Question about Apex Digital LD1919 19 in. LCD TV
Apex LD1919 tv quit working
I'm having the same problem...just went off, flashing green indicator light, no sound, no picture, no remote, no control panel working. customer support # is useless. They said unplug for 30 sec & replug hit power button & hold for 10 sec & tv will return to mfg defaults. WRONG! NOTHING BUT THE SAME.
  • Judy green Apr 18, 2009
    I want a second opinion...my set is 90 days old & the circuit board blew??? Thanks!
    Thanks...that's 2 for 2. It just pisses me off to know I now have to buy another tv. Peace!
  • 3,037 Answers
Basically the flashing green light means there is a start up problem, probably in the power supply board, but could be a number of things. Sorry to say, but unless you have a ton of expertise in tvs and electronics (which you wouldn't be here otherwise), it will have to be taken to a local repair shop to have it properly diagonosed as this tv doesn't provide an error code. Depending on how much you paid, this might not be worth it as most make you pay $50 just to look at it and lcd tvs are quite cheap right now, especially online though I would go towards a more reliable brand like samsung, element, vizio, etc. Let me know if you need anything else
Benjamin
Posted on Apr 18, 2009
  • Benjamin Patri
    Benjamin Patri Apr 18, 2009
    If its only 90 days old, take it back, return it and get a different brand. If the store doesn't take it back, it is still under manufacturer's warranty for a year.
  • 15,935 Answers
CLICK HERE for your owners manual.
99.99% of the time - unplugging an electrical appliance does NOT work.
In your case - there has been an internal part failure - most likely an output IC, or popped capacitor.
If the light is red - it is in standby mode.
Since the light changes to green - the power supply should be OK... and the failure will be on a circuit board.
If you have no experience repairing LCD monitors (or TVs in general) PLEASE seek professional help.
There are potentially lethal voltages stored inside if not dissipated properly.
Unfortunately - there is no end-user quick & easy solution for your problem.
You are looking at a repair bill around $200usd. Most for labor... as capacitors are about $3 each.
Thanks for using FixYa!!
Black screen / has power / no picture /
Inverter problem shine a flash light you will see picture far in the back ground
Feb 08, 2011 | Apex Digital LD1919 19 in. LCD TV
I have an Apex Digital TV Converter box # DT250A. Today, all of a sudden my TV screen went greenish and then the picture on my TV went out ( static looking screen ). The light that's on my Converter Box...
The DT250 likely has one or more bad 470uf 25v capacitors. You should replace all four. Look at some of these youtube videos for how do do the replacement.
http://www.youtube.com/watch?v=on_2CP52cW4
http://www.youtube.com/watch?v=YCSNWi3UHf4&NR=1
Order 4 new 470uf 25v capacitors from digikey.com P/N P10274-ND
Use first class mail as your shipping method. Will be under 10 dollars total.
Jul 05, 2010 | Apex Digital Televison & Video
Tv green light is plinking. But tv won't come on, it acts like its.
Power Supply board is dead.Replaced the power supply board will solved this problems.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 20, 2010 | Apex Digital LD1919 19 in. LCD TV
GREEN LIGHT COMES ON BUT TV WONT LIGHT UP AND WONT TURN OFF
Call the number on your TV manule and tell them you probley have a Loos Fuse in your Tv
Jan 05, 2010 | Apex Digital LD1919 19 in. LCD TV
Blinking green light and won't turn on
bad capacitors on the power board just one bad on mine! posabilty of 3 two are 1000uf 25v and and the other is like 400v 100uf or something. I pulled one out of an old satalite reciever good luck Thanks JT
Oct 19, 2009 | Apex Digital LD1919 19 in. LCD TV
Green flashing light on but tv won't turn on
Check capacitors on the power board. Two 1000 uF 25V and one 150uF 400V.
Jul 15, 2009 | Apex Digital LD1919 19 in. LCD TV
How do I access the circuit board on the Apex LD1919?
All the components are screwed to the back of the cabinet. Once the back screws are removed, the front bezel snaps off. (Not easily, but take courage and try.) Release a connector in a set of leads to the pilot light panel to get enough slack to lay the bezel flat. The LCD panel then removes with seven silver screws (one is a ground lead). Move it to the side, and the power supply board is accessible. Two connectors and four screws, and it comes out.
Jul 02, 2009 | Apex Digital LD1919 19 in. LCD TV
Need a replacement remote for apex lcd1919 tv
i have one, since my tv just self destructed
Apr 09, 2009 | Apex Digital LD1919 19 in. LCD TV
Apex 1919 tv model brand new and stopped working
I had the same problem. Turned out to be bad capacitor on the main power supply board. The board has a heavy red and black cable at one end and several grey wires at the opposite end. Near the grey cables there are three blue cylinders (two large and one small) surrounded by a black metal frame heat sink. One of the two larger ones was "pregnant" swollen and about to burst. I changed it and the other one like it will new ones from Radio Shack P/N 272-1032 1000 uf 35 WVDC. The unit powered up and worked fine again.
Find a friend who is handy with a soldering iron - parts cost about $3. Be sure to unplug and discharge everything before diving in.
Not a bad little TV/Monitor otherwise.
Good luck
Mar 21, 2009 | Apex Digital LD1919 19 in. LCD TV
No picture or sound?
hi i have a 42 inch plasma samsung tv i have picture and no sound
Nov 03, 2008 | Televison & Video
Apex Digital LD1919 19 in. LCD TV Logo
74 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
