Question about Motion Computing MOTION LE1600 Notebook
Forgot password im looking for the manual to see how can i get to bios set up to restart the computer to the original version
  • 272 Answers
If this is a desktop computer, look for the bios flashing button on the motherboard or just remove the CMOS battery from the motherboard ( possibly located below the RAM slots ) that is like a coin. and place the battery back after 1/2 minuets. It will clean the BIOS password.
Posted on Apr 18, 2009
Tip
TRICKS AND TIPS ON HOW TO ACCESS THE BIOS/CMOS WHENEVER YOU FORGOT THE PASSWORD
BIOS PASSWORD ARE USED TO SECURE YOUR COMPUTER BY PREVENTING OTHER USERS TO ACCESS YOUR COMPUTER'S BIOS SETTING OR MAKING IT UNBOOTABLE REQUIRING PASSWORD.
But in some cases, some people forgot the password.
HERE ARE THE TRICKS AND TIPS ON HOW TO ACCESS THE BIOS/CMOS SETTING WHENEVER YOU FORGOT THE PASSWORD.
SOLUTION1. RESET THE BIOS PASSWORD USING DOS COMMAND PROMPT.
1. Go to start menu and choose RUN. For other operating system like Windows 7 and Vista, just use the search bar and type the command prompt. Right click mouse and run as administrator.
2. type the word "debug" and press enter
3. type the code "-o 70 2e" and press enter
4. type the code "-o 71 ff" and press enter
5. type the letter "q" and press enter
6. type the word "exit" and press enter
7. try to restart your computer and it will remove the bios password.
SOLUTION 2. TRICK THE COMPUTER TO GENERATE BIOS PASSWORD.
Some computer can generate bios password when you enter 3 different incorrect bios password. Below message will appear:
Password check failed
Fatal error...System halted.
CNU9117K31
Use the last line as password. CNU9117K31
SOLUTION 3. USE BACKDOOR PASSWORDS
AWARD BIOS
AWARD SW, AWARD_SW, Award SW, AWARD PW, _award, awkward, J64, j256, j262, j332, j322, 01322222, 589589, 589721, 595595, 598598, HLT, SER, SKY_FOX, aLLy, aLLY, Condo, CONCAT, TTPTHA, aPAf, HLT, KDD, ZBAAACA, ZAAADA, ZJAAADC, djonet
AMI BIOS
AMI, A.M.I., AMI SW, AMI_SW, BIOS, PASSWORD, HEWITT RAND, Oder
OTHER PASSWORDS:
VOBIS & IBM - merlin
Dell - Dell
Biostar - Biostar
Compaq - Compaq
Enox - xo11ne
Epox - central
Freetech - Posterie
IWill - iwill
Jetway - spooml
Packard Bell - bell9
QDI - QDI
Siemens - SKY_FOX
TMC - BIGO
Toshiba - Toshiba
In TOSHIBA BIOS, just hold left shift key during booting process.
For IBM APTIVA BIOS, press both mouse repeatedly during the boot.
SOLUTION 4. CLEARING THE CMOS JUMPER OR DIPSWITCH SETTING.
Go to your motherboard and look for jumper should be located near bios chips or near the battery. THere is usullay 3 pin switch two of them covered with this jumper.
Procedures :
1. Turn off your computer.
2. Unplug the power cable from the power supply unit.
3. Wait for 30 mins to be safe that your motherboard is fully discharged.
4. Locate the jumper.
5. If there is 3 pin switches, the jumper shows would be in 1-2 position. Just place it in 2-3 position with a few seconds and then return it back to normal position 1-2 position.
6. If there is only 2 pin switch, just remove the jumper with a few seconds and then place it back to normal.
7. Connect all the connection and restart your computer. It it will reset the bios setting.
SOLUTION 5. REMOVING THE CMOS BATTERY
If the jumper switch solution doesn't work, try this solution by removing the cmos battery.
Procedures:
2. Remove power source cable.
3. Go to your motherboard and remove cmos battery.
4. Wait for 30 mins or more before returning it back.
5. Place the battery back correctly
6. Plug your power cable and start your computer and it is done.
GOOD LUCK AND I HOPE THIS WILL BE HELPFUL FOR OTHERS.
on Dec 19, 2010 | Computers & Internet
Forgot admin password cannot how to reset admin password gateway lt2104u
Look on Ebay for a password reset disk. Many vendors on Ebay sell a bootable "linux" disk that you boot from and then you can edit your password file on Windows. I have versions for XP/ Vista.Windows 7.
Be sure to get one that works for your version of windows. You must set the BIOS to boot from the CD drive first for this to work. About $5 to $10 for the reset disk.
Regards,
Dennis
Apr 18, 2014 | Gateway LT2104u Netbook
Windows password
hello
If you forgot your windows password, try to use the last version of Hiren's boot CD/DVD or USB..here are the steps to fellow :
1- start your computer and go to its BIOS, verify if CD/DVD is the first in the boot list. if not, do it.
2- put the Hiren's CD/DVD in your CD/DVD drive.
3- restart your computer.
4- your computer will restart from Hiren's CD/DVD. the view is similar to windows 8. ( this depends to the version of Hiren's you are using ).
5- go to the control panel and choose " user accounts .."
6- then go to " change your windows password " if you want to change it or " remove your password " if you want to remove it .
7- confirm by clicking on " change password " button below.
good luck
Apr 08, 2014 | HP 17.3" Envy dv7-7247cl Laptop PC with...
I forgot the BIOS password someone told me to remove battery and put it back but i cant find the battery
The BIOS Battery, to be precise CMOS battery looks like:
When your PC is turned off, your computer saves information about time, bios options and others with the help of CMOS battery. Try to remove it, wait a few minutes and set it back again. This action might cause to reset your BIOS password.
May 10, 2011 | Acer Aspire L100 PC Desktop
Ideo hdd password is frozen acer is my laptop.. im just only partitioning my laptop coz i want to dual boot. my orig os is windows 7 when im istalling the xp the appear the blue screen. and then i think...
If you have forgot BIOS password then you have to reset CMOS jumper setting. Please follow the below steps: Open the Laptop back panel. Locate the CMOS battrey, remove it & then with the help of a screw driver keep on pressing the terminal inside it and turn ON the computer for 10 secs and Turn Off (make sure you keep on pressing the terminal with a screwdriver while turning ON). It will clear the BIOS setting. Now, fix the CMOS battrey & restart the computer. This will take care of the issue.
Thanks and regards,
Jitha
Feb 10, 2011 | Computers & Internet
I forgot my password how can i get it back thanks
Are you using window? If so:
Locate and download a program called "OPHCRACK"
Insert disc and restart computer:
Set your bios to start from the CD:
Just press F8 or whatever the screen says for the BIOS settings and/or options..
Set the boot option order to CD first rather than second or third.
The program will run and it will start to recover the passwords(s)
Jan 25, 2011 | Microsoft Windows? Vista Home Premium...
Im locked out i forgot my password
Thanks and regards,
Jitha
Dec 19, 2010 | Acer Aspire M1641-U1521A PC Desktop
Cannot open bios set up forgot bios password
Reset the motherboard BIOS. To do this:
1. Open your computer casing where the motherboard lies in.
2. Look for the BIOS jumper settings. It should be near the battery.
3. And there reset the bios settings. (To do this, refer to your motherboard manual.)
4. Once already done. Close the casing and power up your computer.
See how it works.:-)
Nov 03, 2009 | Intel D850MV Motherboard
I forgot the security password
here are 2 password type first 1 is bios password if tell me about your bios password it prompt when u powerup follow procedure below
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Then it not want password.
And if u tell about windows password
Then when you power up the computer press F8 key then enter in safe mode then wait until it prompt for user password
then enter in administrator then if u able to enter then reset your password.
But if u set and forgot default administrator password then u should need winxp recovery disk.
Aug 08, 2009 | Acer Aspire 5580 Notebook
Computers & Internet Logo
196 people viewed this question
Top Motion Computing Computers & Internet Experts
David Payne
David Payne
Are you a Motion Computing Computer and Internet Expert? Answer questions, earn points and help others
