Restoring Sage back up file
I am trying to restore a company backup file which has been created on the latest version of Sage Financial Controller on another machine onto my own which is version 10.02.0022 Error message keeps coming up which is: programfiles\sage\accounts\company.001attachments\nominal\1200\statements\288.pdf Can anyone tell me how I fix this please
  • AvonJulie Sep 18, 2007
    Unfortunately Sage back ups are zipped so you cant access the files individually. Although it contains a multitude of different files you only see one file on the disk.
    When you go to restore a company back up file from within Sage it tells you which categories the files belong to like data,reports and layouts but you cant see the individual files.
    any other ideas?!
  • 457 Answers
All the back files that was created is on that other machine even while you may think its on that disk in theory YES but physically NO. Thats why you got this: Error message keeps coming up which is: programfiles\sage\accounts\company.001attachments\nominal\1200\statements\288.pdf Just one more try the disk you used look on it if it has the 288.pdf file you may be able to read it from the PDF software and then recreate it in the sage financial creater?
Posted on Sep 18, 2007
  • 2 more comments
  • Peter Hirawani
    Peter Hirawani Sep 18, 2007
    Another solution I suppose would be when you created the backup from an earlier version when it saved the file it would be fresh on your disk but the file would be 288.pdf saved only......then when you go to restore it in the older version of that software perhaps you may have to open it rather than run it thats why this points to the program files and folders of where that software saving defaults too. However if it did not save to the disk it is because it saved it to the default setup in the original software. The only way to recover is to start again you make certain it saves to the disk. I hope Im making sense as not to confuse you sorry if I am.
  • Peter Hirawani
    Ok I see you are line try to unzip the contents in a seperate folder and then using Sage go to that folder Ill wait?
  • Peter Hirawani
  • Peter Hirawani
    To unzip the file in Windows XP just click on it and then extract it to that disk then try Sage?
Restore recovery disk
Hi Billy,
depends on what you mean by restore. Assuming you have windows installed, you can make a back-up by going to START > Control Panel > System and Security > Create a backup
(the path above may be a bit off from the wording, the PC I am on at the moment is not an english version.)
Then on the left side there is a link to create a recovery disk or create a backup. the recovery disk option only makes a bootable disk to start your computer if your windows cannot start. This only gives you an enviroment where you can try to fix windows or to restore a backup that you created beforehand with the second option above.
If you create a backup, there are two things to keep in mind... what type of data do you want to back up and how often. You can put check marks on all data that you want to backup (Note: the more data you backup the larger your backup file will be). If you plan on restoring a corrupt windows with the backup you should include "System State".
Restoring from a backup file a.k.a. backup image will ONLY give you back the files that were on your computer at the time you made the backup... that means everything that you created after you made the backup will be lost.
Hope that helps.
May 16, 2014 | Dell XPS 200 PC Desktop
Want to Backup and check your Windows Activation use WinKeyFinder
The latest version of this program is v1.73 released March 2010 I use this to encrypt my Windows Activation keys the v1.72 is great for backing up and restoring your wpa.dbl activation file
  • Supports Windows 98, 2000, XP, Vista, 7 and more - 32 bit
  • Supports Windows XP, Vista, 7 64 bit versions
  • Supports MS Office 2000, XP, 2003, 2007, and 2010 - 32 bit and 64 bit
  • Many Enhanced features
  • Removed the title RC from it.
This New version has the following Features Removed that were in version 1.72RC:
  • Removed Password Generator
  • Removed Activation Backup/ Restore
  • Many Internal features
I liked it so much I created a U3 installer file for v1.72 to backup my activation files for future installs download the installer HERE from my Sky Drive make sure that you also save a copy of your Volume Serial for the Primary Drive Partition this will change each time you install another copy of the DOS or add a Hard Drive
on Mar 31, 2010 | Microsoft Windows XP Professional
Error code (-6000,-83)
1.. Your solution depends on what action you were taking when the error occurred. Please choose the appropriate selection.
You are opening your company file
You are storing your company file on a Windows server
You are storing your company file on a Linux server
You are restoring your company file
2.. Intuit recommends more than one solution for this problem. The first solution may solve your problem, or you may need to try all of them to resolve the issue. For best results, perform the solutions in the order shown.
Solution 1: Change the extension if the restored file extension is .qbm or .qbw.adr instead of .qbw
Solution 2: Check for problems in your file name and file path
3.. You are creating a back up
Create a new File Folder on the root of the C drive.
Create a backup and save it to the newly created File Folder.
for more help visit
QuickBooks Tech Support
Feb 12, 2013 | Intuit QuickBooks Pro 2008: Windows
Recover data from my backup
Which operating system and what data do you need to recover ???
You can create a backup disk with Microsoft Windows 7 or any other version of the operating system.
This disk will contain the files, programs and settings that you chose to save during the backup operation.
Yet, this disk does little good for you if you do not know how to retrieve that backup data.
Luckily, Microsoft offers a simple process for restoring this data to your operating system.
Even a basic computer user should have no problem restoring her backed up data from a backup disk.
Insert your Windows 7 installation DVD into your optical drive.
Reboot your computer and press a key to boot from the disk once prompted.
Click "Repair your computer."
Choose the hard drive that contains your copy of Windows 7.
Click "Windows complete PC restore."
The latest backup data will be selected by default. I
n the event you wish to restore earlier backup data, press "restore from a different backup."
Click "Next."
Your computer will now restore the backup data into Microsoft Windows 7.
Sep 27, 2011 | Gateway 506GR PC Desktop
I am trying to change the financial year end date in Sage Instant Accounts??
You can only do this is Sage 50 but you can get it changed by someone who has Sage 50 with the same version number as your instant. They can back up their data restore your date change the year and then backup and you can restore it on your computer and they can restore their data. NB they must be on exactly the same version.
Dec 11, 2010 | Sage Instant Accounts 8.0 (013604ug)
What is the latest version of winrar?
The latest version of Winrar is 3.93.
Link to Download Winrar
Rar Labs
This is an evaluation version. To get the best out of it you have to purchase license. They will send it as a Registry File. However you can use it without purchasing, even after it has expired. But you will not be able to get the best compression.
Prior to install, please backup your System State and create System Restore point
How to back up the System State
  1. Click on Start menu and Click on RUN (or Skip if you have the search bar in the Start Menu)
  2. Type in ntbackup and hit enter (you can type this in thesearch bar in other operating systems such as Vista. Hit enter when it finds and shows it to you)
  3. Click on Advanced Mode.
  4. Click on the Backup Tab.
  5. Locate the System State option and check the Checkbox.
  6. Browse and provide a Backup Location. Has to be a separate Partition. Will need some space as well.
  7. Start the backing up. Will take 20-30 minutes depending on the Size of your System Related files and theRegistry.
How to create a System Restore Point
  1. Get the RUN box as I have explained earlier.
  2. Type in this and hit enter. /restore/rstrui.exe
  3. Click on Create a Restore Point.
  4. Provide a Descriptive Name and Click on Create to Create it.
Feel free to contact me again...
Thanks for using Fixya!
Sep 05, 2010 | Microsoft Windows Vista Ultimate Edition
I want to transfer all sate data from my old laptop to my new PC, I have already installed the hardware on the new PC
Sage has an EXPORT function that you can use to transfer data.
You could also copy the daily files from the storage folder to a USB drive
O the new machine use the IMPORT function to import a backup of the files or use the folder options to get data from the USB drive to set up a new company profile which would use your old data to set up a new copy of SAGE with your exisying information.
The prefered option is IMPORT / EXPORT
Feb 21, 2010 | Sage Instant Accounts 8.0 (013604ug)
I have been getting error code -6000; -83. What
Might I suggest going to the Getsatisfaction website. I have provided a link that will direct you there.
You can use OpenID, Windows Live/Bing, or create a new username.
Hope they can help you out.
Jun 05, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Financial Year in Sage
If you are using sage 50 or Sage instant
the financial year can be changed in settings and financial year and click change button. However this is not available in all levels. It sounds if your backup may be out of date.
May 06, 2009 | Sage Instant Accounts 8.0 (013604ug)
Invalid Path error
I get this error when trying to run Financial reports in Sage line 50 financial controller verson 10: C:\PROGRAM FILES\SAGE\ACCOUNTS\REPORTS\\*TB.SRT contains an invalid path No matter what financial report I try to access I get the same error including audit trail. My computer is window Vista. Please help me and also let me know how much is it cost for on line chat?
Thank you
from selvi
Apr 14, 2009 | Sage Instant Accounts 8.0 (013604ug)
Computers & Internet Logo
3,866 people viewed this question
David Payne
David Payne
