Question about Apple iPod MA446LL/A MP3 Player
Restore my ipod was working just fine, until it said it needed to be restored. I've seen the screen before so i connected to itunes to restore the ipod. It said it was restoring the ipod but never did . It just showed the restore screen again, and itunes started the restore proccess again,the same cycle keep's happening still no restoration.
  • Anonymous Dec 04, 2007
    restoting my ipod
  • craigmod Dec 22, 2007
    I have the same problem
  • 752 Answers
Try pressing the play and center button at the same time until the ipod resets itself, then try.
Posted on Sep 22, 2007
My ipod is disabled and says connect to itunes but it also says itunes could not... so what do i do?
Step 1:
Apple's iPod Touch comes with a screen lock feature that allows you to set a four-digit security code to prevent others from using your iPod. Every time the iPod locks, you must enter this code to unlock the screen and access the user interface. Entering the wrong code too many times, or simply forgetting your security code, can cause you to be completely locked out. When this happens, you can quickly unlock your iPod Touch.
Connect your iPod Touch to the computer you usually sync it with. When you disconnect your iPod, it should now be unlocked. If Step 1 does not work, you have to restore your iPod Touch. Be advised that restoring your iPod Touch returns it to the original factory settings. This means that all your songs and files will be deleted and lost. You can resync your files to your iPod from iTunes once you have finished restoration. Connect your iPod to your computer and open iTunes. Make sure you have the latest version of iTunes before proceeding. In the left navigation panel in iTunes, select your iPod under the "Devices" section. Click the "Summary" tab and select "Restore." When iTunes prompts you about backing up your data, click "Back Up." In the following window, click "Restore." After the restore process completes, you will see the Apple logo on the screen of your iPod. Leave your iPod connected to your computer until it shows up again on the iTunes navigation panel. Your iPod touch is now unlocked. In iTunes you will be able to setup your iPod. Select the backup you made in the drop-down menu to restore your data files. Click "Continue" to finish the restoration. iTunes: Restoring iOS software
http://support.apple.com/kb/HT1414
Mar 01, 2013 | Apple iPod touch Original
Iphone stuck on itunes screen with usb
First power off your iphone and restart it does it start normally or not.
Secondly restart your iphone without connecting to computer. so remove usb cable and restart your iphone ipod or ipad. Even though iphone stuck all logo and itunes and usb symbol then it is a issue of original sim
Secondly when you connect iphone to computer and it detected as recovery mode then your ipod iphone is not properly restored. Here is how to restore ipod / iphone or ipad.
Jun 26, 2017 | Apple iPhone 3G
I redy to run after fornat
Hi Do this first
-Try switching the hold button on and off three times and then hold down the menu and center button
If will not work follow these steps:
o reset your iPod nano (2nd generation):
* 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)* 2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip:o If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.o If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Retry:
Retry your iPod with a different USB port on your computer, not a USB port on your keyboard or hub.
Restart:
Restart your computer, and make sure that you have the latest software updates installed.Note:
* To update your Windows software, select Windows Update from the Tools menu of Internet Explorer.* To update your Mac OS software, select Software Update from the Apple menu.
Reinstall
* To update and reinstall your iPod software, first download the latest version of iTunes.* Next, open the new version of iTunes and connect your iPod to your computer.* Select your iPod in the source list and click "Check for Update" under the Summary tab. iTunes will check to see if your iPod needs to be updated and perform the update for you.
Restore
* Note: Because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your iTunes Library.
How to restore your iPod:For Windows:
* 1. Make sure you've reinstalled the latest version of iTunes.* 2. Open iTunes, and then connect your iPod to your computer.* 3. After a few moments, it will appear in the source list in iTunes. If the iPod's display doesn't show "Connected" or "Do not disconnect" you may need to put the iPod into disk mode to proceed.* 4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main iTunes windows.* 5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software. The 4 possible restore options are:o Restore Option 1: Restore - Restores with same iPod Software version already on iPod.o Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.o Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.o Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.* 6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.* 7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.* 8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Dec 16, 2011 | Apple iPod nano
Ipod stutters and stops downloading youtube
Start by syncing your iPod with your computer. When you do this, the iPod management screen will appear. Midway down that screen there's a button that reads "Restore." Click the restore button. This begins the process of restoring the iPod to its factory settings. After you click the restore button, iTunes will ask you to confirm that you really want to do this. If your iPod content is backed up, go ahead. The iPod restore process includes iTunes downloading and installing iPod software and bug fixes. You will see a window that looks like this. Follow the onscreen instructions. **On a Mac, you will be asked to enter your computer?s password. On Windows, the installation will just proceed. As iTunes restores the iPod, you will see a progress bar. After the restoration process has completed, iTunes will pop up a window letting you know that it?s done. Now you?ve got an empty, freshly formatted iPod. Now you can sync the iPod with your computer and download your iTunes library again.
Nov 05, 2009 | YouTube Computers & Internet
Washed comes on when plugged into computer and functions but not when unplugged
You should try resetting the ipod by pressing and holding both the menu and center buttons down until you see an apple appear on the screen or for at least ten seconds. If nothing happens by resetting it without being connected to your computer; I would try restoring it using itunes i've copy and pasted those steps below for you
How to restore iPod (ARTICLE NUMBER HT1339) Ensure that you have an active Internet connection
as new versions of iTunes and iPod Software may
need to be downloaded to your computer. Download and install the latest version of iTunes
if you do not already have it installed. Open iTunes, and then connect your iPod to your
computer using the USB or FireWire cable that came
with your iPod. After a few moments, your iPod will appear in the
Source panel in iTunes. Select your iPod in the Source panel and you will
see information about your iPod appear in the
Summary tab of the main iTunes windows. Click the Restore button. You will be prompted
iTunes to automatically download the latest iPod
Software. The 4 possible restore options are: Restore Option 1: Restore - Restores with same iPod Software
version already on iPod. Restore Option 2: Use Same Version - Restores with same iPod
newer version is available. Restore Option 3: Use Newest Version - Restores with the latest
iPod Software available. Restore Option 4: Restore and Update - Restores with the latest
iPod Software available. If you are using a Mac, a message will appear
prompting you to enter an administrator’s name and
password. A progress bar will appear on the computer screen
process has started. When this stage is completed, iTunes will present one of two messages on screen
with instructions specific to the iPod model you
are restoring. Restore Instruction 1: Disconnect iPod and connect
it to iPod Power Adapter (typically applies to
older iPod models). Restore Instruction 2: Leave iPod connected to
computer to complete restore (typically applies
newer iPod models). During the stage 2 of the restore process, the
off. After stage 2 of the restore process is complete
first time.
If after a reset and restore it still will not work while not connected; I would try putting it in a DRY bowl of rice over night. You may still have moisture in the ipod. Usually rice works pretty good for this issue. Hopefully, the ipod wasn't damaged and this helped you out. Cheers :)
Apr 22, 2009 | Apple iPod nano
I have just bought a second hand ipod nano generation 3 and it worked fine until I clicked onto the reset settings. It now seems to have locked and i have no idea what to do ? PLEASE HELP
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
  1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
  2. Download and install the latest version of iTunes if you do not already have it installed.
  3. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
  6. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
  7. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
  8. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
    • Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  10. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
All this can be found here: Click Here
Mar 19, 2009 | Apple iPod nano 3rd Generation
APPLE IPOD 30GB
Hi all, Not to worry, Will provide the TS steps...
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
Then follow these steps as well
If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
Then follow this step as well:
Jan 26, 2009 | Apple iPod MA446LL/A MP3 Player
Ipod 5ht screen dont work.
You can try these steps
or
    1. Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    1. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
    2. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
    1. Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    1. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
    2. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time
    Dec 07, 2008 | Apple iPod MA446LL/A MP3 Player
    How to unfreeze mp3 player
    To reset your iPod:
    • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
    • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
    you can also try restoreing it
    Restore
    • Note: Because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your itunes Library.
    For Windows:
    • 1. Make sure you've reinstalled the latest version of itunes.
    • 2. Open itunes, and then connect your iPod to your computer.
    • 3. After a few moments, it will appear in the source list in itunes.
    • 4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main itunes windows.
    • 5. Click the Restore button. You will be prompted with one or more restore options that may prompt itunes to automatically download of the latest iPod Software. The 4 possible restore options are:
      • Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
      • Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
    • 6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, itunes will instruct you to leave iPod connected to your computer to complete restore.
    • 7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
    • 8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the itunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
    if the problem isn't solved.. check your warranty at
    https://selfsolve.apple.com/GetWarranty.do
    Jul 07, 2008 | Apple iPod MP3 Player
    Apple iPod MA446LL/A MP3 Player Logo
    35 people viewed this question
    Top Apple Audio Players & Recorders Experts
    Parshiv Luthra
    Marvin
    Marvin
    Dapid Candra
    Dapid Candra
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
