Question about Mitsubishi WD-52525 52" Rear Projection HDTV
No signal, blue screen
Ok my mitsubishi WD-52525 is not getting a signal from any inputs. There is a blue screen with lighter wavy stip in the middle horizontally. Even a simple video game plugged into the front won't go on. I can turn on my DVD and hear the sound, but no pic from cable or DVD. Doesn't seem to fit criteria for a new lamp. Green status light is still constant. Any ideas?
  • Anonymous Mar 31, 2014
    that's all the problems i have for now
    Genius:
  • 1,153 Answers
If no video and OSD is good then: Suspect the Signal PCB part # 930B923002
Posted on Sep 18, 2007
Mitsubishi wd 52525 lost greens and blues. only colors on screen are red hues.
This the classic symptom for component input wires being crossed. Check color coding on tv input and signal sourse. Green,Blue and Red wires must correspond. If ok Is the color off on the tv menu also. If so and wires are ok replace light engine.
Nov 03, 2009 | Televison & Video
Blue screen and steady green status light.
mitsubishi will rebuild the chasis for $200 with a 6 month warranty
mits.parts 1-800-553-7278
fax 1-706-654-4299
Sep 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Wd-52525 can no longer connect with any input deviced, and is fuzzy in the middle of the screen.
I would "reset" the entire tv (like when you first got it) and make sure all input devices are ASSIGNED correctly and each of those has a physical connection that is good. Can you access "setup" OK?? If OK, there is a known problem with the "input board" on some Mits...not an easy or cheap repair.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD 52525 blue screen on all inputs
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
Jun 03, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blue screen on tv
DID YOU TRY TO CHANGE THE CHANEL MANUALLY? OR CHECK THE INPUT BUTTON
May 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blue screen on WD-52525
Hi, Standby i'll sent you how.for a while
Apr 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525
Normal 0 The Mitsubishi WD-52525 has a serious capacitor problem as discussed in this forum overseen by a Mitsubishi certified repair technician: http://www.hometheatershack.com/forums/mitsubishi/11703-problem-mitsubishi-wd-52525-scrambled-picture-no-picture-2.html. There has been a worldwide problem in computers and TVs over thepast several years with faulty electrolytic capacitors (from Taiwan) thatdecay, dry out, swell and die. The power supply is often the firstcomponent to go bad, but other systems also degrade over time. As theforum explains , this problem is widespread in these sets causing multipletypes of display problems after several years of use. On my set, I also got a blue screen with a lighter blue ball in the middle. Mitsubishi is awareof the problem and will cover most of the cost of repairing the chassis, evenyears out of warranty, but apparently ONLY if you get an estimate from aMitsubishi certified repair station and contact their customer support BEFOREdoing any work on the set. I just followed the recommended procedure onthat forum and Mitsubishi is covering half the cost of my $700+ repair when my3+ year-old set recently died and showed only this blue screen on all inputs.
Mar 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Watching dvds
Good Day;
Make sure you have proper input selected, blue sreen normally means you have no video signal.
Good Luck, big IRISH.
Aug 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Unable to receive input device signal
Can you post a picture of the screen so I can properly diagnose it. It sounds like the caps on the FMT PWB but a picture would help me be certain.
Aug 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
T.V. Problems
sounds like the capacitors on the FMT or Signal PWB need to be replaced.
Jul 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
154 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
