Question about Intel Desktop Board D915PGN - Motherboard - ATX - i915P - LGA775 Socket - UDMA100, SATA - HD Audio
Bios setting Need some help on two beeps at startup for my DG41TY motherboard.
  • 2 more comments
  • manish_54 Apr 18, 2009
    Still giving the same problem...I have tried this many a times. It has also given a message that memory size decrease. Kindly help.
    Do I need to change the RAM and buy new one.
    I have only one set of RAM and two slots. I have tried to push RAM in both slots and it keeps on giving the same beeps. Probably RAM do have some issue. Will buy a new one and see if it works.
    Thanks Buddy for your support...
  • 272 Answers
It is a problem with your RAM. Please try remove and replace the ram tightly on that port or another one. It should solve your problem.
Posted on Apr 18, 2009
  • Fixer Apr 18, 2009
    memory size decrease means less memory then the last startup. please try one Ram at a time on different slots. Seems, you have more than one.
    surely the Ram is the problem, Thanks
Computers doesn't startup and has no beep
remove the RAM chip and start the computer without the ram chip inserted and see if you get beeps if yes the motherboard/bios is ok, even if you dont get to hear any beeps, try rubbing the edge of the ram which goes into the ram slot using a Eraser and then reinsert the same back in Ram slot and then see if you can at least get to bios and see if hard disk is detected as windows boots from hard disk if yes check if you can boot to windows if no may need to reinstall windows.please reply with results so that can help
Feb 22, 2012 | Foxconn (945G7MA-8KS2) Motherboard
Startup beep on intel mb dg41ty --- how do you turn off the onboard speaker??
click start control panel sounds and audio devices select advanced place a tick in the mute box
this might vary depending on your operating system
if you want to fix the beeps check your computer ram make sure they are securely seated with no dust built up also Cmos battery also check all leads from motherboard to hard drive make sure they are securely seated with no dust built up
hope this helps you
Jul 21, 2011 | Intel Classic DG41TY Desktop Board - G41...
Sir namaste! coumputer farmet ke liye xp cd dalne ke bad kaon sa buttan press karna hai?
cd andar dalne se pehle ye dekh lo ki tumne apne bios set kiye h ki nahi
1. bios check karne k liye computer restart kare or boot screen aane se pehle DEL DEL lagatar press kare.
2.jab tumhari bios settings ka window aa jayega to boot device set is tarah se karna-
1st boot device (cd rom)
2nd boot device (cd rom)
and 3rd set karna jaruri nhi hai.
save karke exit karte hai.
ab fir restart kareke dekhna ki " ENTER FOR BOOT FROM CD OR DVD " aata hai ki nahi.
tum youtube ki is link me bhi dekh sakte ho-
http://www.youtube.com/watch?v=n0cop_am1WM
ye 100% work karega.........
Jul 20, 2011 | Intel DG41TY Motherboard
Dell 1525. I get a continuous beep on start up. What could be the problem?
A single continuous beep on boot up usually indicates a stuck key on your keyboard.
Mar 05, 2011 | Dell Inspiron 1525 Notebook
Mother board does not make beep sound
this could be just about anything. Check to make sure the power supply is plugged in to all the correct ports, check to make sure the RAM seated properly.
Mar 05, 2011 | Intel Motherboard
My 8i845gvm-rz motherboard giving me continuous beeping sound, I am not evern able to go in startup/ BIOS settings.
Hello
OK, because there is different beep codes for different problems, hence, you will need to be more specific on the particular beep code you are getting.
Please let me know when you have the sufficient information.
Kind regards
Andrea
Aug 29, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
My bios speaker will beep on startup but nothing more. What avenue should I approach to get past this part of startup?
First you need to know which BIOS you have and how many beeps it is producing... these beeps are the POST - Power On Self Test. They tell us if there are problems such as missing keyboard, video card not working, memory faults etc...
Then you need to go to the appropriate BIOS site and see what the number of beeps mean.
If it is a single beep - it means all is well...
As you are not getting anything more you should check to see if the Hard Drive (HD) light flashes - if so - the HD is probably operating ok and loading your system but there is either a problem with your monitor or video card... borrow another monitor and see if that helps...
But it all depends on the number of beeps you get and what kind - long and short beeps (like morse code).
If this helped you at all please vote!
Oct 06, 2009 | Asrock M266A Motherboard
No Beep sound during startup. Motherboard or Processor ?
ok
pull cmos cell for 15 minute then check so all settings of bios are reset.
Also Refix RAM memory reattach all connection to motherbord.
Jul 16, 2009 | Asrock P4I45GV R5 Motherboard
Motherboard keeping beep and the computer can not startup..
Different kind of beeping have different meaning.. But, the common problem is your hardware allocation on the board. Just try to pull out the ram and insert it back. Do this also on your vga card. By the way, what type bios do you use? e.i : pheonix, award, IBM. Explain the type of beep of your computer.
Sep 24, 2008 | Foxconn WinFast K7S741MG Motherboard for...
Intel Desktop Board D915PGN - Motherboard - ATX - i915P - LGA775 Socket - UDMA100, SATA - HD Audio Logo
189 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
