Printer will not print
Gave command to print, heard a ''tone'' and since then cannot get printer to print. It has one item in ''q'' but it will not delete that item. I have re-connected everything to make sure nothing loose but nothing seems to work......help.
  • 537 Answers
Restart the PC. If that doesn't help, delete the printer and reinstall it. This happens quite often for some printers.
Posted on Apr 18, 2009
I have sumsang SCX3200 & I want to print my some Document & figer frm dos mod. Windows Xp is runing on my desktop pc
DOS applications cannot print on USB ports, but there's a workaround by using a share and the NET USE command, first create a share of that printer check this site: http://compnetworking.about.com/od/windowsnetworking/ht/printer-sharing.htm, (take note of the name you gave the shared printer) than you use NET USE command to connect the shared printer to a virtual port (LPT2) first click on START, than RUN, than type CMD than hit enter, type the following command " net use lpt2: \\127.0.0.1\(shared printer name) /yes " than hit enter, if you have a " command completed successfully " than you have your shared printer connected to a virtual port (LPT2) now it is just a matter of setting your DOS software to print to LPT2... and VOILA! it prints...
Jun 25, 2011 | Office Equipment & Supplies
Troy 8150 Printer
Yes I beleive you do need the -P
I use this on a HP 8150 I think it is Aust.version of you machine from the look of it
lpr -S 100.100.10.111 -P raw -o c:\temp\output.ps
Getting print q name
Press Menu until INFORMATION MENU appears on the printer display.
2. Press Item until PRINT CONFIGURATION appears on the panel.
3. Press Select to print out a configuration page
2nd page should be listed your print que name
or maybe just type the ip address of printer in browser and look in printers webpage.
Sorry for sketchy answer just trying to help!!
Oct 31, 2007 | Office Equipment & Supplies
How do I print a negative black & white photo...it keeps printing a yellow tone image?
hi...while you give the printing command go to option and select black and white option. u can get black and white.
If u get yellow tone image means that the catridge of black might hav finshed please check the catridge and replace it.
Jul 05, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Printer will not print anything except test page and wont delete
Possibly, the print spooler needs to be restarted. In Windows, one of the ways to do this is in the Command Prompt window. (Start > Accessories > Command Prompt, right click on the command and choose Run as Administrator in Vista or Win7).
Type "net stop spooler" <enter> without the quotes. At the next prompt, type "net start spooler" <enter> again without the quotes. After the last command finishes, restart the computer. Check that the queue is empty and retry printing.
I hope this helps.
Apr 15, 2010 | Lexmark X1270 All-In-One InkJet Printer
I cannot figure out how to load the paper in my new canon mx300 printer. I put the stack of paper in the back of the printer, but none of the sheets will feed through. Any suggestions?
Hi,I assume you gave a print command from PC but printer did not print?
Did you try to make a "copy" of something ? as photocopier function. thru the command keys on the printer..
Please give me more detail then I can give more solutions..Regards
Jan 26, 2010 | Canon MX300 Office All-In-One Printer
2 document pending for print.i coud not print now.
hmm simply just click printer icon and cancel all the docs for printing then again give the print command and your papers will print
Mar 28, 2009 | HP PSC 1210 All-In-One InkJet Printer
Tone adjustment
When you give 'print command' a window appears. From that window select 'Properties' besides the name of your printer. a new window opens , from this window select the appropriate tab as per your printer and adjust ink level or set print quality to 'fast' or 'fastest' or 'draft' whichever opion that may be present.This will make the prints lighter. !
Dec 11, 2008 | Epson Stylus CX5000 InkJet Photo Printer
LOUD clicking sound and no print
plz give me a solution when i gave a print command there is two light one is green and second is orenge light this two lights are constend so plz give a solution.
May 04, 2008 | HP LaserJet 1020 Printer
Printer offline
1) Ensure you've run the D-Link supplied automatic configuration wizard. 2) Also ensure you have "Netbios over TCP/IP" enabled in your network settings. 3)Ensure you turn off "Bidirectional Printing" in the Ports tab and "Enabled Advanced printing features" in the advanced tab, for testing purposes. I know the printer connectivity is officially supported by D-Link (thru an independent 3rd party test facility) but it seems they may have had NetBeui installed, which is an outdated networking protocol. Try the first 3 options I gave, if they don't work, then let me know. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
24 people viewed this question
jasbo
jasbo
