Question about Allied Telesyn AT-2746FX (AT2746FX) Network Adapter
Lost of ethernet 100baseFX reception
I have the card installed on a PC and conected to LAN and using the 100baseFX port connected to an industrial switch garretcom. After a temporary power down of the switch the card tramits normally but stop receiving frames. The "100" LED flashes twice a second. The problems fixes when the umplugging and inmediately plugging the fiber RX ST connector is done.
    Scholar:
  • 47 Answers
Have you tried replacing the fiber cable? It sounds like the connector is loose or the cable has been bent too far.
Posted on Sep 17, 2007
My dell xps 410 will not go online thru either of the ethernet ports on the computer. im using my phone with usb tether and it goes online fine. it says it need the ethernet controller driver but...
Hello, look at this link, you should have installed the bottom driver, but take care! if you've got a LAN card as well, you might have got the MOBO one disabled in bios, so best to take out the LAN card, find out what it is and look for a driver for it, meanwhile, with it removed, install the LAN driver for the MOBO LAN port, (bottom driver on this link ) and see if it appears in your 'Network Connections' (Check in bios to see if it's been disabled, though)
Regards, nicam49
The link: http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=DIM_PNT_9200_XPS_410&os=WW1&osl=en&catid=&impid=
Aug 22, 2011 | Dell XPS 410 PC Desktop
When installing the disk it says the ethernet cable is not conected when it is
Connect the LAN cable from the D-Link to the LAN port on your computer. If you have alreadt done this and you get this error message then it is possible the LAN card driver has not been installed.
I suggest you install or reinstall the LAN card driver before running the D-Link installation disk.
Jun 20, 2011 | D-Link DIR-600 Router
I have two ParkerVision WR1500 4-port Wireless DSL/Cable Routers. The first one I have connected my Ethernet Cable from my modem to the WAN port. This is where I get my Internet Signal. My understanding...
You won't get internet connection that way because there is no connection between the first parkervision and the 2nd one.
Best way is use only one parkervision router. Connect WAN port to modem for internet, 1st lan port connect to your pc and 2nd lan port connect to 2nd pc in other room. 2nd way is, use only one parkervision. Connect WAN port to modem for internet, 1st lan port connect to your pc, setup wireless SSID and connect your 2nd pc to this router for internet wirelessly. Assuming your 2nd pc has wireless capability.
Apr 13, 2011 | ParkerVision SIGNALMAX WR1500...
Adding a PCI ethernet card?
One port on the router is an "Ethernet" port -- look closely to see the 8 wires in the socket.
You'll need a similar 8-wire connector on your computer,
and an "Ethernet-cable" that has 8 strands of wire.
Adding-in the PCI Ethernet card will add an 8-wire connector,
so that the Ethernet-cable can be connected.
Be sure to buy a 'PCI' Ethernet adapter, not 'PCI-E', and not 'ISA'.
It may come with a CD-ROM containing software to be installed.
Don't pay more than $20. Or, find a "computer-geek" -- he/she probably will have one or more "spare" PCI Ethernet cards to give to you.
Nov 18, 2009 | Dell Dimension 4400 PC Desktop
Can you tell me what the difference is between the modem part for ethernet/usb adsl modems, 060-E240-061 AND 060-E242-A01. I would appreciate and info or direction to a specific web site for this info....
when your pc conect with ethernet port also say that LAN port and oter port is USB port
which one conect with ethernet/LAN port is
called ethernet Modem and which conect with
USB port called usb Modem.
Jul 06, 2009 | Computers & Internet
Ethernet port not "active"
Hi there.
Restart the PC and go into the bios to make sure the on-board LAN is enabled, if it is try as jery says and try another ethernet cable.
Post back please and good luck
Apr 21, 2009 | Dell Latitude C400 Notebook
How to conect a wireless router to a regular modem
If your modem/router has a USB connectivity, you can connect it via USB. Else you will have to buy an Ethernet PCI Card, which wont cost you much.
I hope this solves your problem. Good Luck ! Kindly Accept my Solution.
Regards, Arjun
Apr 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
No LAN conection displayed in network connections
check that proper driver is installed, in the device manager that shows excmlatory mark that indicates proper driver not been installed, update the driver it will works
Mar 22, 2009 | HP Pavilion a6547c Refurbished AMD Desktop...
How do i connect to a lan with a Toshiba Tecra 8000
You can get a bus card that has an ethernet port to hook up via ethernet cable, or a universal wireless card for the bus port or usb port. You can find either of these at Walmart or Bestbuy.
Jul 27, 2008 | Toshiba Computers & Internet
LAN card not installing
u can use any brand . there's no problem in that . installation procedure is very simple. just buy a pci lan card. Insert it in the pci slot. Then switch on your computer , insert the driver cd provided with your lan card , then install the appropriate drivers.
Then, you can connect BSNL Broadband by connecting your ADSL modem with your LAN card.
Hope it helps..
Regards
Grydor.
Mar 06, 2008 | Computers & Internet
Allied Telesyn AT-2746FX (AT2746FX) Network Adapter Logo
46 people viewed this question
Top Allied Telesyn Computers & Internet Experts
Prashant M
Prashant M
Are you an Allied Telesyn Computer and Internet Expert? Answer questions, earn points and help others
