Question about Toshiba Satellite A135-S2276 Notebook
Wiring diagram for lc-xnb4m elki projector to laptop
Projector is not project data from laptop
Try to lower the output resolution of your laptop for external display to
800 x 600, which is the native resolution for your SB20
Mar 29, 2011 | Eiki LC-SB20 Projector Multimedia...
Can't hook up my laptop to play DVD's through my Eiki LC-XNB4M
computer should always be connected with 15 pin VGA to DVI-I cable.
Select in menu input 1 analog RGB and adjust output resolution of Dell to 1024 x 768. this should work !
USB is only for mouse control with pj remote
Jul 09, 2010 | Eiki LC-SM4 Multimedia Projector
Giving message on laptop that says, "projection mode disabled"
try to use a full wired VGA cable, so the laptop can recognize the external display/ projector by the ID pins.
Many laptops deactivate external display ports to save energy
Mar 18, 2010 | Eiki LC-XB15 Multimedia Projector
In few minutes after turn on the projector (Eiki Lc-xnb4m) , it shut off automaticlly. and i connect notebook with the projector ,no any reaction. i don't know how to operate it?
are any of the leds flashing? could be overheating. blow out the dust with canned air. if the lamp is old, it could be that it needs to be replaced. if the fans go out immediately as well, it could be the power supply.
Aug 22, 2009 | Eiki LC-XE10 Projector Multimedia...
My eiki LC-xnb4m will power on but shuts off after about 60 seconds. It doesn't shut off completely.it just drops the input signal (audio and video) and the fan kicks on heavy for a few minutes. Then...
may be overheating. blow out the projector with canned air. the dust keeps in the heat that the projector is trying to expell. also check the lamp for bulges and dark spots. if you have any of those, replace the lamp. if the lamp is new, check the colorwheel for a high-pitched whir. if you don't hear it, replace the colorwheel. otherwise, replace the ballast.
Jul 01, 2009 | Eiki LC-XE10 Projector Multimedia...
Laptop won't project onto Eiki
The signal type settings wrong in the menu, or broken interconnection between input board and mainboard of projector, due to shocks during portable use.
Jun 10, 2009 | Eiki LC-XB20 Projector Multimedia...
New projector. which cords do I need?
laptop, vga. dvd, composite or s-video, and audio. gaming console, composite or hdmi, if you have it.
Feb 27, 2009 | Eiki LC-XB20 Projector Multimedia...
Eiki LC-xnb4m computer connection issue
I actually fixed it myself--I found another site that said for Dell systems, you need to hold down the Fn button (bottom left) and push F8 and then it recognizes the projector. Solved the problem immediately!
Jan 27, 2008 | Office Equipment & Supplies
Toshiba Satellite A135-S2276 Notebook Logo
49 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
