Question about Dell Dimension 5100 (D51L1) PC Desktop
No boot no keyboard or mouse
Getting keyboard errormouse and keyboard will not work in any usb ports they work on another computer. When powering on gts to th bios loading page and stops. If i leave it off for a while it will boot normal, but still no keyboard or mouse
  • lmrom Apr 18, 2009
    reset password tried keyboard then tried mouse still nothing. tried my phone in a usb port that works(charges off the computer) time to dump this pig
  • 3,940 Answers
First disconnect all external connections except video, see if system will boot normally (press the power button once on tower to shutdown)
If that works, then connect the keyboard only to the back USB port nearest the NIC. See if the keyboard works. If it does, shutdown and connect the mouse and try again. If it doesn't, try the mouse only. If you localize the problem to either the mouse or keyboard, replace that item.
If neither works, then reset the motherboard junper to reset BIOS defaults. the again, try them one at a time. If they still do not work, then you will need a mothebroard.
Posted on Apr 18, 2009
USB ports fail - no mouse or keyboard on start up on hp pavilion desktop p6000
some older computers don't load usb devices until after windows is booted and in such instances usually a traditional ps2 mouse and keyboard (green and purple plugs respectively) are the best option to enter the bios or boot from cd/dvd
Jan 19, 2016 | Computers & Internet
Keyboard stopped working
http://www.ascendtech.us/emachines-kb-0705-ps-2-keyboard-black_i_kbdemkb0705bps2.aspx
Things I see here.
1) The second Keyboard you plugged wasn't any good either.
2) The PS/2 port for your keyboard on your motherboard, isn't any good anymore.
Computer off, plug it into the Mouse PS/2 port, and use a USB mouse.
BIOS will reset the I/O address for that PS/2 port, and set it for the Keyboard, when the computer is turned back on.
You may have to;
A) Turn the computer off
B) Unplug from power.
C) Press the Power On button in, and hold it in for a count of 10 seconds. Let go of the Power On button. Do this same procedure two more times.
What you are doing is draining residual power, clearing CMOS Error Codes, and resetting BIOS back to the factory default settings.
Keyboard plugged in, USB mouse plugged in, plug the computer back into power. WAIT 1 minute, turn the computer on.
Still no?
Motherboard replacement.
You didn't unplug the old Keyboard, WITH the computer on, and plug the new Keyboard in, did you? It isn't a hot-swap device. The computer must be off when unplugging a mouse, or keyboard.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 28, 2012 | Computers & Internet
Dell E521 cannot get to bios with usb keyboard.
check the loose connection on mother board try to reconnecting again then after that power on the computer quickly press f2.
Mar 06, 2010 | Computers & Internet
Hello, i currently use a IBM desktop with IBM keyboard and mouse but i just bought a microsoft wireless keyboard and mouse which i just installed into my desktop using the installation CD. They are both...
Hi Tony,
It appears that you have an IBM desktop whose BIOS isn't capable of booting off of a USB keyboard and mouse device. Older computers used to require that a PS2 mouse and keyboard be attached before booting, to prevent you from booting a machine without any way of controlling it. You have 3 options:
1. leave the corded mouse and keyboard attached and never use them
2. update the BIOS for your desktop to the newest one in hopes that the updated BIOS will allow for USB mouse and keyboard operation
3. go to a computer store and get a PS2 to USB converter/adapter. They're small and relatively inexpensive. It plugs into the PS2 port, and makes your computer think that there's a PS2 device connected, when it's actually a USB device.
Mar 03, 2010 | Microsoft Wireless Laser Mouse 6000 v2.0
Mouse and keyboard have no power
If your mouse and keyboard work properly with another computer or laptop the problem could be :
A) if devices are USB :
- defective USB port : chose another USB port;
- USB port inactivated in BIOS : check and activate;
- motherboard defective : replace motherboard.
B) if devices are PS/2 :
- damaged PS/2 ports : buy a PS/2 to USB adapter for your mouse/keyboard or buy USB mouse and keyboard;
- motherboard defective : replace it.
Oct 04, 2009 | Computers & Internet
USB keyboard and mouse not working on startup. Dualboot with xp and vista.
The usb ports might me malfunctioning . Try to use different ports. If that doesnt solve it then there might be a power issue on the board.
Apr 26, 2009 | Abit IC7-MAX3 Motherboard
Problem with KVM switch and Vista
Your problem has nothing to do with the Operating System (Vista), it has something to do with the brand of your computer. I have similar problem before, I have Vista (Dell), but the time I connected another Vista (Sony Vaio), everything worked correctly.
This is what you need to do:
1. You have to make sure that you are using a standard USB keyboard and mouse.
2. Connect first the keyboard and mouse directly to the Vista computer to see if the USB ports of your computer are working properly.
3. You may power cycle the KVM switch by disconnecting it from the computers (including the keyboard and mouse) and leave it disconnected for 2 minutes.
4. Reconnect everything after two minutes and then reboot the computers.
5. Try using different USB keyboard if problem exist after power cycling the KVM switch.
Sep 16, 2008 | IOGear GCS632U 2-port KVM Switch
Mouse and keyboard not working / recognized by computer
If its an USB keyboard and mouse, try to insert keyboard in upper port and mouse in lower port USB.
Sometimes when they Both are inserted in port in same line, they are unable to Fetch equal amount of power.
Try this and do restart your computer, after inserting them in USB ports.All the Best
Jul 02, 2008 | E-Machines T3624 PC Desktop
Keyboard
It seems that your motherboard had or say nearly to its end... but you can use USB-keyboard, that's one way to solve it, or a USB-mouse. But before doing so try to disconnect the mouse and use use computer... if it works, then it's either the mouse or keyboard will be transferred to a USB port.
Nov 05, 2007 | Dell Dimension 8200 PC Desktop
No mouse or keyboard power
There might be. Try the Keyboard and mouse on another computer and see if they work. By the way, are they wireless?
Apr 17, 2007 | ASUS P5LD2 Motherboard
Dell Dimension 5100 (D51L1) PC Desktop Logo
308 people viewed this question
Alun Cox
