Question about Sceptre X20g-Naga III 20.1" LCD Monitor
Scepter LCD not working, can't disassemble
I have a 20'' Sceptre LCD. It worked fine for about 18 months, then suddenly quit. The screen stays black, the logo lights blue (which usually meant a good signal from the computer) all the time even if it's not connected to the PC, and none of the buttons on the front seem to do anything anymore.
I'm trying to open the case for diagnostics and I've gotten stuck. I removed the bezel, but I can't seem to separate the inner metal frame from the back of the plastic case. Any suggestions are much appreciated!
  • Anonymous May 16, 2009
    I have this problem as well, and have found that it would cost $100 dollars to replace the board and $35 shipping. That == half the price of a new, much better, monitor. Sceptre sucks. Finding the parts to replace the board yourself might work in the end, if you know what you're doing and save you some money as well.
    Problem Solver:
  • 11 Answers
A little late but hey better late than never. I assume you have the screen assembly out of the plastic housing by now. The bar with buttons actually hides two out of the six screws that hold the monitor brackets in place. Pretty straight forward. Once you get the screen separated from the plastic junk, take off the thin metal protector in the centre at the back of the screen which hides the circuit boards. Should be just one screw and then slide the cover off. Make sure you disconnect the one electric connector that protrudes through the cover on the side before you remove it. Do not pull the wires, use a needle nose pliers instead. Underneath the cover you'll see two circuit boards, one with surface mounted ICs and one with capacitors and coils that the power cable attaches to. This is the board that needs repair. On this board are 4 small capacitors in a row in a small seperate section of the board. Two of those are a little smaller than the other ones. Hopefully you know what a capacitor looks like. These capacitors are rated as follows: two 470uf/25V and two 1200 uf/10V the 470s are the smaller ones. You can take the board out, make sure you disconnect all plugs and take out all screws, mark were they came from or better, take a picture if you are not faimiliar with this stuff. Then either replace the capacitors yourself or have somebody do it. The parts total about 4 bucks. Desoldering is tricky so of you have never done it, better not attempt it, get a pro to do it. When done, re-assemble in reverse order. Good luck.
Posted on Aug 07, 2009
  • 5,660 Answers
I may get a bad rating from you, but it is at this point, that I feel compelled to tell you to STOP!
Inside that LCD monitor are Electrolytic Capacitors.
The ones for this LCD monitor are of a large capacity. They hold a large voltage. They can hold this voltage for Weeks, sometimes Months!
Should your fingers cross the terminals for these capacitors, or make a connection to the circuit that one, or more might be in, the capacitor, (Or capacitors), would release their stored charge to YOU!
This could result in a VERY BAD shock, or a LETHAL one! Like D-E-A-D!
It is for your safety, that I advise you to leave it alone.
More than likely Electrolytic Capacitors INSIDE the power supply for the monitor are bad. The time and cost of fixing it would just be better spent on buying a new one.
SHOULD you NOT heed my warning, you have to discharge EACH, and every one of those capacitors. This HAS to be done in a safe manner.
There IS NO real safe way to do this!
We tech's don't even fool with this anymore. Too many melted screwdrivers, and too much molten red hot shrapnel flying around, to warrant our safety over it.
Posted on Apr 18, 2009
I have the same problem. After you take off the bezel, you have to remove the stickers around where the stand attaches to the monitor. They don't look like stickers, but in fact they are. They are two flexible plastic stickers (kind of kidney shaped) to either side of the metal bracket that attach the stand to the monitor. Just use something sharp, like a pocket knife, and pry them up. You will find 3 screws under each one. Undo those screws, and that will release the internal metal frame from the back piece of the plastic housing. You still have to slightly pry the clips on each side of the plastic housing, but now the whole shebang should come out of there.
As far as fixing the power problem, I haven't gotten that far yet. I plan on testing the power supply next.
Posted on May 15, 2009
I Have a scepter X405BV-FHDR TV That has a black vertical line about an inch wide and is and about 4" from the center of the screen.
TCON board or the LCD panel is faulty. Can confirm by replacing the TCON board. In some models TCON board is integrated to the panel, In such cases you have to replace the panel.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Feb 07, 2017 | Sceptre Televison & Video
How do I remove back panel from scepter flat screen x425
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Disassemble procedure to many popular brand TVs are given with illustrations. I do recall that I've seen the disassemble procedure to this TV too, by this site.
Jul 25, 2014 | Sceptre X425BV-FHD 42" LCD TV 1920x1080,...
Scepter flat screen input problem
It sounds that the input signal selection IC is faulty. This IC is at the main board, and will be very difficult to replace to an inexperienced person. Contact any service technician.
Jun 24, 2013 | Sceptre Televison & Video
Screen is going blank but blue power light stays on
most likely a capacutor has blown or it just lost the signal. try unplugging all connections while powered off the replug the power on. hopes this works. if it dsoes please rate with a comment
Feb 07, 2013 | Sceptre "32"" Class 720p 60 Hz Lcd Hdtv...
Scepter X32 LCD High Definition telivision. Just
Yes it's dead; the power supply in these tvs do not have much stamina;
Due to the fact that their are no provisions for removal of heat. TV does not
have enough fans because customers don't like the noise and, the power supply surge caused by turning a cold set on and, off is not addressed by the manufacturer.
That is why the sets have only one a year warranty.
The choice you have is: repair the power supply or, replace the power supply
unless your set is under warranty.
Jul 30, 2010 | Sceptre X32BV-Naga 32 in. LCD TV
I HAVE A SCEPTER 32GV-KOMODO. WHEN I TURN IT ON THE SCREEN COMES UP AND SAYS SCEPTRE IN RED AND THEN GOES BLANK. NO MENU OR ANYTHING COMES UP
a chip on the main PCB went out. I just replace the board on my X32GV, You can sometimes find one on ebay, you can also get free live tech support from sceptre here. Or send it in for repair if still under warranty here.
hope this helps
Jan 11, 2010 | Sceptre X32BV-Naga 32 in. LCD TV
Sceptre 20" Monitor will not stay on
First check the monitor sleep mode for your monitor in windows control panel, check that its not going into hibernation/stanby. if thats not it. and the monitor keeps shutting down. You may have to replace it newer models have more features and could be cheaper by saving you the hassel check newegg.com or orverstock.com
Jul 08, 2009 | Sceptre X7GNAGAV 17" LCD Monitor
I have a 20 sceptre widescreen lcd monitor
Have you tried any other monitor connected to your computer since your current problem? Check your connections, make sure your VGA cable/DVI cable are in good condition. If none of that works try to RMA it to sceptre if your still within the 1 year period.
Apr 07, 2009 | Sceptre X20g-Naga III 20.1" LCD Monitor
Control buttons on flat screen scepter monitor
My 22" Scepter Monitor wont light-up, pulsating blue light on. I posted this SOS a feww hours ago but I couildn't sign into FaceBook. Please anyone with a solution would be tremendously appreciated.
Best regards,
Oscar
Feb 15, 2008 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
Scepter X37sv-Naga LCD
The Sceptre TV do use the Sony codes. However, the cheap universal remotes do not have the buttons needed. The Volume Up/down and channel up/down are controlled with the circle of buttons (arrows) in the middle of the remote.
You can get an OEM remote from Sceptre. They still have them available. Sceptre is in California.
Jan 04, 2008 | Sceptre X37sv-Naga 37 in. LCD Television
Sceptre X20g-Naga III 20.1" LCD Monitor Logo
1,086 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
