Sony KP-53S75 53 in. Rear Projection Television
Problem for Sony KP-53S75 53 in. Rear Projection Television
Sony KP-53S75 Red convergence problem
By lsquared on Sep 17, 2007
The red on my Sony KP-53S75 tv started bending and isn't lined up with other colors, giving the old 3-D glasses effect, double words and images. I covered the red lense and except for the missing red the picture is crisp and clear. I have read about the convergence ics and have ordered Sanyo replacements. I am a pretty good fix-it guy but want to know exactly what I need to do to discharge caps, replace ics, check fuses and resistors etc.While I'm in there,how do I clean the lenses and mirror(s)and adjust picture after? Thanks for any info.
Same Problem
Apr 09, 2009
-   hey i have the same problem i even bought a new remote to try to fix it but there is no tv setting on this tv that allows u to move the whole screen?-   lillajon
Nov 20, 2008
-   convergence adj
-   Guest
Solution #1
posted on Feb 22, 2009
Not Rated)
Ecollier2012
Rank: Guru  Sony Televisions & Videos  Expert
Rating: 93%, 587 votes
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
Solution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Was this helpful?
Yes
No
Solution #2
posted on Oct 13, 2007
Not Rated)
tvtechnician
Rank: Guru  Sony Expert
Rating: 88%, 122 votes
to discharge the caps just unplug the tv and wait about ten minuites. to replace the ics i use solder wick to remove the solder. insert new ics and solder. after you have replaced them the convergence should pop back into place. to clean the guns just wipe off the top of the lens. if the mirror is clean just leave it as any little blemmish will show on the front screen. very rarely the stk ics dont fix the problem. if this is the case there are a few resistors and fuses next to th ics. to check them just use a cotinuity testor. if any of them are open replace them. the resistors and fuses usually run in groups of 4. four for each color.
Was this helpful?
Yes
No
Popular Solutions for Sony KP-53S75 53 in. Rear
Questions and Unsolved Problems for Sony KP-53S75 53 in. Rear
Do you recommend Sony KP-53S75 53 in. Rear Projection Television?
Answer
Answer
have a Sony KP 53S75 and speaker is distorted during sound. How to remove cover to inspect and... (More)
Answer
rca projection hd52w66 got sound --no picture,no raster
Answer
no picture. on light blinks four times pauses and blinks four times.
Answer
no picture or audio from tv, can hear power supply turn on. timer light blinks 4 times. minor smoke... (More)
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in , IL
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
