Question about Philips 60PP9401 60" Rear Projection Television
Phillips 60pp9401 tv was fine last night--this morning i turned on cartoons fo rteh kids and the colors were like 3d---after i took my kids to school i tried to take off the back cover to see if there was some kind of adjustment--i didnt know there was a mirror on the back cover and it fell and shattered when i removed the last screw. online the mirror is $175 to replace, but my local glass compant will make me a mirror with the correct dimensions for $45 would this mirror work?
  • pdquix Dec 31, 2007
    yes i still need solution where do i get chips to repair or should i let a tv shop do it. Thanks
    Genius:
  • 1,694 Answers
Yes,generic will work, mirror material is nothing special, just get
the size right................
Original problem is convergence issue....do you still need solution ? ...................................T.
Posted on Dec 14, 2007
6ya staff
SOURCE:
We have a Philips 60pp9401, 60' rear projection tv. The images looked like they are layered. How do we align the colors without the original remote control? Using Intellisense.
U can't alignments this even u have the original remote.Tv have a problems known as convergence problems,it dead.Colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be changes on the tv convergence board to fix convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 18, 2010 | Philips 60PP9401 60" Rear Projection...
Looks 3d,bows in the middle
You must replace conversion IC's (2)
Part number: STK 392-xxx
Also check resitors in circuit for>>open
easy repair!
May 19, 2010 | Sony KP-43HT20 43" Rear Projection...
Looks uneven almost like 3d
The lenses might have moved out of line - with power off give a gentle tap to the side of lense suspected of this problem. (power off) then switch on if there are changes then you have found your problem.
good luck
Sher
May 30, 2009 | Philips 60PP9401 60" Rear Projection...
DVR 510 WON'T WORK ANYMORE
Did you have a power outage last night or lightning strike? If not unplug the receiver for approxiamately 30 seconds and plug it back in to the wall plate. Try to turn it on now. If it fails to power up it may indicate that the receptacle is bad or the receiver. Swap the plug from the receiver to the known good outlet the tv plugs into and try to power it up. If it fails the receiver is dead and you will need a new one. 510 are due to be discontinued with Dish so your local provider may not have one to replace yours with and you may be left with the option of upgrading the receiver, seeing if Customer Service can send you one out if you have a warranty program or buying one from a retailer or online.
Hope this helps you.
Apr 07, 2008 | DISH Network DVR 510 DTV Receiver /...
Phillips 60pp9401
This set uses two convergence packs that go bad and take with them a resistor or two. You will need a repar shop to get it fixed. If it's over 10 years old, I would suggest getting a new HDTV set as these sets can start going downhill fairly rapidly past this age. If that's not an option, the repair could run over $350 IMHO.
Dec 18, 2006 | Philips 60PP9401 60" Rear Projection...
Open Questions:
See all Philips 60PP9401 60" Rear Projection Television Questions
Philips 60PP9401 60" Rear Projection Television Logo
106 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
