allow the computer to start up. Plug the computer into an AC outlet using the AC adapter to start the computer and allow the battery to charge.
Dec 30, 2007 | Toshiba Satellite M55-S3512 Notebook
Audiovox D1708 Portable DVD Player Logo
77 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
