Question about LG WM2487H Front Load Washer
Our machine's digital display reads 'dE' seconds after pressing start and nothing isour machine's digital display reads 'dE' seconds after pressing start and nothing is happening except for an awful b
Our machine's digital display reads 'dE' seconds after pressing start and nothing is happening except for an awful beeping. Any advice appreciated!
  • 116 Answers
Try to close dorr completely if not call in service tech.
Posted on Apr 29, 2009
    President:
  • 1,865 Answers
The dE error means that the door switch has failed to "make" Either the door is not closed all the way, or the door switch needs to be replaced or adjusted.
Posted on Apr 18, 2009
I have a vetch mod# CS6114 I checked the base unit and it gets power to charge phone but I can't get a dial tone. I even hooked up to another line and still won't work.
This sounds like a registration problem, the
handset must be de-registered from wherever
it thinks it is and then registered to your base.
( I ). First, to de-register a cs6114 handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll from "Test Base" to "Test Handset", press [select]
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( III.) To register the cs6114 handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
NOTE 2: Some cs6114 bases do not have the "In Use"
lamp indicator. To register the handset simply park it
displaying "Not Registered" in the base cradle and wait
for the registration to occur. Pressing # as above may
be required, maybe not.
Good luck !!
Feb 12, 2015 | Vtech DECT 6.0 Cordless Phone with Digital...
Hi,I have just bought a Denon dn m991r second hand and I am having problems recording on analog.I press record and DIGITAL IN starts flashing on display,I press play/pause button but nothing happens no...
Go here - http://www.minidisc.org/part_Denon_DN-M991R.html . Get the owner's manual. Read it.
The preset mode changes whether you record analog or digital.
Assuming nothing is jamming or is bent, the weak eject is probably why the guy sold it to you. It can't hurt to take the cover off and watch what happens.
Aug 05, 2012 | Denon DN-M991R Mini Disc Player
LG WM1814CW Front load Washer dE error? I get the dE error everytime I push the start button. The door wont open or close. I can hear the latch moving inside but nothing will happen. The "Door...
A dE error code indicates that the washer door was unable to lock. This can normally be resolved by performing a simple reset on the washing machine.
How to reset the washing machine:
1.
Press POWER to turn the washer off.
2.
Unplug the washer from the power outlet or turn the circuit breaker to the unit off.
3.
With the power disabled, press and hold the START/PAUSE button for 5 seconds.
4.
Plug the washer back in, or turn the circuit breaker back on.
5.
For more information about how to reset your specific model, please refer to the owner's manual.
Press in on the door firmly and select any cycle. The washer door should lock, and the cycle should begin without an error code appearing on the display. If the cycle does not begin and the dE code appears again, repair service is required.
Feb 03, 2018 | LG WM1814CW
I have a Health O Meter HDM560. I need to reset the #1 and #2 users and start over, can you help me there is nothing in the manual about it I can find.
Current Instruction Manual for the HDM560 can be found here:
http://www.healthometer.com/Manuals/MANUALS/HDM560-05_43_41816518.PDF
For resetting it would be similar to the initial setting process. FOLLOW these steps:
Lift display cover. Push "SET" button at bottom of pad. User "1" and "2" will appear.
User "1" will start blinking. Press the "USER" button to choose user "1" or "2". Once selected, press "SET" button to lock in information.
Both "HEIGHT" and "AGE" will appear on the screen. The "HEIGHT" will start blinking. Press the "UP" or "DOWN" arrows to find the correct height.
After entering height, press the "AGE" button. Use the "UP" and "DOWN" arrows to enter correct age and press "SET".
Both "MALE" and "FEMALE" images will be displayed. Press the "GENDER" button until the correct MALE/FEMALE image blinks and then press "SET". This will lock in the information.
Your correct information including User, Height, Age, and Gender will be displayed. Now you are ready to calculate weight.
Tap your person "USER" number (1 or 2) in center of scale with your toe. Your personal profile will appear. Wait until "000" appears. Stand on scale so bare feet are positioned over silver pad surface. "000" will blink your weight for approximately 3 seconds. "BF" will flash and body fat percentage will appear. The scale will turn off automatically in a few seconds.
May 21, 2011 | Health-O-Meter Health & Beauty
Program will not start but there is a key icon showing
Hello Tom, welcome to Fixya. The "key" symbol indicates the "child lock" feature has been activated. To de-activate it simply follow these steps... 1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display ) 2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display. 3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program. Let me know if this was helpful to you or not, if so please take a second and rate it accordingly. Thank you for visiting "fixya" for your washer solution inquiry. Good luck macmarkus :)
Jun 21, 2010 | Bosch Classixx WFL 2066 Front Load Washer
How can i turn off key symbol
Hello Lucy and welcome to Fixya.
As far as the "signal" activation or de-activation goes, it should be performed before starting a load of laundry and it is as follow's... 1) Turn the program selector to any program as you would doing laundry. Add your items... 2) When you close the door the "start/pause" light flashes... 3) Press the "menu" button until the signal indicator is displayed and flashes ( a small speaker symbol ) as does the start/pause light. If no buttons are pressed within 10 seconds, the current setting will be saved. 4) Press the "select" button until the desired volume or "off" is reached/displayed. 5) Press the "start/pause" button so the program starts and the setting is saved after the cycle has completed. As for the "key" symbol, your washer has a "child lock" program and the symbol indicates it has been activated.
Here`s how to deactivate it...
good luck going forward.
macmarkus :)
Jun 16, 2010 | Bosch Washing Machines
How do I deregister my handsets on my VTech 2656
To be able to register your replacement handset, you must de-register all the handsets from the VT2656 base unit.
Follow the steps below to de-register your handset(s) from the VT2656 base:
1. Take out the handset that sits on the base.
2. Unplug power from the base.
3. Hold down PAGE while reconnecting power. When the In Use light blinks, release the PAGE key.
4. Hold down PAGE key for 5 seconds. When the In Use light begins to flash, release the PAGE key.
5. The handset charging light will blink 5 times. Within 5 seconds from when it stops blinking, press PAGE once.
You must register the handset(s) by following the steps below:
1. After charging the handset, remove it from the cradle, the LCD display will read "SEARCHING FOR BASE".
2. Press "NEW" and then enter the 15-digit Base ID code, located on the underside of the VT2656 base unit.
3. Press "OK". The handset will display "PLEASE WAIT!!".
4. Wait approximately 15 seconds. The handset will display "FOUND BASE". If the handset displays "BASE BUSY TRY LATER", this indicates that the system is in use. Wait until the base unit is in the idle (on hook) mode and repeat steps 2-4.
Apr 30, 2010 | Vtech Digital Cordless Telephone VT-2568
I have a problem with panasonic kx ft938 showing "fax memory full". How can i clear it?
The memory is full of received documents due to a lack of paper, or a paper jam.
Install paper or clear the jammed paper.
or, unplug the unit for about 5 minutes.
or, to clear the RAM, try one of these procedures:
(If the first one doesn't work, try the next one)
1.
Press menu 7 dial dial dial dial * 6 start
Press up-arrow key until the display reads shipment set then press start
The display will read reset counter
Select yes or no then press start
2.
Press # 7 dial dial dial dial * 6 enter
3.
Press standby set dial dial dial dial * 6 start 9 9
On success, a long beep will be heard
4.
Press menu 7 monitor monitor monitor monitor * 6 start
Parameter 65 for memory collation should be set to invalid to maximize the memory page rating
Nov 27, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Error code de
hi, i've got the same problem. But when i leave it for a minute or two with the beeping, it will automaticaly start its washing program. Without opening and closing the door. We probelbley need a new door sensor. I've seen them on the internet for $100. But as long it's washing like it does now. I'am leaving it like it is.
Aug 21, 2008 | Washing Machines
LG WM2487H Front Load Washer Logo
519 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
