Question about Toshiba 65H81 65" Rear Projection Television
No Sound, wavy horizontal lines, blinking picture, missing picture modes.....Piece of Junk!
I bought this Toshiba 65'' Widescreen HDTV back in 2002 and just after the warranty ended the speakers quit working. Then a year later it quit displaying in "Full" screen mode while using component hdtv inputs which meant I never knew the scores of the Final Four or Football games because the only modes it would show would be the zoomed in video modes. Now, for 100% of the video inputs, the screen constantly blinks and wavers all over the place. It is worse as you go to the top of the screen. When it first started doing this it would get better as the TV warmed up for 30 minutes or so, but now it just blinks and has blurry lines everywhere. I took of the back panel and the inside parts and wires are mostly coating in a black dust. Is it worth anything to clean it? Anyone seen this problem and can I just buy the board part and replace it myself because if I have to pay alot to repair this TV, I would get more enjoyment hauling it to a field and blasting it multiple times with a shotgun.
    Problem Solver:
  • 6 Answers
It is a good tv over all, so I think is worth fixing. because when it works, it give out a very nice picture compared with other rear projectors or DLP's for that matter. and it was also expensive for a reason, no?
It's the convergence IC's that need replacing. STK 110. you can put in there 150 or 180's. If you are not handy with this kind of stuff have someone put it in for you for about 200 bucks and the 2 chips are 10-15 bucks each.
Hope this helped
Nic
Posted on Nov 07, 2008
SOURCE:
Mitsubishi rearTV has intermittent wavy lines running throughout
Do you have anything to test it in 1080i? Does it do it on all connections or just one? I had a similar problem with my TV that turned out to be a bad input board. Mine would only display 1080i through the Component connections. All others would show pink and green wavy lines. It cost me around 500 to fix it. Unplug the TV. Remove the back cover for the TV. Using a NON-metal object, or gloves, wiggle the input board (that has all the video connections on it) slowly back and forth and see if the problem comes and goes. You will have to have someone watching for you. If something is loose on that board, the problem should show itself. Narrowing down the problem will probably save you money on repair bills.
May 13, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Wavy line on bottom and top of widescreen line?
Its filter in vertical section is leaky.
Dec 30, 2009 | Sanyo DP42849 42 in. HDTV
I get curved red lines and then screen goes completely red and no sound
This is symptom of defective red picture tube in TV that needs to be replaced.
Let me know if you want to replace it by yourself to provide you part number info or call tv tech to do the job.
Thanks.
Nov 30, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Mitsubishi 55" Projection TV / Horizontal Wavy Lines at Start Up
this is very common with these sets. the fix is to replace 11 very very smal capacitor on what is known as the hypermodule. The ideal sitation is to replace the hypermodule. if you can find it. I can do this repair. I have done about 10 at the shop. if you need to i would suggest finding someone who is very experence in surface mounted repair
Mar 18, 2008 | Toshiba 65H81 65" Rear Projection...
Green screen crash
i have a projection tv. It is a a Samsung HDTV 55" widescreen. There is a green curvey lines at top of screen. Can you help?
Jan 20, 2008 | Televison & Video
Toshiba 65H81 65" Rear Projection Television Logo
163 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
